but the ASW has a "Type Data Certificate" issued by the country where built.
I guess that would be "LBA". The ultralight Sparrowhawk does not BT "Bob Kuykendall" wrote in message om... Earlier, "BTIZ" wrote: ...how did they get that with a factory produced glider that had not passed Part 23 testing standards? Um, like an ASW-20 or a Zuni, perhaps? Bob K. |
but the ASW has a "Type Data Certificate" issued by the country where built. I guess that would be "LBA". The ultralight Sparrowhawk does not The foreign certification of the ASW-20 has no bearing on the lack of US certification of these ships. For whatever reason, Schleicher declined to seek US type certification. Individual aircraft of this type operate in the US under special airworthiness certificates as Experimental, Racing or Exhibition aircraft. I guess that the better example in this case is indeed the Zuni. It also was manufactured in series production, does not hold type certification anywhere, and all examples operate under special airworthiness certificates as Experimental, Racing or Exhibition aircraft. Bob K. |
I thought this thread seemed a bit like Deja Vu all over again:
http://groups.google.com/groups?q=g:...g.goog le.com ![]() Bob K. |
Things Wanted Cheap | MRQB | Restoration | 0 | March 18th 04 11:01 PM |
Things Wanted Cheap | MRQB | Aviation Marketplace | 0 | March 17th 04 08:46 AM |
Jet Glider Sparrowhawk | Mark James Boyd | Soaring | 31 | January 22nd 04 06:09 AM |
WANTED: Lycoming IO-320 | Matt S. | Aviation Marketplace | 0 | September 22nd 03 05:11 PM |
Conspiracy Theory’s real Script: Slave CIA, FBI change the story jews wanted to tell the media | Jean-Paul Roy | Restoration | 0 | July 12th 03 12:55 PM |
