In article , K.P. Termaat
writes For a distance flight using up to three turn points the Sporting Code says at 1.4.5.b. : "The turn points must be at least 10 kilometers apart and may be claimed once, etc." Why "10 km", why "once". Does anybody know. It was an arbitrary distance decided on by Tor Johannessen when he was in charge of Sporting Code rules some years ago. The intention was to prevent repeat use of a particular turn point. I was Sporting Code editor (under Tor) at that time and argued against it, but did not prevail. After all, it is for a distance rather than a goal flight and I would have though that if the required distance can be proved, that should be sufficient. And even for a goal flight, what is wrong with a repeat turn point as long as it is in the pre-flight declaration and the geometry of the course is correct for the type of flight concerned? However, I think that it is right that some rule prevents the use of lots of repeat legs, or even lots of legs, in wave or ridge lift. That was the purpose of the "up to three turn points". Any figure, 10km or other, is arbitrary. A slight error, say 9.9 km would lead to the whole flight being rejected whereas 10.1 km would be OK. As you say, Karel, "why?" Particularly now that free (no pre-flight turn point declaration) flying for various distance records is allowed, perhaps the whole matter of distance and goal definitions should be looked at again by IGC. For instance, where "distance" is the criteria rather than "goal", why do not free flight rules apply? And for free flights where waypoints can be selected by the pilot after flight, why is a pre-flight declaration needed at all? Just a couple of "stones into the millpond" ......... -- Ian Strachan Lasham Gliding Centre, UK Bentworth Hall West Tel: +44 1420 564 195 Bentworth, Alton Fax: +44 1420 563 140 Hampshire GU34 5LA, ENGLAND |
Hello Ian,
Thanks for your extensive reply. Quite happy with that. I have sent you a personal reply with some more details. For the discussion on ras let me reply in short again. The OO ruined a 1000 km FAI badge just a week ago being unaware of the 10 km FAI requirement. Or may be FAI did that. The flight in question was: Starting point ST 1st turnpoint A (leg of 99 km to the NE) 2nd turnpoint B (leg of 403 km to the S) 3rd turnpoint A (leg of 403 km to the N) Finishpoint FP (leg of 99 km to the SW) So a distance flight using up to three turnpoints. Total length 1004.3 km. An excellent performance flown one would say. Not to FAI however. FAI considers the return to A as a "jojo" after having flown more then 800 km to and back from B. So no 1000 km FAI badge. Of course the flight fullfils our national rules for a 1-3 tp free flight and the pilot will receive a 1000 km badge from our National Gliding Organisation for his outstanding performance. To prevent "jojo-ing" between two waypoints of a 1-3 tp flight we have in our national rule the simple statement "Each visit to a turnpoint increases the number by one". Prevents "jojo-ing" and does not destroy an excellent performance as the one described. Of cource the popular OLC recognises this flight also. Maximises the distance flown to 1012.2 km using 4 turnpoints (see OLC site). Best regards Karel NL "Ian Strachan" schreef in bericht ... In article , K.P. Termaat writes For a distance flight using up to three turn points the Sporting Code says at 1.4.5.b. : "The turn points must be at least 10 kilometers apart and may be claimed once, etc." Why "10 km", why "once". Does anybody know. It was an arbitrary distance decided on by Tor Johannessen when he was in charge of Sporting Code rules some years ago. The intention was to prevent repeat use of a particular turn point. I was Sporting Code editor (under Tor) at that time and argued against it, but did not prevail. After all, it is for a distance rather than a goal flight and I would have though that if the required distance can be proved, that should be sufficient. And even for a goal flight, what is wrong with a repeat turn point as long as it is in the pre-flight declaration and the geometry of the course is correct for the type of flight concerned? However, I think that it is right that some rule prevents the use of lots of repeat legs, or even lots of legs, in wave or ridge lift. That was the purpose of the "up to three turn points". Any figure, 10km or other, is arbitrary. A slight error, say 9.9 km would lead to the whole flight being rejected whereas 10.1 km would be OK. As you say, Karel, "why?" Particularly now that free (no pre-flight turn point declaration) flying for various distance records is allowed, perhaps the whole matter of distance and goal definitions should be looked at again by IGC. For instance, where "distance" is the criteria rather than "goal", why do not free flight rules apply? And for free flights where waypoints can be selected by the pilot after flight, why is a pre-flight declaration needed at all? Just a couple of "stones into the millpond" ......... -- Ian Strachan Lasham Gliding Centre, UK Bentworth Hall West Tel: +44 1420 564 195 Bentworth, Alton Fax: +44 1420 563 140 Hampshire GU34 5LA, ENGLAND |
I agree with you Karel.
