Newbie seeking advice
Old June 13th 04, 01:04 AM
Bill Daniels
When I read Fred's report of tail separation, my first thought was
pre-existing damage from a tail dolly that clamped the tail boom too
tightly. The hard landing/poor repair scenario works too.
Bill Daniels
"Gldcomp" wrote in message
. com...
Like I said, accidents like this are extremely rare.
If we look at the history of your old Open Cirrus, it probably had
previous
damage history.
It wouldn't be a surprise if it had previously severed the tailcone in a
groundloop during an outlanding.
I know a few cases similar to yours, and all could be traced back to a
previous damage that was hidden and not well repaired.
Still, a rare event, and like I said, it is NOT the reason we wear a
parachute.
Airplanes break up in flight more often than gliders and power
pilots/passengers are not required to wear a parachute.
If we respect our flight envelopes, gliders don't break up in flight.
They are certified aircraft and are designed to withstand severe forces,
as
long as we respect their limits.
"f.blair" wrote in message
news:27Kyc.16387$2i5.5757@attbi_s52...
I beg to differ with this last post. In a contest flight south of
Littlefield, TX in 1988, the tail section of my Open Cirrus broke just
in
front of the horizontal stabilizer. At the nose of the glider went down
with no response from the stick, I began to unbuckle. As the glider
went
inverted, I rolled out and successfully reached the ground with the help
of
my big round parachute. I had encountered some severe turbulence, that
in
later discussions with Dick Johnson, he decided must have been some type
of
horizontal, rotor type cloud. I was encountering severe updrafts then
severe downdrafts. The whole glider was going up then down, not just
nose. I was basically just holding on waiting for it to stop. Went
through
about 5-6 cycles of up then down, then it got real quiet and the nose
started down and that was when I realized that the control stick did
nothing, so I got out. The boom was broken, but the tail was attached
by
cables and a push rod. I watched it land in the field next to me, a
smooth,
flat approach. The glider was inverted, but the tail section was
upright.
The only thing that was not bent during the landing was the T.E. probe
that
was on the front edge of the vertical stabilizer. Gliders can have
structural failures.
It is not a good idea to say that 'something' will never happen.
Still flying and loving it.
Fred Blair
Greater Houston Soaring Association
Original Post:
Forget all the "I think this", "I think that" very common to
rec.aviation.soaring.
Gliders don't fall appart in flight by themselves like ultralights and
other
crazy flying machines.
Gliders are, after all, certified aircraft.
Sure a parachute might also save you in case of structural failure,
but
vast majority of bail-outs were motivated by mid-air collisions.
I only know of structural failures leading to bail-outs in factory
test-flights and in older wooden gliders who had been previously
repaired
using unknown techniques, and end-up losing their tails, leading to
bail-outs.
Glider structural failures are extremely rare in real life outside of
these
cases.
Gliders don't break-up in flight unless they hit something.
Old June 13th 04, 05:43 PM
Finbar
Gldcomp wrote:
OF COURSE the rare bail-outs are motivated by collision.
and other
Really? Actually, midair structural failure (usually due to pilot
error) is much more common than midair collision (arguably always due
to pilot error) as a cause of fatal accidents (which is what the
following data are from). I can't think of any obvious reason why
there would be a bias making midairs more surviveable.
This is from a previous post on causes of fatal accidents.
People have done these studies often enough before, but the breakdown
of fatal accident causes is worth looking at.
I looked at 61 fatal accidents that occurred between 1990 and 2002.
12 accidents, or 20%, resulted from a stall (with or without spin) in
the landing approach.
There were 11 incidents (18%) of collision with terrain during the
in-flight phase, generally along ridgelines. 3 of these were observed
to involve stalling low above the ridgeline; most of the others were
not observed.
An astonishing 9 incidents, or 15%, resulted from in-flight structural
failures. Most involved main spar failure, usually with at least one
wing separating from the fuselage, apparently as a result of
over-stressing the aircraft in flight. 2, however, involved in-flight
control system failures; one where the control stick apparently broke
off (as I understand the report) and one where a swage on one of the
control cables failed.
5 incidents, 8%, resulted from the pilot being incapacitated by heart
attack, stroke, epileptic seizure, drug use, and one apparent
incapacitation of unknown cause (aircraft simply flew into the
ground).
Another 5 incidents resulted from spins from altitude without
recovery. These are difficult to explain, especially since some of
the pilots were highly experienced. However, one high-spin glider had
its CG clearly aft of limits.
There were 4 incidents each of
- elevator/tailplane not connected
- stall on takeoff (premature termination of tow or self-launch)
- collision with terrain while attempting to land (3 of the 4 were
landouts)
There were 2 incidents each of
- midair collision
- loss of control on takeoff
- pilot killed by wire during landing
And there was one incident in which it is clear the pilot attempted to
bail out (for reasons unknown) but was apparently incapacitated when
struck by the canopy.
Here are the things that struck me:
1. Sure enough, we have lots of landing-phase stall/spin fatalities
2. Reading between the lines a little, we probably have a very similar
number of ridge-soaring fatalities.
