Glider vs. Power Pattern Bank Angle?
Old June 12th 04, 03:13 AM
Vaughn
"John H. Campbell" wrote in message
whereas in gliders we're taught to bank at about 45 degrees or so.
I don't think so. A "medium" turn of 30 deg. works well (gliders are
typically most roll stable near this value), is first introduced, best
rehearsed, most common (it's the famous optimum bank for "standard"
thermals), easiest to perform (Laws of Learning REPEIR, Levels of Learning
RUAC...) and gives the option to go both to a "shallow" bank of 15 deg. or a
"steep" bank of 45 deg. to adjust turn radius in progress if necessary
(maintaining good coordination and speed control) without going (at low
altitudes no less) near the parachute-wearing limit of 60 deg. or the
"abrupt..." condition of aerobatic flight. The FAA PTS does not recommend
any particular bank angle for the Landing Task, but it does define a Steep
turn Task in the Performance Maneuver Area of Operation as 45 +/-5 deg. If
that's your starting value for an ordinary turn in the pattern, how much
steeper (and more stressful) are you planning to go if your path is going
past the line of the runway?
Thanks for this, I was starting to think I had been taught (and been
teaching) wrong.
Vaughn
Glider power systems Bill Daniels Soaring 13 May 6th 04 10:53 PM
Winch Experts wanted Ulrich Neumann Soaring 117 April 5th 04 06:52 AM
Restricting Glider Ops at Public Arpt. rjciii Soaring 36 August 25th 03 04:50 PM