This is surely a leftover from ancient days. We skipped that rule for our National redcords and our "Nattional OLC" (which, BTW, has been running since 1945) many years ago. At least you can say that there was a purpose in the old days because it wsa a sport in itself to find two tutnpoints close together but still 10 km apart. Not so easy to find in a forrested country like Sweden. Today with the GPS loggers you can calculate 2 TP:s with that are exactly 10 km apart........ so there is no sport in it any more. KISS!!! When Ray Lynskey flew the first 2000K flight it was not recognized as a world record, so consequently the SC was changed the following year to allow 3 TP courses. Ronalds flight is quite an achievement so why not use it as an argument for a proposal to the IGC for the 2005 meeting? We will support it! Robert Danewid Sweden K.P. Termaat wrote: Hello Ian, Thanks for your extensive reply. Quite happy with that. I have sent you a personal reply with some more details. For the discussion on ras let me reply in short again. The OO ruined a 1000 km FAI badge just a week ago being unaware of the 10 km FAI requirement. Or may be FAI did that. The flight in question was: Starting point ST 1st turnpoint A (leg of 99 km to the NE) 2nd turnpoint B (leg of 403 km to the S) 3rd turnpoint A (leg of 403 km to the N) Finishpoint FP (leg of 99 km to the SW) So a distance flight using up to three turnpoints. Total length 1004.3 km. An excellent performance flown one would say. Not to FAI however. FAI considers the return to A as a "jojo" after having flown more then 800 km to and back from B. So no 1000 km FAI badge. Of course the flight fullfils our national rules for a 1-3 tp free flight and the pilot will receive a 1000 km badge from our National Gliding Organisation for his outstanding performance. To prevent "jojo-ing" between two waypoints of a 1-3 tp flight we have in our national rule the simple statement "Each visit to a turnpoint increases the number by one". Prevents "jojo-ing" and does not destroy an excellent performance as the one described. Of cource the popular OLC recognises this flight also. Maximises the distance flown to 1012.2 km using 4 turnpoints (see OLC site). Best regards Karel NL "Ian Strachan" schreef in bericht ... In article , K.P. Termaat writes For a distance flight using up to three turn points the Sporting Code says at 1.4.5.b. : "The turn points must be at least 10 kilometers apart and may be claimed once, etc." Why "10 km", why "once". Does anybody know. It was an arbitrary distance decided on by Tor Johannessen when he was in charge of Sporting Code rules some years ago. The intention was to prevent repeat use of a particular turn point. I was Sporting Code editor (under Tor) at that time and argued against it, but did not prevail. After all, it is for a distance rather than a goal flight and I would have though that if the required distance can be proved, that should be sufficient. And even for a goal flight, what is wrong with a repeat turn point as long as it is in the pre-flight declaration and the geometry of the course is correct for the type of flight concerned? However, I think that it is right that some rule prevents the use of lots of repeat legs, or even lots of legs, in wave or ridge lift. That was the purpose of the "up to three turn points". Any figure, 10km or other, is arbitrary. A slight error, say 9.9 km would lead to the whole flight being rejected whereas 10.1 km would be OK. As you say, Karel, "why?" Particularly now that free (no pre-flight turn point declaration) flying for various distance records is allowed, perhaps the whole matter of distance and goal definitions should be looked at again by IGC. For instance, where "distance" is the criteria rather than "goal", why do not free flight rules apply? And for free flights where waypoints can be selected by the pilot after flight, why is a pre-flight declaration needed at all? Just a couple of "stones into the millpond" ......... -- Ian Strachan Lasham Gliding Centre, UK Bentworth Hall West Tel: +44 1420 564 195 Bentworth, Alton Fax: +44 1420 563 140 Hampshire GU34 5LA, ENGLAND |
In article , Robert Danewid
writes snip When Ray Lynskey flew the first 2000K flight it was not recognized as a world record, so consequently the SC was changed the following year to allow 3 TP courses. I do not think that was so, Tor Johannessen simply formulated more flexible distance rules for badges, not at that time for world records. In fact in the 1960s you could fly three legs for badge flights, sometime later for reasons unknown this was restricted but is now back. I have always thought that as long as a "straight downwind dash" is allowed for distance and goal flights, some pretty versatile rules should apply for flights with turn points, particularly those that start and finish at the same place. In long thin countries like the UK and others, the three turn point distance is particularly appropriate to keep you away from sea effects and over good soaring terrain without risking long retrieves if "sod's law" prevails