3. We don't talk much about overstressing the aircraft, but there's a
great deal of that going on.
4. Distraction seems to be a really big issue: if you lump the landing
phase and takeoff phase stall/spins together you get the picture.
Often (PTT, landout) the cause of the distraction is fairly obvious.
5. Sometimes it's just a day with your name on it: whether it's a
heart attack, a powerline or fence you didn't see, or a wire swage
(essentially un-inspectable) that fails. "Fate comes calling"
accidents seem to be about 20% of fatalities.
Old June 13th 04, 07:13 PM
Gldcomp
Maybe I need to clarify this in other words.
No legislative requirement was ever established to carry parachutes because
airplanes or gliders fall appart in normal flight.
This is a common beginner's instinctive fear, expecially during a recovery
from stall, that the wings will fold and they will drop down like a rock.
Some people get so stressed out and terrorized by the sensation of G's that
they will forever avoid more than 30 degrees of bank so they don't have to
tackle the Gs. There are a lot of pilots like that.
The simple truth is that airplanes and gliders don't do that, UNLESS WE FLY
OUTSIDE THE ENVELOPE (exceed VNE, G-loads, etc), or we sabotage it in some
other fashion such as an ill-executed repair, or controls not properly
connected upon assembly.
I never said one is more survivable than the other.
Notice again what I said : Structural failures is NOT the reason we are
required to wear parachutes (but of course, if they do occur, parachutes
will save the pilot just as well).
Midair Collision is the reason we are required to wear parachutes.
That's all I said.
"Finbar" wrote in message
om...
and other
not observed.
ground).
landouts)
- midair collision
Old June 13th 04, 09:33 PM
Bruce Greeff
Let's introduce some common sense here.
Things can break, collide or in other ways ruin your day. We wear parachutes in
the hope that, one day, should we need to rely on something to save our lives
from a no longer flyable glider, the parachute might do the job. Who cares what
the most common cause of failure is, when considering using a primary safety device.
Some points -
My 33 year old Schempp-hirth glider is under 3000 hours total time (+-2200 at
present)- officially a toddler given the life extensions to 12000. I wonder how
many bits of damage and out of spec things there are on her. She has led an
eventful, "competition plane" life for the first decade of flying. Then spent
years being somewhat neglected and inexpertly flown by a succession of owners
who could only afford a cheap glider. And cheap maintenance I suspect...
I maintain the airframe carefully, inspect and renew what looks tired. I have
had it serviced by the professionals, who rate it as one of the best they have
seen - but I really can't be sure there is no problem lying undetected.
Pilots make mistakes, one of the most experienced pilots I have known wrecked a
Ventus A by getting too close to a CB. He used full airbrake, undercarriage out
and nose progressively steeper. Eventually the elevator folded gracefully onto
the fin. His comment was that, as he kneeled on the seat, it struck him that it
was seven years since he had packed his chute. He wondered if it would open.
Some years ago in Germany a pilot landed after three hours in his Spaatz. The
parachute was uncomfortable, and he discarded it before launching again. Half an
hour later he executed a loop, without noticing my friend and a passenger above
him. They pulled up, but he struck their fuselage with his wingtip - inverted.
Wood and fabric wingtip against steel frame had predictable results. They
watched the Spaatz spiral down from nearly 5000' AGL. He did not survive the impact.
My Pioneer 29' tri-conical flies with me, every time - lumps and all. And yes
that does include flights over five hours. It is 18 years old and getting due
for replacement, and has only ever been open in the riggers shop - personally I
like it that way. But maybe some day I get unlucky, or do something stupid.
Maybe some day it will save my life.
That's all I said.
om...
and other
not observed.
ground).
landouts)
- midair collision
Old June 13th 04, 09:58 PM
Gldcomp
Exactly, I couldn't agree more, the parachute may save you in many different
situations.
Most of them are not the reason we are required to wear them, otherwise,
power pilots and passengers would be required to wear one too.
BTW, I've never heard of anything like this before with a glass ship :
an elevator folding gracefully onto the fin...
I've flown in front of CBs most of my flying career and never once had to
fly outside the envelope.
But that aside... an elevator folding ?? it probably was damaged before and
not well repaired.
Has this accident been listed anywhere on the Web so that we could all look
at it ?
"Bruce Greeff" wrote in message
wrecked a
undercarriage out
onto
the fin. (...................................)
because
recovery
rock.
that
to
FLY
some
That's all I said.
Old June 13th 04, 11:35 PM
Finbar
"Gldcomp" wrote in message . com...
Actually, the only legislative requirement (in the US, at least) to
carry parachutes is precisely because of the possibility of airplanes
or gliders falling apart in flight. You're right, it doesn't relate
to normal flight: it relates to flight with a bank angle exceeding 60
degrees or a pitch angle exceeding 30 degrees (nose up or down). If
only normal flight is intended, there's no legislative requirement to
carry a parachute at all.
Agreed.
