![]() "Michael Higgins" wrote in message ... I first thought the gas strut/spring was bad, so I spent considerable time taking it out. It seems to be working OK. The gas spring is about 5.9' long and has about a 1.5' stroke. I can close it with about 20 or more pounds of force, and then it springs back to the full extended position. So it functions OK. But -- maybe the gas strut has lost some pressure and should have a higher force? Struts like that should take something like 80 pounds force to compress them, so I expect it's old. The bad news is that a weak strut won't prohibit the handle from going to the up position like you're seeing, so that's not the immediate problem. The second "strut" on the gear is an oil-filled damper, not pressurized at all. They leak over the years and also need to be replaced, but again that's not the problem you're looking at. I carefully took a mirror and flashlight and carefully inspected every linkage, rod, crack, shaft, weld, and rivet in the landing gear system for signs of damage. Everything looks normal. The only thing that looks abnormal is the angle of the arms coming off the shock/isolation mounts on the rear of the wheel well wall. Any ideas on what broke? How to fix it? Don't know. Every case of gear collapse I've heard of due to the wheel not being fully deployed was resolved without permanent damage, outside of maybe gear doors. -Dave |
I owned an LS-3, not an LS-6, but I understand there are many common
elements. My experience is the same as Dave's, below. The second strut mounted inside the gear box near the wheel is a damper, not a gas spring. The gas spring in my LS-3 was rated, as I recall, for about 90 lbs. when new and typically declined to about half of that over time. While a weak gas spring (and an old damper--look up my postings on this subject from a few years ago) can certainly contribute to a gear collapse, I don't know of any reason why you'd be more or less likely to suffer permanent damage. I, too, know of no other incidents where anything like this happened and I know of a lot of LS "self retracting" landing gears over the years (including mine on two occasions). So long as you're looking for other problems, however, the rubber shock mounts can deteriorate (again, assuming that the '3 and the '6 are similar). The bond between the rubber donut sandwiched between inner and outer steel bushings can fail over time, especially if the ship has been left assembled for extended periods, whether inside or--horrors--outside. If so, the "resting" angle/geometry of the upper struts would tend to change and might cause the kind of situation you describe. Said shock mounts were relatively easy to replace in my LS-3 (1/2 day with someone else helping me) but I don't know if the same thing is true for the LS-6. The classic indicator of a failing shock mount was that the fuselage sat somewhat lower to the ground when the ship was rigged. There was no other outward indication that anything was wrong, even after removing the old mounts (you'd have to torque them somehow and compare new to old values). Might be worth investigating if you can't find anything else. Chip Bearden "David Kinsell" wrote in message news:Kykvc.31762$IB.27403@attbi_s04... "Michael Higgins" wrote in message ... I first thought the gas strut/spring was bad, so I spent considerable time taking it out. It seems to be working OK. The gas spring is about 5.9' long and has about a 1.5' stroke. I can close it with about 20 or more pounds of force, and then it springs back to the full extended position. So it functions OK. But -- maybe the gas strut has lost some pressure and should have a higher force? Struts like that should take something like 80 pounds force to compress them, so I expect it's old. The bad news is that a weak strut won't prohibit the handle from going to the up position like you're seeing, so that's not the immediate problem. The second "strut" on the gear is an oil-filled damper, not pressurized at all. They leak over the years and also need to be replaced, but again that's not the problem you're looking at. I carefully took a mirror and flashlight and carefully inspected every linkage, rod, crack, shaft, weld, and rivet in the landing gear system for signs of damage. Everything looks normal. The only thing that looks abnormal is the angle of the arms coming off the shock/isolation mounts on the rear of the wheel well wall. Any ideas on what broke? How to fix it? Don't know. Every case of gear collapse I've heard of due to the wheel not being fully deployed was resolved without permanent damage, outside of maybe gear doors. -Dave |
Landing Gear Parts, Antique Part, EXP Airplane Auction | Bill Berle | Owning | 0 | November 24th 04 05:11 PM |
landing gear cleaning | Bob Miller | Owning | 4 | July 5th 04 09:24 PM |
Cessna landing gear legs Reserve MET! | Bill Berle | Restoration | 0 | February 22nd 04 07:50 PM |
Landing Gear Lights-Need Wiring Help | BG | Home Built | 2 | August 16th 03 11:21 PM |
Landing gear door operation | Pechs1 | Naval Aviation | 2 | July 6th 03 06:01 AM |
