10 km's apart
Old June 2nd 04, 10:14 PM
Robert Danewid
I agree with you Karel.
This is surely a leftover from ancient days. We skipped that rule for
our National redcords and our "Nattional OLC" (which, BTW, has been
running since 1945) many years ago.
At least you can say that there was a purpose in the old days because it
wsa a sport in itself to find two tutnpoints close together but still 10
km apart. Not so easy to find in a forrested country like Sweden. Today
with the GPS loggers you can calculate 2 TP:s with that are exactly 10
km apart........ so there is no sport in it any more. KISS!!!
When Ray Lynskey flew the first 2000K flight it was not recognized as a
world record, so consequently the SC was changed the following year to
allow 3 TP courses.
Ronalds flight is quite an achievement so why not use it as an argument
for a proposal to the IGC for the 2005 meeting? We will support it!
Robert Danewid
Sweden
K.P. Termaat wrote:
Hello Ian,
Thanks for your extensive reply. Quite happy with that.
I have sent you a personal reply with some more details.
For the discussion on ras let me reply in short again.
The OO ruined a 1000 km FAI badge just a week ago being unaware of the 10
km FAI requirement. Or may be FAI did that.
The flight in question was:
Starting point ST
1st turnpoint A (leg of 99 km to the NE)
2nd turnpoint B (leg of 403 km to the S)
3rd turnpoint A (leg of 403 km to the N)
Finishpoint FP (leg of 99 km to the SW)
So a distance flight using up to three turnpoints. Total length 1004.3 km.
An excellent performance flown one would say. Not to FAI however. FAI
considers the return to A as a "jojo" after having flown more then 800 km to
and back from B. So no 1000 km FAI badge.
Of course the flight fullfils our national rules for a 1-3 tp free flight
and the pilot will receive a 1000 km badge from our National Gliding
Organisation for his outstanding performance.
To prevent "jojo-ing" between two waypoints of a 1-3 tp flight we have in
our national rule the simple statement "Each visit to a turnpoint increases
the number by one". Prevents "jojo-ing" and does not destroy an excellent
performance as the one described.
Of cource the popular OLC recognises this flight also. Maximises the
distance flown to 1012.2 km using 4 turnpoints (see OLC site).
Best regards
Karel NL
"Ian Strachan" schreef in bericht
In article , K.P. Termaat
writes
For a distance flight using up to three turn points the Sporting Code
says
at 1.4.5.b. : "The turn points must be at least 10 kilometers apart and
may
be claimed once, etc."
Why "10 km", why "once". Does anybody know.
It was an arbitrary distance decided on by Tor Johannessen when he was
in charge of Sporting Code rules some years ago. The intention was to
prevent repeat use of a particular turn point. I was Sporting Code
editor (under Tor) at that time and argued against it, but did not
prevail.
After all, it is for a distance rather than a goal flight and I would
have though that if the required distance can be proved, that should be
sufficient. And even for a goal flight, what is wrong with a repeat
turn point as long as it is in the pre-flight declaration and the
geometry of the course is correct for the type of flight concerned?
However, I think that it is right that some rule prevents the use of
lots of repeat legs, or even lots of legs, in wave or ridge lift. That
was the purpose of the "up to three turn points".
Any figure, 10km or other, is arbitrary. A slight error, say 9.9 km
would lead to the whole flight being rejected whereas 10.1 km would be
OK. As you say, Karel, "why?"
Particularly now that free (no pre-flight turn point declaration) flying
for various distance records is allowed, perhaps the whole matter of
distance and goal definitions should be looked at again by IGC. For
instance, where "distance" is the criteria rather than "goal", why do
not free flight rules apply? And for free flights where waypoints can
be selected by the pilot after flight, why is a pre-flight declaration
needed at all?
Just a couple of "stones into the millpond" .........
Ian Strachan
Lasham Gliding Centre, UK
Bentworth Hall West
Tel: +44 1420 564 195 Bentworth, Alton
Fax: +44 1420 563 140 Hampshire GU34 5LA, ENGLAND
Old June 4th 04, 02:25 PM
Ian Strachan
In article , Robert Danewid
writes
snip
allow 3 TP courses.
I do not think that was so, Tor Johannessen simply formulated more
flexible distance rules for badges, not at that time for world records.
In fact in the 1960s you could fly three legs for badge flights,
sometime later for reasons unknown this was restricted but is now back.
I have always thought that as long as a "straight downwind dash" is
allowed for distance and goal flights, some pretty versatile rules
should apply for flights with turn points, particularly those that start
and finish at the same place. In long thin countries like the UK and
others, the three turn point distance is particularly appropriate to
keep you away from sea effects and over good soaring terrain without
risking long retrieves if "sod's law" prevails and you land out at the
farthest extremity of the course. I recall a Lasham pilot declaring an
out-and-return to a lake (reservoir, actually) in farthest Wales, and
landing just below the lake in a remote Welsh valley. Perhaps his
retrieve car keys were in his pocket as well (I cannot recall), but that
sort of thing convinced me decades ago of the merit of motor gliders!
What DID happen, as I recall, was when the first 2000 km out-and-return
was flown in New Zealand, the photo evidence rule was that "the turn
point itself must appear on the photo". This was a hang-over from
competitions where such a rule was introduced for the convenience of
photo-assessing. But outside comps, the principle should always have
been "proof of presence in the appropriate Observation Zone". The 2000k
O&R was accepted after a delay "finding the turn point" on the photos,
but the case was used by me and others to point out the anomaly and the
requirement for the TP itself to be in the picture was dropped from the
Code. The increasing use of GPS recorders also helped. Principle won
over convenience, I am glad to say!