Sort of circular definition: if everything is as it's supposed to be,
nothing happens that shouldn't. But what you said a few posts back
was,
"Gliders don't fall appart in flight by themselves like ultralights
and other
crazy flying machines. Gliders are, after all, certified aircraft."
The safety doesn't come from certification, nor from disparaging other
aircraft, nor from hiding behind legislation. It comes from
respecting the engineering limits of the aircraft. Fly your glider
normally, within its normal flight parameters and, if it was properly
engineered and maintained, it will not come apart in flight. This is
also true of "ultralights and other crazy flying machines," by which I
assume you're referring to Sparrowhawks and helicopters in that order
;-) Certification does have value: it establishes that the aircraft's
design and construction, and its operating limitations, conform to
established engineering practices. Many non-certificated aircraft
also conform to those practices, but you have to find another way to
be sure of that. In either case, you have to maintain and operate
them properly also. Properly engineered and maintained aircraft,
flown within their limits, won't fall apart in flight.
I didn't mean to suggest you had. I made the remark because I was
comparing fatal accident statistics. If one was more surviveable,
then my statistics would not be representative of structural failures
and midair collisions as a whole. However, I think they probably are,
in which case in-flight structural failures for any reason other than
collision are 4 - 5 TIMES more likely than in-flight structural
failures due to midair collisions.
That's all I said.
Yes, and it's not in accordance with the facts. Let's review.
1. Structural failures in flight are extremely rare, as I'm sure you'd
agree. With even more incredibly rare exceptions relating to
maintenance, they are almost always caused by operating the aircraft
outside its design limits - either in terms of airspeed or aerodynamic
acceleration loads - or by imposing excessive structural loads during
a midair collision.
2. Midair collisions account for about 1 in 5 in-flight structural
failures. The rest occur for reasons other than midair collision.
Therefore, to the extent that we need to worry about in-flight
structural failure at all, collision is not the primary thing to worry
about: operating the aircraft within its normal limits is.
3. The FAA does require parachutes for "aerobatic" maneuvers,
precisely because of the increased risk of structural failure
resulting from exceeding airspeed or aerodynamic acceleration limits.
It does not require parachutes because of midair collision risks.
4. Glider contest organizers (not legislators) require parachutes
because of the risk of midair collision in high-density thermaling
situations.
For our beginner friend, the bottom line is this:
Yes, most of us wear parachutes, and it seems like a rather
conservative but sensible safety precaution. We do it because we're
aware that soaring brings us into thermals that may have other gliders
in them, increasing the risk of midair collisions. However, this is
mostly just something to make us all feel better, because actual
midair collisions that cause the aircraft to become uncontrollable are
even more rare than the aircraft breaking up in flight for some other
reason - and that's very, very, very rare!
Old June 14th 04, 04:54 AM
tango4
Q - Do gliders 'crash', break or collide?
A- Yes
Q - Could a parachute save the pilot in some of those incidents?
A - Yes
Conclusion - Wear a 'chute!
Q - But do I have to wear a chute legally?
A - Who gives a damn! It's just the *sensible* thing to do!
Ian
"." wrote in message
om...
I went for a ride in a glider many years ago and was immediately taken
with
the whole experience. I have always wanted to fly and now have the time
to
do it as I am finished with my skydiving career. Before I sell my rigs I
wanted to ask a question. Do any of you wear pilot rigs? Before I trade
some gear for a pilot rig....what is the reality of actually getting out
of
a glider if you have a structural failure or something catastrophic? I am
a
realist and can accept the fact there are inherent risks up there believe
me, but I don't want to buy a rig if it's a mute point. Do any of you
wear
rigs? Thanks for the advice.
Old June 14th 04, 11:40 AM
Bruce Greeff
situations.
not well repaired.
Big snip
By his own admission he was so far past Vne I don't think it appropriate to
consider structural defect. The aircraft was virtually new as I understand it -
and a new design at the time. (so the crash was not reported on the internet.)
The failure mode of most elevators at speeds exceeding Vne will be downwards.
Why he flew close enough to a CB that he was unable to avoid it while remaining
inside the envelope is anybodies guess.
Old June 14th 04, 02:04 PM
Bert Willing
That doesn't make sense to me. At high speeds, the elevator produces lift so
in case of structural failure, the bits would go upwards.
Bert Willing
ASW20 "TW"
"Bruce Greeff" a écrit dans le message de
downwards.
Old June 14th 04, 11:40 PM
Gldcomp
"Bert Willing" wrote in
message ...
so
Bert Willing
ASW20 "TW"
Bert,
The elevator does produce lift, but in the opposite direction as the wings
(most of the time anyway).
Seeking advice on pilot training approach... Rob General Aviation 8 December 15th 04 12:58 AM
Midland: Seeking Advice [email protected] Piloting 8 September 29th 04 01:44 PM
Seeking Route Advice - OH -> SD -> MT -> BC Darrell Clay Piloting 0 January 28th 04 01:20 AM
Newbie seeking glider purchase advice Ted Wagner Soaring 19 January 2nd 04 07:00 PM
Newbie seeking glider purchase advice -- II Ted Wagner Soaring 11 December 26th 03 05:04 PM
