#11
Black box was planned, but the cost was too close to the original Colibri,
(the same but with Nav display) that as far as I know, LX Navigation never offered this unit.... tim "mike" wrote in message om... Nice review Tom. Does anyone know about the Colibri Black Box (BB) recorder. I assume it's a more affordable version. Thanks; __Mike Ziaskas "TOM RENT" wrote in message ... I recently studied, selected, and installed the LX Colibri IGC Data Logger in my Glider, and have posted some information on this at: http://www.goldengate.net/~tmrent/so...35/Colibri.htm I will update this site as necessary. Good lift, Tom Rent Minnesota Soaring Club I also host the Schweizer 1-35 site at: http://www.goldengate.net/~tmrent/so.../sgs135new.htm [replies to me must remove the "XXs" in my email address or they will bounce] |
Hi Bob,
The quote below is after he already fixed the text. Paul Remde "Bob Lepp" wrote in message m... Nice Colibri write-up with excellent photos. I must point out an error though. In the review text you mention that the Cambridge 302A has built-in antenna. That is not correct. It has an external antenna that can be mounted remotely, just like the Colibri. Happy Easter, Paul Remde Paul, I believe he said the Volkslogger had a built in antenna. Quoting..... The 302A was recently approved but is large, not very portable, and is a basic logger with no built-in user interface. The Volkslogger is popular and reliable but not so easy to use due to the poor human factors of the user interface. Also, the Volkslogger has a built-in GPS antenna, limiting the options of where you must mount it. Bob |
Kevin Christner wrote:
Andrew Warbrick wrote in message ... Good review, clear and to the point. You forgot to mention one feature of the Colibri which might influence people's decision. The internal memory back up battery needs to be replaced every few years and to retain IGC approval this has to be done by the dealer, not the owner. Having said this, I still bought a Colibri as the best option. The user interface on the Volkslogger really is vile in comparison. It is true that the Colibri does have internal back-up battery, as do MOST other flight computers, loggers and even avionics, the truth is that since the Colibri was introduced now nearly 8 years ago, we have yet to replace any of these batteries from routine use.....as long as the Colibri is used frequently and not left dormant for very extended periods. Kevin Christner for Tim Mara Having done this with my LX20 it is pretty simple on this model. The battery is on a seperate screw secured pocket - as long as you ensure power continuity when you replace the battery you are away. If you are unwise enough to remove the power completely (no external power and no 9V leads to the battery connector) you will have to return the unit to the LX folks in Slovenia. The reason for the batteries is to ensure integrity of the data stored in NVRAM, so the security info will be lost when it loses all power. Might be worth sending to LX for the older LX20 units anyway - so they can be upgraded to the new security spec. Can't speak for the other loggers. One other point - the battery on mine was getting weak but still functional after 8 years. 1996 model LX20 must be one of the older ones out there and still going strong. With the latest firmware I even get final glide information and a rudimentary moving map. The support from LX is outstanding and consistent. |
At 08:54 14 April 2004, Bruce Greeff wrote:
Kevin Christner wrote: Andrew Warbrick wrote in message news:... Good review, clear and to the point. You forgot to mention one feature of the Colibri which might influence people's decision. The internal memory back up battery needs to be replaced every few years and to retain IGC approval this has to be done by the dealer, not the owner. Having said this, I still bought a Colibri as the best option. The user interface on the Volkslogger really is vile in comparison. It is true that the Colibri does have internal back-up battery, as do MOST other flight computers, loggers and even avionics, the truth is that since the Colibri was introduced now nearly 8 years ago, we have yet to replace any of these batteries from routine use.....as long as the Colibri is used frequently and not left dormant for very extended periods. Kevin Christner for Tim Mara Having done this with my LX20 it is pretty simple on this model. The battery is on a seperate screw secured pocket - as long as you ensure power continuity when you replace the battery you are away. If you are unwise enough to remove the power completely (no external power and no 9V leads to the battery connector) you will have to return the unit to the LX folks in Slovenia. The reason for the batteries is to ensure integrity of the data stored in NVRAM, so the security info will be lost when it loses all power. In the Colibri the back up battery is internal. To get IGC approval loggers have to erase security information once the case is opened. Having said which, I still consider the Colibri the best option, even if I have to send it away to the dealer every few years (the manual just says 'several years', it's nice to hear that this may be as much as eight years) to get the battery replaced. From the documentation it appears the Volkslogger does not require a battery replacement, but the Volkslogger woud not have fit my panel and the user interface is truly abysmal. Might be worth sending to LX for the older LX20 units anyway - so they can be upgraded to the new security spec. Can't speak for the other loggers. Good idea. One other point - the battery on mine was getting weak but still functional after 8 years. 