and you land out at the farthest extremity of the course. I recall a Lasham pilot declaring an out-and-return to a lake (reservoir, actually) in farthest Wales, and landing just below the lake in a remote Welsh valley. Perhaps his retrieve car keys were in his pocket as well (I cannot recall), but that sort of thing convinced me decades ago of the merit of motor gliders! What DID happen, as I recall, was when the first 2000 km out-and-return was flown in New Zealand, the photo evidence rule was that "the turn point itself must appear on the photo". This was a hang-over from competitions where such a rule was introduced for the convenience of photo-assessing. But outside comps, the principle should always have been "proof of presence in the appropriate Observation Zone". The 2000k O&R was accepted after a delay "finding the turn point" on the photos, but the case was used by me and others to point out the anomaly and the requirement for the TP itself to be in the picture was dropped from the Code. The increasing use of GPS recorders also helped. Principle won over convenience, I am glad to say! Ronalds flight is quite an achievement so why not use it as an argument for a proposal to the IGC for the 2005 meeting? We will support it! Glad you and I agree for once, Robert ! I am merely a Committee chairman and could not make such a proposal to IGC, it is outside the remit of my Committee. But you Aero Club delegates can. What about my other points on declarations and free flights? -- Ian Strachan Bentworth Hall West Tel: +44 1420 564 195 Bentworth, Alton Fax: +44 1420 563 140 Hampshire GU34 5LA, ENGLAND |
Ian
I was present at the 1991 IGC meeting in Queeenstown, just a couple of months after Rays flight, which he presented at the meeting. Perhaps I was fouled again at an IGC meeting, but my impression was clearly that to fly so long tasks we needed more TP:s. We have seen all this stuff several times, I amquite sure that eventually we will have COTS loggers apporved. Do you remember when we went from marking the TP:s with ground markers to cameras? I think it is called evolution. BTW, it is more fun to debate with you Ian than to agree with you! Have nice summer. Robert Ian Strachan wrote: In article , Robert Danewid writes snip When Ray Lynskey flew the first 2000K flight it was not recognized as a world record, so consequently the SC was changed the following year to allow 3 TP courses. I do not think that was so, Tor Johannessen simply formulated more flexible distance rules for badges, not at that time for world records. In fact in the 1960s you could fly three legs for badge flights, sometime later for reasons unknown this was restricted but is now back. I have always thought that as long as a "straight downwind dash" is allowed for distance and goal flights, some pretty versatile rules should apply for flights with turn points, particularly those that start and finish at the same place. In long thin countries like the UK and others, the three turn point distance is particularly appropriate to keep you away from sea effects and over good soaring terrain without risking long retrieves if "sod's law" prevails and you land out at the farthest extremity of the course. I recall a Lasham pilot declaring an out-and-return to a lake (reservoir, actually) in farthest Wales, and landing just below the lake in a remote Welsh valley. Perhaps his retrieve car keys were in his pocket as well (I cannot recall), but that sort of thing convinced me decades ago of the merit of motor gliders! What DID happen, as I recall, was when the first 2000 km out-and-return was flown in New Zealand, the photo evidence rule was that "the turn point itself must appear on the photo". This was a hang-over from competitions where such a rule was introduced for the convenience of photo-assessing. But outside comps, the principle should always have been "proof of presence in the appropriate Observation Zone". The 2000k O&R was accepted after a delay "finding the turn point" on the photos, but the case was used by me and others to point out the anomaly and the requirement for the TP itself to be in the picture was dropped from the Code. The increasing use of GPS recorders also helped. Principle won over convenience, I am glad to say! Ronalds flight is quite an achievement so why not use it as an argument for a proposal to the IGC for the 2005 meeting? We will support it! Glad you and I agree for once, Robert ! I am merely a Committee chairman and could not make such a proposal to IGC, it is outside the remit of my Committee. But you Aero Club delegates can. What about my other points on declarations and free flights? |
Robert Danewid wrote:
We have seen all this stuff several times, I amquite sure that eventually we will have COTS loggers apporved. Do you remember when we went from marking the TP:s with ground markers to cameras? I think it is called evolution. It's really good to read such positive opinion. /Janos |
