At 05:12 30 April 2004, Graeme Cant wrote:
'Gliders have the highest rate of midairs of all forms of hard wing aviation.' Why is that? Are glider pilots in general less capable of keeping a good lookout? In my experience no, they are not. It is because we put ourselves in a position where we are more likely to come into contact with other gliders. As a matter of course we accept the need to fly close to one another whereas the rest of the GA community and commercial sector try to stay as far apart as possible. The military do deliberately fly close to one another, is this not the reason why military aircraft have more mid-airs with each other than airliners have with each other? I have to agree that gadgets are not the answer to the problem, good lookout and situational awareness is, and the good sense to bug out if you loose that. Just assume for one minute that a device could do all that has been proposed, predict a collision with another thermalling glider. The alarm goes off and the pilot takes immediate avoiding action, that is what the device is for, and immediately puts himself in the path of another glider in the thermal who did not figure in the prediction. The cure could be worse than the disease, such a device has the potential of causing the very event it seeks to prevent. Remember you are never alone in a thermal for long, if the lift is good others will want to share it, you only have to look up at the sky a few minutes before the gate opens at a comp when there is only one good thermal to see what I mean. Can you imagine the carnage if they all start to react to collision alarms? At least at the moment they are all doing more or less the same thing. The answer is, good lookout, good situational awareness and the ability to put safety first, press on itius second. Don't expect the other guy to get out of your way, get out of his, and if that means he has an advantage, sobeit, at least you continue to fly on intact. DAJ Whatever happened to teaching good look out and airmanship? Nothing. It's still taught and practiced as effectively, efficiently and thoroughly as it ever was - and has been for many years. And it's just as ineffective as it ever was. Are you one of those who see it as simply a problem of laziness and complacency? You're probably right but they're both endemic in human nature and won't change now. For jobs as important as this, monitoring systems designed with built-in tendencies to distraction and complacency - and with multiple duties just to top it off - are simply inadequate and always will be. All forms of training in lookout are doomed to fail because of basic human limitations. Not just optical limitations. Humans are simply bad at continuous alertness and monitoring for a very low probability threat over a long period. That's why we no longer have engineer's panels in the flight decks of large aeroplanes. There's as much or more to monitor than there always was - we've just accepted that humans don't do it well and found other solutions. Gliders have the highest rate of midairs of all forms of hard wing aviation. I'm happy with the collision threat and the things I do to minimise it and I'll go on flying gliders. If you're not happy, Dave, you need to accept that it won't be improved without electronic assistance. Isn't 50 or more years enough? Graeme Cant |
![]() Don Johnstone wrote: The answer is, good lookout, good situational awareness and the ability to put safety first, press on itius second. This doesn't sound like an answer to me. I do all those things, yet I've still come close to collisions. Don't expect the other guy to get out of your way, get out of his, and if that means he has an advantage, sobeit, at least you continue to fly on intact. I don't expect the other guy to get out of my way, but I've still come close to collisions. These have generally been contest situations involving many gliders, but not always. An effective, but not perfect, way to avoid collsions is to always fly well away from other gliders. It's not a perfect way, because you can't stop other glider from seeing you and joining you. I'm surprised people are willing to claim a technological solution is unworkable without any demonstration of it's ability. How can you say "The answer is, good lookout, good situational awareness and the ability to put safety first, press on itius second", when you have no data on the proposed solution? Wouldn't a better remark be "Try it, and show us the results?" -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
For Keith Willshaw... | robert arndt | Military Aviation | 253 | July 6th 04 05:18 AM |
Anti collision lights mods for Arrow 1968?? | Frode Berg | Piloting | 3 | May 20th 04 05:42 AM |
Anti collision light mod for Piper Arrow 1968 model? | Frode Berg | Owning | 4 | May 20th 04 05:16 AM |
New anti collision system for aircrafts, helicopters and gliders | Thierry | Owning | 10 | February 14th 04 08:36 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