1996 model LX20 must be one of the older ones out there and still going strong. With the latest firmware I even get final glide information and a rudimentary moving map. The support from LX is outstanding and consistent. Agreed, the Colibri still seems to be the best solution on the market today. |
![]() .... The reason for the batteries is to ensure integrity of the data stored in NVRAM, so the security info will be lost when it loses all power. This is off track but the whole point of NVRAM (*Non* *Volatile* Random Access Memory) is that data will NOT be lost when you remove power. Tony V. |
![]() later model LX20's have a small hatch on them to easily replave the memory battery......without having to send the unit in to have the seals re-set tim Having done this with my LX20 it is pretty simple on this model. The battery is on a seperate screw secured pocket - as long as you ensure power continuity when you replace the battery you are away. If you are unwise enough to remove the power completely (no external power and no 9V leads to the battery connector) you will have to return the unit to the LX folks in Slovenia. The reason for the batteries is to ensure integrity of the data stored in NVRAM, so the security info will be lost when it loses all power. Might be worth sending to LX for the older LX20 units anyway - so they can be upgraded to the new security spec. Can't speak for the other loggers. One other point - the battery on mine was getting weak but still functional after 8 years. 1996 model LX20 must be one of the older ones out there and still going strong. With the latest firmware I even get final glide information and a rudimentary moving map. The support from LX is outstanding and consistent. |
Tony Verhulst wrote:
.... The reason for the batteries is to ensure integrity of the data stored in NVRAM, so the security info will be lost when it loses all power. This is off track but the whole point of NVRAM (*Non* *Volatile* Random Access Memory) is that data will NOT be lost when you remove power. Tony V. Hi Tony, I can't explain why, but take my word for it, you will have to send the unit to the factory if it loses backup power for a moment. I'm not sure whether the security code is in volatile memory or not, but even a momentary power loss means the unit reports "invalid secret key" and refuses to work. No negotiation, even though the contents of the NVRAM remain. Conversely you can run it till the battery is discharged to the point it will not boot, and there is no problem. So - if you do decide to open the little flap and replace the battery, be sure to maintain power somehow. |
X-no-archive: yes
In article , Bruce Greeff writes Tony Verhulst wrote: .... The reason for the batteries is to ensure integrity of the data stored in NVRAM, so the security info will be lost when it loses all power. This is off track but the whole point of NVRAM (*Non* *Volatile* Random Access Memory) is that data will NOT be lost when you remove power. Tony V. Hi Tony, I can't explain why, but take my word for it, you will have to send the unit to the factory if it loses backup power for a moment. I'm not sure whether the security code is in volatile memory or not, but even a momentary power loss means the unit reports "invalid secret key" and refuses to work. No negotiation, even though the contents of the NVRAM remain. Conversely you can run it till the battery is discharged to the point it will not boot, and there is no problem. So - if you do decide to open the little flap and replace the battery, be sure to maintain power somehow. The Secret Key is held in battery maintained Volatile RAM so that any opening of the case will trash the key and make the recorder insecure regardless of external power being available or not. As I recall, this applies to all FRs except early EWs. Tim Newport-Peace "Indecision is the Key to Flexibility." |
Helicopter Simulator | Ezra Bavly | Rotorcraft | 14 | October 26th 04 11:16 PM |
Pirep: Garmin GPSMAP 296 versus 295. (very long) | Jon Woellhaf | Piloting | 12 | September 4th 04 11:55 PM |
Ice meteors, climate, sceptics | Brian Sandle | General Aviation | 43 | February 24th 04 12:27 AM |
Aviation Insurance History, data, records? | cloudclimbr | General Aviation | 0 | February 17th 04 03:36 AM |
Which Logger? | tango4 | Soaring | 15 | October 5th 03 01:12 AM |
