On Tue, 02 Nov 2004 23:19:41 -0500, Bryan Martin
wrote: in article , Brad Mallard at wrote on 11/2/04 5:27 PM: What I think I need from this group is maybe some restriction definitions for the following: Certified, homebuilt, amatuer built, experimental, restricted, and ultralight... or any other comments Get a copy of the November 2004 issue of KitPlanes magazine, it has an article that does a good job of explaining these terms. It's primarily an article on the new light sport aircraft rule but it diagrams who can work on and inspect the various classifications of aircraft. Actually, the article itself is online: http://www.kitplanes.com/features/co...Revolution.pdf Figure Two does illustrate the various certification categories. Basically, you have "Normal" and "Special". Aircraft with "Special" airworthiness certificates include those in the Restricted, Limited, Primary, Experimental and Light Sport categories. You can obtain an Experimental certificate in six sub-categories. As far as I know, only two of the sub-categories have specific FAA guidance for the issuance of operating limitations: Amateur-Built and Experimental Light Sport. For the rest, the operating limitations are completely at the whim of the local Flight Standards District Office (FSDO). What it sounds like you want to do is convert a Cessna from the Normal category to the Experimental/Amateur-Built one (note that there *is* no "homebuilt" category). The only way the FAA will permit this is if you convince them that the aircraft complies with the 51% rule...in other words, that "...the major portion of which has been fabricated and assembled by persons who undertook the construction project solely for their own education or recreation." (14CFR 21.191) As has been discussed here in the past, gaining a Experimental/Amateur-Built certificate for something that started as a production aircraft is not impossible, but is very, very rare. You have to find an FAA inspector who is willing to sign off on it. Best bet is to contact your local FSDO and get an inspector to establish what he or she will require to be done to allow the recertification. In one local case, the FSDO told the interested party that he would be required to scratch-build a new fuselage. Ron Wanttaja |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 1st 04 02:31 PM |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | September 2nd 04 05:15 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 07:29 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 2nd 04 11:41 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