Glad you and I agree for once, Robert ! I am merely a Committee
chairman and could not make such a proposal to IGC, it is outside the
remit of my Committee. But you Aero Club delegates can. What about my
other points on declarations and free flights?
Ian Strachan
Bentworth Hall West
Old June 4th 04, 06:37 PM
Robert Danewid
Ian
I was present at the 1991 IGC meeting in Queeenstown, just a couple of
months after Rays flight, which he presented at the meeting. Perhaps I
was fouled again at an IGC meeting, but my impression was clearly that
to fly so long tasks we needed more TP:s.
We have seen all this stuff several times, I amquite sure that
eventually we will have COTS loggers apporved. Do you remember when we
went from marking the TP:s with ground markers to cameras? I think it is
called evolution.
BTW, it is more fun to debate with you Ian than to agree with you!
Have nice summer.
Robert
writes
snip
a world record, so consequently the SC was changed the following year
to allow 3 TP courses.
argument for a proposal to the IGC for the 2005 meeting? We will
support it!
Old June 4th 04, 08:06 PM
Janos Bauer
called evolution.
It's really good to read such positive opinion.
/Janos
Old June 4th 04, 11:32 PM
Ian Strachan
writes
Ian
OK, I was not at the meeting at Queenstown in New Zealand so I bow to
your memory.
I fail to see what these issues of distance flying rules have to do with
the use or otherwise of COTS GPS units.
Could it be a fixation of yours, more appropriate for another thread on
newsgroup r.a.s.? Anyway as I am sure that you know, I and others are
working on rules that might be approved by IGC for the use of such COTS
GPS units for badge flights up to Diamonds. The "up to Diamonds"
IGC-approval level is currently used for the EW series of GPS flight
recorders which are recorder units that need a NMEA feed from specified
Garmin GPS receiver units.
Do you remember when we went from marking the TP:s with ground markers
to cameras?
Too right, in the mid-1960s I wrote the rules for and than ran a trial
of photographic evidence on behalf of the BGA at a competition at
Bicester in the UK. It was successful and I drafted the first BGA rules
for photographic evidence as a result. These included the use of Kodak
Instamatic cameras which were at the time simple and almost
glider-pilot-proof. I remember that at the Bicester trial, one guy with
a 35mm camera managed to fail to load the film properly and thought that
he had taken 24 or 36 pictures when in fact none were exposed because
the film was not winding on. And now we have 24 satellites whizzing
around giving position to 10 metres or so. Amazing!
Ah, that explains it.
PS: what about my other points on no need for declarations for free
flights, and why not allow free flights for badge distance requirements
on the basis that proven distance is just that, a distance achievement?
Ian Strachan
Bentworth Hall West
Old June 5th 04, 08:41 PM
Robert Danewid
Ian
10 km and Cots has just one thing in common. We glider pilots are so
keen to discuss technical topics, that really is not significant for the
survival of our beloved sport. As you, I am an engineer, but I have
realized that we engineers, and there are plenty of us in gliding, just
love to solve every poblem with a technical solution, even if the
optimal solution is not technical.
I mean, logger security, the distance between TP:s, GPS altitude or
pressure saltitude etc etc, which we spend so much time on, will we get
more new members if we use GPS altitude, skip the 10 km rule or allow COTS?
NO...... but it is is damn fun to discuss!
May be it is a bit annoying, but I support your proposals for free
flight for badges.
As always Ian, it is stimulating to debate with you.
Robert
writes
Ian
your memory.
to cameras?
Old June 5th 04, 11:55 PM
Ian Strachan
writes
snip
I support your proposals for free flight for badges.
OK, you national delegates that can make proposals to IGC, go for it!
I am quite humbled by what you say. But debate is not as good as action
and decisions that enrich our sport.
Ian Strachan
Bentworth Hall West
Old June 8th 04, 07:37 AM
Mark James Boyd
Oh, I disagree. Allowing GPS altitude and COTS would have
given several pilots I know a lot more to talk about
to their friends after several flights, and some buttons and
pins to show off, and got them interacting with SSA for their
badges. Things that make soaring, and the recognition of
soaring achievements easier, help the sport. Maybe not in the
quick way of making droves of new members apply, but anything
that makes a part of aviation even marginally easier (nosewheel
vs. tailwheel is another example) does have some effect, though
it be hard to determine.
Mark Boyd
Avenal, California, USA
Old June 8th 04, 06:09 PM
Jack
Mark James Boyd wrote:
...anything that makes a part of aviation even marginally easier
(nosewheel vs. tailwheel is another example) does have some effect....
Now you've done it!
Nosewheels have definitely lowered the quality of the powered aviation
experience -- roughly to the same degree that rational competition and logging
rules _would_ do for the sport of soaring.
Jack
Old June 5th 04, 01:37 AM
Mark James Boyd
I must say I'm soundly against using any more than 3 turnpoints for
badge performances. If there is no min distance between turnpoints
and enough are used, one could claim thermalling as "distance."
I flew 520km one day (according to the GPS "totals") but it
was mostly just in a circle :P
I think the 3TP idea and rules as they stand are quite reasonable.
One can still fly an out-and-return or triangle closed course
concurrently, since start and finish are NOT considered turnpoints
in the rules (according to my understanding). Having them 10km apart
may even add a little to safety assuming several pilots are attempting
the same task and want to avoid hitting each other on the way
back...
Of course it's one more detail to check before attempting a task...and
that IS a tiny bit annoying...
writes
snip
allow 3 TP courses.
Ian Strachan
Bentworth Hall West
Mark Boyd
