Paul Bart wrote:
I do not know about the conversion process required to convert geometric and I assume the actual within the bounds of GPS error altitude, to pressure altitude. However given the assertion that the pressure altitude can differ by as much as 1000ft from the geometric altitude, does it imply that two pressure altitudes can actually differ by 2000ft? Would it not provide sufficient argument to switch to geometric altitude? Yes, this is correct. You don't have to climb as high on a cold winter day, as you would on a hot summer day, to obtain a specific pressure altitude gain. But, I suspect some (maybe most?) would say that we have always measured pressure altitude is this sport, and that we should continue doing so... Marc |
![]() "Marc Ramsey" wrote in message . com... Paul Bart wrote: However given the assertion that the pressure altitude can differ by as much as 1000ft from the geometric altitude, does it imply that two pressure altitudes can actually differ by 2000ft? Would it not provide sufficient argument to switch to geometric altitude? Yes, this is correct. You don't have to climb as high on a cold winter day, as you would on a hot summer day, to obtain a specific pressure altitude gain. But, I suspect some (maybe most?) would say that we have always measured pressure altitude is this sport, and that we should continue doing so... Marc Hi Marc Thanks for your reply. Given the budding status of my gliding career, this is not likely to be an issue for me any time soon ![]() can *potentially* reduce an error, by up to 1000 ft it should be seriously considered. I wonder if the resistance to change is mainly due to the high average age of the gliding fraternity? Paul |
On Thu, 03 Jun 2004 13:52:29 GMT, "Paul Bart"
wrote: "Marc Ramsey" wrote in message .com... Paul Bart wrote: However given the assertion that the pressure altitude can differ by as much as 1000ft from the geometric altitude, does it imply that two pressure altitudes can actually differ by 2000ft? Would it not provide sufficient argument to switch to geometric altitude? Yes, this is correct. You don't have to climb as high on a cold winter day, as you would on a hot summer day, to obtain a specific pressure altitude gain. But, I suspect some (maybe most?) would say that we have always measured pressure altitude is this sport, and that we should continue doing so... Marc Hi Marc Thanks for your reply. Given the budding status of my gliding career, this is not likely to be an issue for me any time soon ![]() can *potentially* reduce an error, by up to 1000 ft it should be seriously considered. I wonder if the resistance to change is mainly due to the high average age of the gliding fraternity? I have a strong suspicion that climbing to a pressure altitude should present much the same difficulty regardless of which way it differs from the geometric altitude, but climbing to a geometric altitude will get easier as the pressure (and hence pressure altitude) rises. Unless I'm much mistaken, this could be used as an argument for retaining the pressure altitude for badges. What have I missed or misunderstood here? -- martin@ : Martin Gregorie gregorie : Harlow, UK demon : co : Zappa fan & glider pilot uk : |
Paul Bart wrote:
"Marc Ramsey" wrote in message Yes, this is correct. You don't have to climb as high on a cold winter day, as you would on a hot summer day, to obtain a specific pressure altitude gain. But, I suspect some (maybe most?) would say that we have always measured pressure altitude is this sport, and that we should continue doing so... Thanks for your reply. Given the budding status of my gliding career, this is not likely to be an issue for me any time soon ![]() can *potentially* reduce an error, by up to 1000 ft it should be seriously considered. But, using GPS altitude only reduces the error if we were measuring geometric altitude. Using GPS altitude under the present rules would *increase* the error, because we are presently measuring pressure altitude. I wonder if the resistance to change is mainly due to the high average age of the gliding fraternity? I'm not going to touch that one... Marc |
"Paul Bart" wrote in message news:x2Gvc.4102
however given that GPS can *potentially* reduce an error, by up to 1000 ft it should be seriously considered. I wonder if the resistance to change is mainly due to the high average age of the gliding fraternity? Paul You seem to have missed the frequently stated point that the difference is not an error. An error free measurement of pressure altitude will not be equal to an error free gps (geometric) altitude except under rare conditions. Recognition of this fact may have something to do with age, but the real issues are recognizing what is to be measured, why it is being measured, and then determining whether it is reasonable to change to measuring something else. Andy |
![]() "Andy Durbin" wrote in message om... "Paul Bart" wrote in message news:x2Gvc.4102 however given that GPS can *potentially* reduce an error, by up to 1000 ft it should be seriously considered. I wonder if the resistance to change is mainly due to the high average age of the gliding fraternity? Paul You seem to have missed the frequently stated point that the difference is not an error. An error free measurement of pressure altitude will not be equal to an error free gps (geometric) altitude except under rare conditions. No I did not. You are correct, I have incorrectly used the word error if one considers it's meaning in a relation to the output of the measuring device, however that was not my intention. Recognition of this fact may have something to do with age, but the real issues are recognizing what is to be measured, Height above ground I would have thought. If I understand the preceding discussion correctly, pressure altitude was used because there were no other viable options, not because it was a good measure of height above ground. why it is being measured, To either establish benchmark, or to fulfill some requirements. For each of these I would rather know the actual distance above ground, not a measure that depends on prevailing meteorological conditions. Unless, of course, you consider Martin's observation, that the effort to climb to a particular pressure altitude takes about the same effort regardless of the geometric altitude and also assuming that it is the effort that is important, rather then the actual height above ground. and then determining whether it is reasonable to change to measuring something else. Thank you for your observation. Paul |
"Paul Bart" wrote in message ...
Recognition of this fact may have something to do with age, but the real issues are recognizing what is to be measured, Height above ground I would have thought. If I understand the preceding discussion correctly, pressure altitude was used because there were no other viable options, not because it was a good measure of height above ground. Without any effort I can identify 3 different measurements that are curently derived from pressure based barographs and flight recorders. They a continuity of flight altitude gained following a low point absolute altitude achieved Height above ground is not a parameter that is used for any badge, award, or record as far as I know. Please don't interpret my reply as being an objection to COTS GPS. If ever there was an opportunity to change the world from pressure altitude to GPS altitude it was when RVSM was introduced. But no, many aircraft faced expensive air data system retrofits because the system was too enrenched in barometric altimetry. Andy |
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk | Jehad Internet | Military Aviation | 0 | February 7th 04 04:24 AM |
