You cannot make a certified plane into a homebuilt.
You can move it from certified to experimental, but it will not be the same as a homebuilt and will not be treated as such. You might be better off telling us what you want to accomplish by doing this, and someone here will be able to tell you what you are up against. "Brad Mallard" wrote in message ... I know this is a popular question, but I have not seen anyone actually answer it. Can you make a Certified aircraft into a homebuilt? The only response I have gotten is "yes, but with a lot of paperwork." Is there a starting point? Brad |
I am a Private Pilot with about 100 hours. I am looking for an airplane that
I can call my own, whether it is certified, homebuilt, experimental, or ultralight. I have a Cessna 172 that is paid for right now, but I think I can build a better plane faster that will haul more for about the same money I have invested in my 172. As it is right now, I can't hardly do anything to my 172, as I am not an A&P. I talked to my local flight service station and they said, if I built at least 51% of an aircraft, then it could be classified as experimental. With experimental, as long as I have documented everything, and passed their inspection, and flew the plane for a documented 40 hours in assigned airspace, then as soon as it was classified as experimental, it would have the same freedoms as a certified aircraft. If I wen the other way, and altered an existing plane like a Cessna 172 for example, then it could be reclassified as "restricted" and I would have to contact them every single time I decided to fly. What I think I need from this group is maybe some restriction definitions for the following: Certified, homebuilt, amatuer built, experimental, restricted, and ultralight... or any other comments Brad "Dude" wrote in message ... You cannot make a certified plane into a homebuilt. You can move it from certified to experimental, but it will not be the same as a homebuilt and will not be treated as such. You might be better off telling us what you want to accomplish by doing this, and someone here will be able to tell you what you are up against. "Brad Mallard" wrote in message ... I know this is a popular question, but I have not seen anyone actually answer it. Can you make a Certified aircraft into a homebuilt? The only response I have gotten is "yes, but with a lot of paperwork." Is there a starting point? Brad |
As far as I know, there is no other way to be able to fix your own plane
than build it or be an AP. Many people get an AP to let them do their own work and pay him to check the work and sign it off. This is legal. If that is what you are looking for, you should start asking around for someone who will do that for you. The only downside is you still need certified parts. Only build a plane, if that is what you really want to do. Building a plane because you want to fly usually doesn't work out for most folks. They end up never finishing. "Brad Mallard" wrote in message ... I am a Private Pilot with about 100 hours. I am looking for an airplane that I can call my own, whether it is certified, homebuilt, experimental, or ultralight. I have a Cessna 172 that is paid for right now, but I think I can build a better plane faster that will haul more for about the same money I have invested in my 172. As it is right now, I can't hardly do anything to my 172, as I am not an A&P. I talked to my local flight service station and they said, if I built at least 51% of an aircraft, then it could be classified as experimental. With experimental, as long as I have documented everything, and passed their inspection, and flew the plane for a documented 40 hours in assigned airspace, then as soon as it was classified as experimental, it would have the same freedoms as a certified aircraft. If I wen the other way, and altered an existing plane like a Cessna 172 for example, then it could be reclassified as "restricted" and I would have to contact them every single time I decided to fly. What I think I need from this group is maybe some restriction definitions for the following: Certified, homebuilt, amatuer built, experimental, restricted, and ultralight... or any other comments Brad "Dude" wrote in message ... You cannot make a certified plane into a homebuilt. You can move it from certified to experimental, but it will not be the same as a homebuilt and will not be treated as such. You might be better off telling us what you want to accomplish by doing this, and someone here will be able to tell you what you are up against. "Brad Mallard" wrote in message ... I know this is a popular question, but I have not seen anyone actually answer it. Can you make a Certified aircraft into a homebuilt? The only response I have gotten is "yes, but with a lot of paperwork." Is there a starting point? Brad |
Dude wrote:
As far as I know, there is no other way to be able to fix your own plane than build it or be an AP. Nope, there is another way. Anybody can work on a homebuilt, even if they didn't build it. The only thing the builder gets is the option to get a certificate to do the annual condition inspections. If you're not the builder, you'll have to find an A&P (doesn't need to be an IA like a normal certificated aircraft). Many people get an AP to let them do their own work and pay him to check the work and sign it off. This is legal. Yes, this is a good idea. My mechanic doesn't charge any additional for owners helping. She does divide her customers into two groups, those who participate in the maintenance of their aircraft and those who are (in her words) "just pilots." A guy based at our field one day popped in and said he thought there was something wrong with his battery. The mechanic told him to go bring it in so it could be tested. He gave her a blank look. "Oh yeah, I forgot, you're just a pilot. Ron, go give him a hand pulling out his battery." |
As far as I know, there is no other way to be able to fix your own plane than build it or be an AP. Yes there is. Buy an amateur built experimental. The only maintenance you can't perform on it is the annual condition inspection (which can be performed by an A&P, rather than an IA). In the OP's case, if he just wants a plane that he can maintain himself, the best bet would be to sell the 172 and buy a homebuilt. John Galban=====N4BQ (PA28-180) |
Restricted is for test and R&D. You are clearly not doing R&D or
Test. Therefore you have to find some in the FAA whose has the authority to write you an 8130-? while turning a blind eye. If the plane crashes one of the first things done is a paperwork review, yours and the planes. The paper trail would lead right back to the person who wrote your ticket. And it would be clear the ticket was written improperly. The 8130-? can (but doesn't have to) have restrictions, for example, "can only fly over the water, and must take off and land from over the water". I have actually seen this. And usually there are time limits, 30 days, 60 days, etc based on the test plan you submit. You do have a test plan? I have heard of people (via this group) who have done this. But it is a bending of the rules and quite frankly anyone who a lot of time and effort in to getting a DAR ticket is not going to risk it. DARs serve at the FAA convience the ticket can be pulled at any time if the FAA says, "we don't need coverage in this area.". You probably didn't tell your local FAA office the full story when you got the 51% rule response. You are risking your investment in the plane and you could end up investing lots of time and money on a venture that could be nulled in 5 minutes if a new inspector asks a pointed question. Sell the plane and build a kit or find a reasonable AP who will let you do supervised work. It is easy to put a plane in to experimental (5 minutes), REAL TOUGH to take it back to cert'ed (could be days of DAR effort). Value of an experimental C172, probably 10 cents on the dollar. "Brad Mallard" wrote in message ... I am a Private Pilot with about 100 hours. I am looking for an airplane that I can call my own, whether it is certified, homebuilt, experimental, or ultralight. I have a Cessna 172 that is paid for right now, but I think I can build a better plane faster that will haul more for about the same money I have invested in my 172. As it is right now, I can't hardly do anything to my 172, as I am not an A&P. I talked to my local flight service station and they said, if I built at least 51% of an aircraft, then it could be classified as experimental. With experimental, as long as I have documented everything, and passed their inspection, and flew the plane for a documented 40 hours in assigned airspace, then as soon as it was classified as experimental, it would have the same freedoms as a certified aircraft. If I wen the other way, and altered an existing plane like a Cessna 172 for example, then it could be reclassified as "restricted" and I would have to contact them every single time I decided to fly. What I think I need from this group is maybe some restriction definitions for the following: Certified, homebuilt, amatuer built, experimental, restricted, and ultralight... or any other comments Brad "Dude" wrote in message ... You cannot make a certified plane into a homebuilt. You can move it from certified to experimental, but it will not be the same as a homebuilt and will not be treated as such. You might be better off telling us what you want to accomplish by doing this, and someone here will be able to tell you what you are up against. "Brad Mallard" wrote in message ... I know this is a popular question, but I have not seen anyone actually answer it. Can you make a Certified aircraft into a homebuilt? The only response I have gotten is "yes, but with a lot of paperwork." Is there a starting point? Brad |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 1st 04 02:31 PM |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | September 2nd 04 05:15 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 07:29 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 2nd 04 11:41 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
