Pawnee Tost 337 completed after the fall of 2003?
Old May 16th 04, 02:46 PM
Stewart Kissel
At 15:54 13 May 2004, Tim Mara wrote:
not true...........at least it is not an official FAA
policy.....
FSDO's can and most still will do field approvals......however,
some FSDO's
Tim-
If you can provide the name of a FSDO who will do field
approvals on a Restricted Pawnee, this would be a big
help.
In the mean time, it appears doing the conversion from
Restricted to Standard Certification and then going
for the 337 is the only procedure currently working.
Some of the paperwork for doing this made its way
up from Argentina. The Tost does have a STC for install
on the Pawnee in a couple of European countries, and
this helps with the US 337 process.
Old May 16th 04, 03:05 PM
Tim Mara
what you're asking for is to change the category of the aircraft, that you
would need to do by making changes if possible in the aircraft itself and
may not always be possible. If you have an aircraft that was certificated
for Spraying only, or similar then that is what it was certified to do.that
and nothing more......you'll need to work with the local FAA to see if your
aircraft can meet the standards for the standard or utility category. Once
you have the aircraft category correct to allow towing then installing the
TOST or any other glider towing system is possible, but until then....sorry,
that's a whole new bag of worms.....
tim
help.
Old May 17th 04, 12:55 AM
Sam Fly
Type Certificate # 2A10 for Restricted category and Type Certificate #
2A8 for Normal category. The Pawnee is approved for either certificate.
I addressed this problem in January 2004 with the FAA. The SSA
Government Liasion Director was supposed to address these problems.
Sam Fly
Texas Soaring Association
tim
help.
Old May 26th 04, 04:58 PM
Stewart Kissel
This Friday the Denver FSDO is going to inspect the
Pawnee at Buena Vista, Co for spray gear removal and
tank sealed. He has already seen the new Tost, radios
and transponder. He will then issue a Standard certificate
including the aforementioned additions, and no 337
will be required. Or at least that is the plan.
Type Certificate #
either certificate.
The SSA
these problems.
Sam Fly
then installing the
tim
help.
Baby Bush will be Closing Airports in California to VFR Flight Again Larry Dighera Piloting 119 March 13th 04 02:56 AM
12 Dec 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 December 12th 03 11:01 PM
15 Oct 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 October 15th 03 09:21 PM
18 Sep 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Military Aviation 0 September 19th 03 03:47 AM
04 Sep 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Military Aviation 0 September 5th 03 02:57 AM
