This is what it boils down to EDUCATION/TRAINING
Training pilots how to look out. How to concentrate, What the dangers are, real and perceived and potential and where these danger lurk in a particular phase of flight. We will never eliminate accidents but by education we can reduce the opportunities. Train hard fly easy as some one said! Dave At 17:00 30 April 2004, Rory O'Conor wrote: Mid Air collisions are a problem. Maybe we need to pull together more information about them. There are a number of different phases of flight during which they occur: Climbing phase (high Angle of Attack) (power planes only) Circuit phase (all planes) Aerobatics (all planes) IFR & low visibility flight (all planes) Normal flight (all planes) Thermalling (soaring planes only) We need to understand the proportion of collisions occurring in the different phases and the potential contributory factors. Road Traffic Accidents happen more often in good weather than bad. It is not entirely clear that thermal collisions happen more often in competition gaggles than when there are only two in a thermal, whatever our instincts. For the different flight phases, different factors will be more or less important and the solutions and devices to prevent collisions may be different. Personnally I would be surprised if TCAS devices could cope with resolving the trajectories of thermalling gliders other than the basic level of identifying another nearby plane. Thus I suspect that the main detection instrument in thermals remains the eyeball. In which case, every effort should be made to ensure the best use of the eyeball in thermals. There may be a role for such devices in other phases eg normal flight and IFR. The only power planes that regularly fly close together are the military and aerobatic display teams. I am sure that the Red Arrows are fitted with the instruments that they best require, but I would be most surprised if they have any electronic device warning them that they are about to hit a team-mate. I expect that they do a lot of training, have superb lookout and excellent communications. I would assume that a TCAS/GPS device will be making noises at 1 mile and probably very loud noises at 1/4 mile (1500 ft). With a typical thermalling diameter of 200-600 feet and circling period of less than 20 seconds, any normal TCAS would be screaming fit to be turned off! We are also entering the area where the margin of error for a GPS (30 ft horizontally, 100 ft vertically) is a significant issue. GPS is not accurate enough to tell which side of the highway you are driving on, nor probably to determine the correct seperation of two thermalling gliders when the pilots using their eyeballs consider that they are adequately seperated. I cannot envisage an electronic GPS device for avoiding intra-thermal collisions, assuming that the planes are going to remain in the same thermal. Rory |
![]() "Dave Martin" wrote in message ... This is what it boils down to EDUCATION/TRAINING Training pilots how to look out. How to concentrate, What the dangers are, real and perceived and potential and where these danger lurk in a particular phase of flight. We will never eliminate accidents but by education we can reduce the opportunities. Train hard fly easy as some one said! Dave At 17:00 30 April 2004, Rory O'Conor wrote: Mid Air collisions are a problem. Maybe we need to pull together more information about them. There are a number of different phases of flight during which they occur: Climbing phase (high Angle of Attack) (power planes only) Circuit phase (all planes) Aerobatics (all planes) IFR & low visibility flight (all planes) Normal flight (all planes) Thermalling (soaring planes only) We need to understand the proportion of collisions occurring in the different phases and the potential contributory factors. Road Traffic Accidents happen more often in good weather than bad. It is not entirely clear that thermal collisions happen more often in competition gaggles than when there are only two in a thermal, whatever our instincts. For the different flight phases, different factors will be more or less important and the solutions and devices to prevent collisions may be different. Personnally I would be surprised if TCAS devices could cope with resolving the trajectories of thermalling gliders other than the basic level of identifying another nearby plane. Thus I suspect that the main detection instrument in thermals remains the eyeball. In which case, every effort should be made to ensure the best use of the eyeball in thermals. There may be a role for such devices in other phases eg normal flight and IFR. The only power planes that regularly fly close together are the military and aerobatic display teams. I am sure that the Red Arrows are fitted with the instruments that they best require, but I would be most surprised if they have any electronic device warning them that they are about to hit a team-mate. I expect that they do a lot of training, have superb lookout and excellent communications. I would assume that a TCAS/GPS device will be making noises at 1 mile and probably very loud noises at 1/4 mile (1500 ft). With a typical thermalling diameter of 200-600 feet and circling period of less than 20 seconds, any normal TCAS would be screaming fit to be turned off! We are also entering the area where the margin of error for a GPS (30 ft horizontally, 100 ft vertically) is a significant issue. GPS is not accurate enough to tell which side of the highway you are driving on, nor probably to determine the correct seperation of two thermalling gliders when the pilots using their eyeballs consider that they are adequately seperated. I cannot envisage an electronic GPS device for avoiding intra-thermal collisions, assuming that the planes are going to remain in the same thermal. Rory We've trained and trained for 100 years and yet we still have collisions. The 'Mark 20 eyeball' is a good tool but it isn't the total solution. Humans just can't maintain the vigilance required. We have plenty of evidence of that both clinical and anecdotal. Bill Daniels |
We've tried "look out the window." We still have collisions. Since