writes Ian I was present at the 1991 IGC meeting in Queeenstown, just a couple of months after Rays flight, which he presented at the meeting. Perhaps I was fouled again at an IGC meeting, but my impression was clearly that to fly so long tasks we needed more TP:s. OK, I was not at the meeting at Queenstown in New Zealand so I bow to your memory. We have seen all this stuff several times, I amquite sure that eventually we will have COTS loggers apporved. I fail to see what these issues of distance flying rules have to do with the use or otherwise of COTS GPS units. Could it be a fixation of yours, more appropriate for another thread on newsgroup r.a.s.? Anyway as I am sure that you know, I and others are working on rules that might be approved by IGC for the use of such COTS GPS units for badge flights up to Diamonds. The "up to Diamonds" IGC-approval level is currently used for the EW series of GPS flight recorders which are recorder units that need a NMEA feed from specified Garmin GPS receiver units. Do you remember when we went from marking the TP:s with ground markers to cameras? Too right, in the mid-1960s I wrote the rules for and than ran a trial of photographic evidence on behalf of the BGA at a competition at Bicester in the UK. It was successful and I drafted the first BGA rules for photographic evidence as a result. These included the use of Kodak Instamatic cameras which were at the time simple and almost glider-pilot-proof. I remember that at the Bicester trial, one guy with a 35mm camera managed to fail to load the film properly and thought that he had taken 24 or 36 pictures when in fact none were exposed because the film was not winding on. And now we have 24 satellites whizzing around giving position to 10 metres or so. Amazing! BTW, it is more fun to debate with you Ian than to agree with you! Ah, that explains it. PS: what about my other points on no need for declarations for free flights, and why not allow free flights for badge distance requirements on the basis that proven distance is just that, a distance achievement? -- Ian Strachan Bentworth Hall West Tel: +44 1420 564 195 Bentworth, Alton Fax: +44 1420 563 140 Hampshire GU34 5LA, ENGLAND |
Ian
10 km and Cots has just one thing in common. We glider pilots are so keen to discuss technical topics, that really is not significant for the survival of our beloved sport. As you, I am an engineer, but I have realized that we engineers, and there are plenty of us in gliding, just love to solve every poblem with a technical solution, even if the optimal solution is not technical. I mean, logger security, the distance between TP:s, GPS altitude or pressure saltitude etc etc, which we spend so much time on, will we get more new members if we use GPS altitude, skip the 10 km rule or allow COTS? NO...... but it is is damn fun to discuss! May be it is a bit annoying, but I support your proposals for free flight for badges. As always Ian, it is stimulating to debate with you. Robert Ian Strachan wrote: In article , Robert Danewid writes Ian I was present at the 1991 IGC meeting in Queeenstown, just a couple of months after Rays flight, which he presented at the meeting. Perhaps I was fouled again at an IGC meeting, but my impression was clearly that to fly so long tasks we needed more TP:s. OK, I was not at the meeting at Queenstown in New Zealand so I bow to your memory. We have seen all this stuff several times, I amquite sure that eventually we will have COTS loggers apporved. I fail to see what these issues of distance flying rules have to do with the use or otherwise of COTS GPS units. Could it be a fixation of yours, more appropriate for another thread on newsgroup r.a.s.? Anyway as I am sure that you know, I and others are working on rules that might be approved by IGC for the use of such COTS GPS units for badge flights up to Diamonds. The "up to Diamonds" IGC-approval level is currently used for the EW series of GPS flight recorders which are recorder units that need a NMEA feed from specified Garmin GPS receiver units. Do you remember when we went from marking the TP:s with ground markers to cameras? Too right, in the mid-1960s I wrote the rules for and than ran a trial of photographic evidence on behalf of the BGA at a competition at Bicester in the UK. It was successful and I drafted the first BGA rules for photographic evidence as a result. These included the use of Kodak Instamatic cameras which were at the time simple and almost glider-pilot-proof. I remember that at the Bicester trial, one guy with a 35mm camera managed to fail to load the film properly and thought that he had taken 24 or 36 pictures when in fact none were exposed because the film was not winding on. And now we have 24 satellites whizzing around giving position to 10 metres or so. Amazing! BTW, it is more fun to debate with you Ian than to agree with you! Ah, that explains it. PS: what about my other points on no need for declarations for free flights, and why not allow free flights for badge distance requirements on the basis that proven distance is just that, a distance achievement? |
I must say I'm soundly against using any more than 3 turnpoints for
