If you are looking for a logger that calculates wind speed and
direction, the Colibri will do this and display it on the units screen. Kevin |
If you are looking for a logger and Pocket PC system with a moving map and
reachable airports highlighted on the screen, Glide Navigator II and a Cambridge 302A will automatically calculate and display wind speed and direction. The 302A offers more memory for flight logs and waypoints than any other logger. It is very nice to never have to worry about whether your logger is going to run out of memory. Good Soaring, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com "Kevin Christner" wrote in message ... If you are looking for a logger that calculates wind speed and direction, the Colibri will do this and display it on the units screen. Kevin |
"Paul Remde" wrote in message news:Tmxtc.2135$4A6.1123@attbi_s52...
If you are looking for a logger and Pocket PC system with a moving map and reachable airports highlighted on the screen, Glide Navigator II and a Cambridge 302A will automatically calculate and display wind speed and direction. The 302A offers more memory for flight logs and waypoints than any other logger. It is very nice to never have to worry about whether your logger is going to run out of memory. Of course... any PDA program can calculate wind from the groundspeed method. WinPilot, mCU, GlideNav, pStrePla, flyWithCE, free programs like GPSLOG and Soaringpilot. While having all that memory is nice, whether or not all that memory is actually useful is completley up in the Air. I have a sample rate of 4 seconds and this provides 16hrs on my colibri. Chances are, if you don't download a flight right away you dont care too much about it. The other disadvantage of the 302a that I see is that its panel mounted.... you need a laptop or PDA to get the logs. With the Colibri, Volkslogger, and SDI Posigraph, you can bring it home and use your desktop, or take it to the scorer at a contest. Kevin |
Hi Kevin,
I'm sure that some people will prefer a portable logger and some will prefer one mounted in the panel. The 302A works best when mounted in the panel, but there is no requirement that it be mounted in the panel. I flew with mine stowed behind me today in an SZD Junior. There is no need to view it in flight. I used double sized plastic tape to secure the GPS antenna to the top of the 302A. I also attached a RAM base with 1" ball so that I can mount it on the canopy in our club's ASK-21. It worked fine, but is a bit clunky. Another mounting solution would be to put it behind the instrument panel (not using a hole in the panel) - secured to another instrument. As someone else pointed out in another posting, a portable logger is not as nice for a syndicate because if someone takes it home for downloading it may not be available for the other syndicate partners when they need it. That is not a problem when it is mounted in (or behind) the instrument panel. You say the Colibri logs for 16 hours at 4 second intervals. That is pretty good - definitely acceptable. But the 302A can log for 25 hours at 1 second intervals. That makes the 3D flight replay very smooth in StrePla - I like that. Good Soaring, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com "Kevin Christner" wrote in message om... "Paul Remde" wrote in message news:Tmxtc.2135$4A6.1123@attbi_s52... If you are looking for a logger and Pocket PC system with a moving map and reachable airports highlighted on the screen, Glide Navigator II and a Cambridge 302A will automatically calculate and display wind speed and direction. The 302A offers more memory for flight logs and waypoints than any other logger. It is very nice to never have to worry about whether your logger is going to run out of memory. Of course... any PDA program can calculate wind from the groundspeed method. WinPilot, mCU, GlideNav, pStrePla, flyWithCE, free programs like GPSLOG and Soaringpilot. While having all that memory is nice, whether or not all that memory is actually useful is completley up in the Air. I have a sample rate of 4 seconds and this provides 16hrs on my colibri. Chances are, if you don't download a flight right away you dont care too much about it. The other disadvantage of the 302a that I see is that its panel mounted.... you need a laptop or PDA to get the logs. With the Colibri, Volkslogger, and SDI Posigraph, you can bring it home and use your desktop, or take it to the scorer at a contest. Kevin |
Pirep: Garmin GPSMAP 296 versus 295. (very long) | Jon Woellhaf | Piloting | 12 | September 4th 04 11:55 PM |
Cambridge Aero Explorer Fix | Guy Byars | Soaring | 8 | May 19th 04 03:04 AM |
Colibri Data Logger reviewed | TOM RENT | Soaring | 18 | April 16th 04 10:47 PM |
Ice meteors, climate, sceptics | Brian Sandle | General Aviation | 43 | February 24th 04 12:27 AM |
Updated IGC approval documents for Cambridge GNSS flight recorders | Ian Strachan | Soaring | 0 | August 27th 03 05:28 PM |