human capabilities change only over evolutionary time, and training programs that encourage good use of existing capabilities have been in place for some time, we should assume that training and exhortations have achieved as much improvement as they ever will. The remaining collision risk must be reduced through some other means. The traffic pattern and thermals are two high-density traffic environments where aircraft maneuvering renders collision prediction difficult. It's not just difficult for machines, it's also difficult for pilots. During pilot training the task must be taught in several steps: 1) be aware of how many other aircraft are nearby 2) locate them 3) avoid getting close to those aircraft unless necessary 4) if proximity is necessary, watch (i.e., try to predict) the path of the other aircraft and avoid going toward the place where it is going 5) learn to anticipate possible unpredictable variations in the path of the other aircraft also and avoid going toward those areas. Level 5) is probably only required in thermals and in formation flying. When we begin thermaling, most of us have to use 3) because we're not good enough at 4) or 5). However, at the moment pilots are much better than machines at 4) and 5), while machines are much better than pilots at 1) and 2). Yet, if 1) fails, the rest is useless. The fact that machines can't do the whole job does NOT mean they can't be helpful. A machine that could inform a pilot that there are 5 other aircraft in the thermal within +/- 500 ft would be valuable to a very alert contest pilot who could account for only 4 of them. The tasks of finding the 5th, and avoiding all 5, might still have to rely on the Mark I Eyeball. Of course, pilots in gaggles know that they are in a high collision-risk situation, and they devote significant attention to seeing and avoiding other aircraft. Pilots who think they are alone in the sky devote much less mental capacity to those tasks. Insisting on "always" maintaining lookout vigilance is ill-advised: many of us have a pretty high cognitive load a high percentage of the time in flight, and if we devote too much attention to lookout we may well lose navigational or meteorological situational awareness, or even just tire ourselves out mentally, leaving ourselves vulnerable when attention is important later. This is where a machine could help, by maintaining a scan and verifying that, indeed, the collision risk is low. If that changes, the machine can alert the pilot, allowing the pilot to properly switch mental capacity to "see and avoid." In fact, this is the primary benefit of flight following during powered VFR flight, and it's no small benefit. Insisting that a technology is useless unless it can solve the whole problem makes perfection the enemy of the good. It's also, in this case, blind to the imperfection of the current technology - the Mark I Eyeball - which plenty of science has shown is, in most near-miss scenarios, far less valuable than the sheer size of the sky. |
Mike,
The FLARM concept has been painfully obvious, from a technology point of view, since the introduction of low-cost GPS. In fact, it could even have been partially implemented with LORAN, but those receivers were expensive and were never widely deployed. Unfortunately, FLARM-type collision avoidance is only going to work if it's deployed to virtually all aircraft, which would require the authorities to insist on it. This won't happen: ADS-B is the chosen approach. It seems to me that TIS-B is most likely what will first begin to provide us with the functionality we need - and actually get deployed. TIS-B (Traffic Information Service - Broadcast) is a portion of ADS-B, essentially a broadcast of the radar returns seen by ATC. At the moment it has limited coverage in the US but you can receive it - however you need to spend about $15,000 on avionics including a Mode S transponder plus a display unit designed for bigger panels than we have. Still, no doubt it will soon occur to some entrepreneur that a TIS-B receiver without all the Mode S baggage, designed for display on a PDA might well find a market (lots of Cezzna drivers think $15k is a lot of money too). |
Mike, The FLARM concept has been painfully obvious, from a technology point of view, since the introduction of low-cost GPS. In fact, it could even have been partially implemented with LORAN, but those receivers were expensive and were never widely deployed. Unfortunately, FLARM-type collision avoidance is only going to work if it's deployed to virtually all aircraft, which would require the authorities to insist on it. This won't happen: ADS-B is the chosen approach. Sort of important to this approach is "is it worth it?" and "does the solution cause more death than the problem?" Kind of like parachutes. If the added weight increases the marginal stall speed to the point it causes .001% more fatal accidents, but only saves .0092% more pilots in breakups, then it was a bad idea. Of course it's extremely unlikely anyone can prove the extra 15 pounds was the cause of fatality, right? How many added fatalities will there be because the pilot is distracted by the bleepy noise, even though the aircraft would have missed by six inches if neither pilot was aware? How many will die because of the distraction itself? This is just too hard to calculate. Huge numbers (hours of flight)multiplied by tiny estimated numbers (risk of midair) makes for a tough comparison. Now instead of risk use cost in $$$$s to implement, and the true cost vs. benefit is very difficult to estimate correctly... -- ------------+ Mark Boyd Avenal, California, USA |
In a recent mid air in the UK it was a quiet day, bright and hazy with poor
visability. There were only 3 or 4 aircraft in the air at the same time. Percieved low risk of collision so level of lookout was low? A very experienced (10,000+ hrs in gliders) was killed. |
Who are you, OscarCVox? Why the nickname?
Where do you fly? W.J. (Bill) Dean (U.K.). Remove "ic" to reply. Talgarth, Nympsfield, Mynd, formerly Lasham for over 20 years. "OscarCVox" wrote in message ... In a recent mid air in the UK it was a quiet day, bright and hazy with poor visibility. There were only 3 or 4 aircraft in the air at the same time. Perceived low risk of collision so level of lookout was low? A very experienced (10,000+ hrs in gliders) was killed. |
For Keith Willshaw... | robert arndt | Military Aviation | 253 | July 6th 04 05:18 AM |
Anti collision lights mods for Arrow 1968?? | Frode Berg | Piloting | 3 | May 20th 04 05:42 AM |
Anti collision light mod for Piper Arrow 1968 model? | Frode Berg | Owning | 4 | May 20th 04 05:16 AM |
New anti collision system for aircrafts, helicopters and gliders | Thierry | Owning | 10 | February 14th 04 08:36 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
