I purchased a PIK 20D which had top mylars. They were in good shape so
we just put some safety tape on them. The ship did not circle very well because you couldn't slow up without hearing the separation on the airfoil and feel the stall mush. I decided to put mylars on the lower surface. Internal seals seemed impossible because the ailerons and flaps have to move side ways to assemble. After Eastern Sailplane installed the lower seals the ship performed much better. I had also installed new push rod seals for the flaps and ailerons both at the root and the outboard exit.. With its new configuration I could circle much slower, about 43-45 kts with 8 degrees of flaps. Previously the ship needed to fly at 47-50 kts. I finally settled with 6 degrees as the best setting for average thermals here in Ohio. My theory was that the lack of lower seals was allowing higher pressure air to go right up through the wing escape through by pushing up the top seals and spoil the laminar flow aft of the flaps & airelons. With the lower seals being pressurized an pushed into the gap they created a much better natural seal. My thermalling was much improved and I was able to stay in a gaggle with much later glass without having to fly faster and have a larger diameter circle. Weaker thermals were usable. I finally got the performance expected. I can't remember if we used the 25 mm or the 30 mm mylar but we chose the smallest tape possible. There is considerable stress on the tape when the flaps are lowered for landing but good preparation and safety tape will do the job. I recommend you have a professional install them. We used a "Monocote" heat shrink model aircraft application iron to improve the adhesive seal where delamination was taking place in a few stops. It is a small iron with a Teflon coating. I glad you asked a question I could help with. Please e-mail me directly or call if you want to chat. REMOVE "NOSPAM" from my address to respond. culverflyer wrote: any first hand experiences? i am considering some for my 20 -- Best Regards, Chuck Lohre, Lohre & Associates, Inc., Marketing Engineering 2330 Victory Parkway, Suite 701, Cincinnati, OH 45206 Toll Free: 877-608-1736, 513-961-1174, Cell: 513-260-9025 Fax: 513-961-1192, E-mail: Marketing Handbook: http://www.lohre.com/extra/index.html |
Chuck Lohre wrote:
Internal seals seemed impossible because the ailerons and flaps have to move side ways to assemble. Hmm, it should be possible somehow since our pik was factory installed with it. /Janos |
"S" seals are possible and I've replaced them in a PIK, just make the seals
long enough to allow side movement when refitting to hinge pins, probably do not require "S" seals if Mylar's are fitted top and bottom Chris Runeckles Universal Plastics P/L "Janos Bauer" wrote in message ... Chuck Lohre wrote: Internal seals seemed impossible because the ailerons and flaps have to move side ways to assemble. Hmm, it should be possible somehow since our pik was factory installed with it. /Janos |
With the S seals would there be an advantage to have the external Mylar's?
"Chris" wrote in message . au... "S" seals are possible and I've replaced them in a PIK, just make the seals long enough to allow side movement when refitting to hinge pins, probably do not require "S" seals if Mylar's are fitted top and bottom Chris Runeckles Universal Plastics P/L "Janos Bauer" wrote in message ... Chuck Lohre wrote: Internal seals seemed impossible because the ailerons and flaps have to move side ways to assemble. Hmm, it should be possible somehow since our pik was factory installed with it. /Janos |
Of course, only empirical testing will provide an answer WRT the PIK20D,
however, positive results were achieved in the Dick Johnson Ventus 2 flight test. See part 2 http://www.ssa.org/Johnson/80-1996-06.pdf Good sealing generally yields good results. Frank Whiteley "culverflyer" wrote in message ... With the S seals would there be an advantage to have the external Mylar's? "Chris" wrote in message . au... "S" seals are possible and I've replaced them in a PIK, just make the seals long enough to allow side movement when refitting to hinge pins, probably do not require "S" seals if Mylar's are fitted top and bottom Chris Runeckles Universal Plastics P/L "Janos Bauer" wrote in message ... Chuck Lohre wrote: Internal seals seemed impossible because the ailerons and flaps have to move side ways to assemble. Hmm, it should be possible somehow since our pik was factory installed with it. /Janos |
Mylar seals installation | John W | Soaring | 2 | May 5th 04 09:03 PM |
mylar seals wing to flap/ Aileron | culverflyer | Soaring | 2 | May 5th 04 02:52 PM |
ZZ Mylar seals | Mike | Soaring | 3 | March 29th 04 03:45 PM |
mylar seals | D.A.L | Soaring | 1 | February 23rd 04 07:15 PM |
Mylar tape wing seals - effect on wing performance | Simon Waddell | Soaring | 8 | January 1st 04 03:46 PM |
