Dear Nowhere!!
If you actually knew anything at all about this you would know that the nickname of plastic pig was actually regarding the earlier Twin Astir and NOT the completly different Twin II Acro on which thousands of people have learnt to fly. And as for the AD banning aerobatics, again if you knew what you were talking about you would know that the Twin II Acro limitations have been lifted to allow it to do the same aerobatics (including spinning) as a K13, only rolling and inverted is still currently unallowed without modification and this type of flying is definitaly only for those who have recieved training in this fine art. An Acro can be taken out in stronger winds (with care) than you would do with a K13 and the maintenance will be a lot less on a GRP 2 seater than an ageing K13. The K13 is a nice glider, I learnt to fly on one but times move on, I am sure the old pilots flying T21's and T31's reacted the same when the K13 came along. Let go of your inhibitions and move with the times or else you may stay nowhere for ever!. At 04:36 27 April 2004, Nowhere wrote: If you REALLY NEED the extra L/D for flying farther afield that MIGHT be a slight reason to consider the Acro. Other than that replacing an ASK13 with a trailerless Acro would probably be a bad move. Actually, with no trailer available you would have to be even more conservative and stay closer to the field with the Acro than the ASK13. The Acro also hasn't been given the 'plastic pig' nickname for nothing. Heavy to fly, heavy to rig and, currently, not even aerobatic thank's to an A.D. mark |
I agree with Mark. Although the k13 is a very good trainer, a Twin is
definitively a step upward which still allows a very good ab initio training. Any concrete advice depends on the exact deal, but a Twin without trailer (which can be bought second hand, too) is, hm, sub-optimal. -- Bert Willing ASW20 "TW" "Mark Davies" a écrit dans le message de ... Dear Nowhere!! If you actually knew anything at all about this you would know that the nickname of plastic pig was actually regarding the earlier Twin Astir and NOT the completly different Twin II Acro on which thousands of people have learnt to fly. And as for the AD banning aerobatics, again if you knew what you were talking about you would know that the Twin II Acro limitations have been lifted to allow it to do the same aerobatics (including spinning) as a K13, only rolling and inverted is still currently unallowed without modification and this type of flying is definitaly only for those who have recieved training in this fine art. An Acro can be taken out in stronger winds (with care) than you would do with a K13 and the maintenance will be a lot less on a GRP 2 seater than an ageing K13. The K13 is a nice glider, I learnt to fly on one but times move on, I am sure the old pilots flying T21's and T31's reacted the same when the K13 came along. Let go of your inhibitions and move with the times or else you may stay nowhere for ever!. At 04:36 27 April 2004, Nowhere wrote: If you REALLY NEED the extra L/D for flying farther afield that MIGHT be a slight reason to consider the Acro. Other than that replacing an ASK13 with a trailerless Acro would probably be a bad move. Actually, with no trailer available you would have to be even more conservative and stay closer to the field with the Acro than the ASK13. The Acro also hasn't been given the 'plastic pig' nickname for nothing. Heavy to fly, heavy to rig and, currently, not even aerobatic thank's to an A.D. mark |
Mark Davies wrote in message
If you actually knew anything at all about this you would know that the nickname of plastic pig was actually regarding the earlier Twin Astir and NOT the completly different Twin II Acro on which thousands of people have learnt to fly. Well actually my club has BOTH a Twin II Acro and a Twin Astir and, with many hours in both, I find the Astir to be much nicer to fly! The ailerons on the Astir, though just as heavy as the Acro, actually ROLL the aircraft and the spoilers don't snatch the way they do on the Acro. Admittedly the back seat on the Acro is a huge improvement on the Astir. And as for the AD banning aerobatics, again if you knew what you were talking about you would know that the Twin II Acro limitations have been lifted to allow it to do the same aerobatics (including spinning) as a K13, only rolling and inverted is still currently unallowed without modification and this type of flying is definitaly only for those who have recieved training in this fine art. You're right about the A.D of course. It has been modified to allow these manouvers. The more advanced aerobatics it was certified for are still off limits which means that while we paid for a fully aerobatic trainer we no longer can use it as such. The point I was trying (and failing) to make was that, at the moment, the Acro wouldn't provide them any more functionality than a K13 in this area. Oddly enough, in speaking up for the Acro you made this point much clearer thans I did. As for spinning, good luck. the Acro's very docile in the stall but difficult to get a good spin out of. Let go of your inhibitions and move with the times or else you may stay nowhere for ever!. Actually I own a glass single seater and I feel the best two seater I've ever flown is the Duo Discus so I'm hardly mired in the past. I just don't like the Acro that much and don't see how this deal would be of any benefit to this club. |
Opinions on Cessna 340, 414 and 421 | john szpara | Owning | 55 | April 2nd 04 09:08 PM |
Opinions wanted | ArtKramr | Military Aviation | 65 | January 21st 04 04:15 AM |
OPINIONS: THE SOLUTION | ArtKramr | Military Aviation | 4 | January 7th 04 10:43 PM |
Rallye/Koliber AD's and opinions | R. Wubben | Owning | 2 | October 16th 03 05:39 AM |
Rallye/Koliber AD's and opinions | R. Wubben | Piloting | 2 | October 16th 03 05:39 AM |
