Mylar seals for PIK20D
Old May 17th 04, 06:17 AM
Janos Bauer
Chuck Lohre wrote:
Internal seals seemed impossible because the ailerons and flaps
have to move side ways to assemble.
Hmm, it should be possible somehow since our pik was factory installed
with it.
/Janos
Old May 17th 04, 12:59 PM
Chris
"S" seals are possible and I've replaced them in a PIK, just make the seals
long enough to allow side movement when refitting to hinge pins, probably do
not require "S" seals if Mylar's are fitted top and bottom
Chris Runeckles
Universal Plastics P/L
"Janos Bauer" wrote in message
with it.
/Janos
Old May 19th 04, 05:05 AM
culverflyer
With the S seals would there be an advantage to have the external Mylar's?
"Chris" wrote in message
. au...
seals
do
Chris Runeckles
with it.
/Janos
Old May 19th 04, 06:25 PM
F.L. Whiteley
Of course, only empirical testing will provide an answer WRT the PIK20D,
however, positive results were achieved in the Dick Johnson Ventus 2 flight
test. See part 2
http://www.ssa.org/Johnson/80-1996-06.pdf
Good sealing generally yields good results.
Frank Whiteley
"culverflyer" wrote in message
. au...
seals
probably
do
Chris Runeckles
installed
with it.
/Janos
Mylar seals installation John W Soaring 2 May 5th 04 09:03 PM
mylar seals wing to flap/ Aileron culverflyer Soaring 2 May 5th 04 02:52 PM
ZZ Mylar seals Mike Soaring 3 March 29th 04 03:45 PM
mylar seals D.A.L Soaring 1 February 23rd 04 07:15 PM
Mylar tape wing seals - effect on wing performance Simon Waddell Soaring 8 January 1st 04 03:46 PM