badge performances. If there is no min distance between turnpoints and enough are used, one could claim thermalling as "distance." I flew 520km one day (according to the GPS "totals") but it was mostly just in a circle :P I think the 3TP idea and rules as they stand are quite reasonable. One can still fly an out-and-return or triangle closed course concurrently, since start and finish are NOT considered turnpoints in the rules (according to my understanding). Having them 10km apart may even add a little to safety assuming several pilots are attempting the same task and want to avoid hitting each other on the way back... Of course it's one more detail to check before attempting a task...and that IS a tiny bit annoying... In article , Ian Strachan wrote: In article , Robert Danewid writes snip When Ray Lynskey flew the first 2000K flight it was not recognized as a world record, so consequently the SC was changed the following year to allow 3 TP courses. I do not think that was so, Tor Johannessen simply formulated more flexible distance rules for badges, not at that time for world records. In fact in the 1960s you could fly three legs for badge flights, sometime later for reasons unknown this was restricted but is now back. I have always thought that as long as a "straight downwind dash" is allowed for distance and goal flights, some pretty versatile rules should apply for flights with turn points, particularly those that start and finish at the same place. In long thin countries like the UK and others, the three turn point distance is particularly appropriate to keep you away from sea effects and over good soaring terrain without risking long retrieves if "sod's law" prevails and you land out at the farthest extremity of the course. I recall a Lasham pilot declaring an out-and-return to a lake (reservoir, actually) in farthest Wales, and landing just below the lake in a remote Welsh valley. Perhaps his retrieve car keys were in his pocket as well (I cannot recall), but that sort of thing convinced me decades ago of the merit of motor gliders! What DID happen, as I recall, was when the first 2000 km out-and-return was flown in New Zealand, the photo evidence rule was that "the turn point itself must appear on the photo". This was a hang-over from competitions where such a rule was introduced for the convenience of photo-assessing. But outside comps, the principle should always have been "proof of presence in the appropriate Observation Zone". The 2000k O&R was accepted after a delay "finding the turn point" on the photos, but the case was used by me and others to point out the anomaly and the requirement for the TP itself to be in the picture was dropped from the Code. The increasing use of GPS recorders also helped. Principle won over convenience, I am glad to say! Ronalds flight is quite an achievement so why not use it as an argument for a proposal to the IGC for the 2005 meeting? We will support it! Glad you and I agree for once, Robert ! I am merely a Committee chairman and could not make such a proposal to IGC, it is outside the remit of my Committee. But you Aero Club delegates can. What about my other points on declarations and free flights? -- Ian Strachan Bentworth Hall West Tel: +44 1420 564 195 Bentworth, Alton Fax: +44 1420 563 140 Hampshire GU34 5LA, ENGLAND -- ------------+ Mark Boyd Avenal, California, USA |
Hello Mark,
FAI is right when it tries to avoid that pilots fly back and forth between two nearby waypoints to achieve a large distance claim, e.g. for the 1000 km badge. Everybody will have sympathy for this position. And three turnpoints looks o.k. to me also. So there is a rule for that in the Code. And one can say "a rule is a rule". However when the hidden effect of this rule is disastrous for an excellent and very sportif distance achievement then to my humble opinion there is something wrong with the definition of the rule. The rule now says "10 km apart and not a second time" with the aim of avoiding "jojo-ing" between nearby turnpoints. Looks o.k. at first glance. At second glance however there is a severe hidden malfunction in this rule. One can hardly say that having flown hundreds of km's and returning many hours later back to the first waypoint has anything to do with "jojo-ing". Is a claimed 'out and return' of 800 km with start and finishpoint a "jojo". Of course not. Is an 'out and return' of 800 km as part of a larger claimed distance flight a "jojo". Of course not also. So the malfunction in the FAI rule should be corrected for is the way to go I think. In fact a better rule looks very easy to me indeed. Considering the "Distance using up to three turnpoints" (1.4.5.b in the Code), what do you think of a rule like "At each visit of a turnpoint the number increases by one". Very simple and effective I think to avoid "jojo-ing" and not having the disastrous hidden effect on an excellent cross country flight of over 1000 km. Karel "Mark James Boyd" schreef in bericht news:40c107b5$1@darkstar... I must say I'm soundly against using any more than 3 turnpoints for badge performances. |
