You're right - the elevator produces lift (same direction as the wings) at
low speeds, not at high speeds. Got mixed up. -- Bert Willing ASW20 "TW" "Gldcomp" a écrit dans le message de om... "Bert Willing" wrote in message ... That doesn't make sense to me. At high speeds, the elevator produces lift so in case of structural failure, the bits would go upwards. -- Bert Willing ASW20 "TW" Bert, The elevator does produce lift, but in the opposite direction as the wings (most of the time anyway). |
Bert,
It has little to do with airspeed. The position of the CG will determine the force on the elevator. "Bert Willing" wrote in message ... You're right - the elevator produces lift (same direction as the wings) at low speeds, not at high speeds. Got mixed up. -- Bert Willing ASW20 "TW" "Gldcomp" a écrit dans le message de om... "Bert Willing" wrote in message ... That doesn't make sense to me. At high speeds, the elevator produces lift so in case of structural failure, the bits would go upwards. -- Bert Willing ASW20 "TW" Bert, The elevator does produce lift, but in the opposite direction as the wings (most of the time anyway). |
Not quite correct. At high angles of attack, the elevator produces lift and
at of angle of attack, it produces negative lift. The crossover (i.e. zero lift, minimum drag) is a design criterium and is usually placed at the max L/D angle of attack. But then, this will of course be influenced by a large variation of the CG. -- Bert Willing ASW20 "TW" "Gldcomp" a écrit dans le message de . com... Bert, It has little to do with airspeed. The position of the CG will determine the force on the elevator. "Bert Willing" wrote in message ... You're right - the elevator produces lift (same direction as the wings) at low speeds, not at high speeds. Got mixed up. -- Bert Willing ASW20 "TW" "Gldcomp" a écrit dans le message de om... "Bert Willing" wrote in message ... That doesn't make sense to me. At high speeds, the elevator produces lift so in case of structural failure, the bits would go upwards. -- Bert Willing ASW20 "TW" Bert, The elevator does produce lift, but in the opposite direction as the wings (most of the time anyway). |
Bert,
I'm sorry, you are not correct or not expressing yourself correctly. I'm not expressing an oppinion here, I'm telling you how it is. The CG is by design located ahead of the Neutral Point of the glider (otherwise the glider would be uncontrollable), so, it has the overall tendency to push the nose of the glider down, since the Neutral Point is the place where all the Lift is acting. To counteract this force, the tail planes are always pushing the tail DOWN, thus keeping the forces balanced. We vary the amount of down force produced by the tail planes by moving the elevator with the stick. When we move the CG aft, we bring it closer to the Neutral Point, which reduced the required down force produced by the elevator. In extremeley aft CG situations, the tailplanes MAY IN FACT produce an overall UP force on the tail, but this is the exception, rather than the rule. The more forward the CG position, however, the more DOWN force is necessary on the tail. This is the very reason pilots try to place the CG aft in competition gliders : so that the elevator doesn't have to produce quite so much DOWN force on the tail. The result is improved climb because of this. "Bert Willing" wrote in message ... Not quite correct. At high angles of attack, the elevator produces lift and at of angle of attack, it produces negative lift. The crossover (i.e. zero lift, minimum drag) is a design criterium and is usually placed at the max L/D angle of attack. But then, this will of course be influenced by a large variation of the CG. -- Bert Willing ASW20 "TW" "Gldcomp" a écrit dans le message de . com... Bert, It has little to do with airspeed. The position of the CG will determine the force on the elevator. "Bert Willing" wrote in message ... You're right - the elevator produces lift (same direction as the wings) at low speeds, not at high speeds. Got mixed up. -- Bert Willing ASW20 "TW" "Gldcomp" a écrit dans le message de om... "Bert Willing" wrote in message ... That doesn't make sense to me. At high speeds, the elevator produces lift so in case of structural failure, the bits would go upwards. -- Bert Willing ASW20 "TW" Bert, The elevator does produce lift, but in the opposite direction as the wings (most of the time anyway). |
If you had made your statements for powered aircrafts, you would be
completely right. However, the design criterons for sailplanes are slightly different because the airfoils used are different (well, today's airfoils anyways). The forces produced by the tailplane are fixed by the pitching coefficient of the airfoil in the first place. At high angles of attack, the airfoil pitches up which has to be compensated by a lift vector on the tailplane. As you need to have the CG in front of the neutral point for stability reasons, it reduces the required lift on the tailplane as the CG moves forward. To use your words, this is not an opinion. A good textbook wood be "Concept and design of Sailplanes" by Fred Thomas (the wording of the title may vary as I just know the German title). -- Bert Willing ASW20 "TW" "Gldcomp" a écrit dans le message de . com... Bert, I'm sorry, you are not correct or not expressing yourself correctly. I'm not expressing an oppinion here, I'm telling you how it is. The CG is by design located ahead of the Neutral Point of the glider (otherwise the glider would be uncontrollable), so, it has the overall tendency to push the nose of the glider down, since the Neutral Point is the place where all the Lift is acting. To counteract this force, the tail planes are always pushing the tail DOWN, thus keeping the forces balanced. We vary the amount of down force produced by the tail planes by moving the elevator with the stick. When we move the CG aft, we bring it closer to the Neutral Point, which reduced the required down force produced by the elevator. In extremeley aft CG situations, the tailplanes MAY IN FACT produce an overall UP force on the tail, but this is the exception, rather than the rule. The more forward the CG position, however, the more DOWN force is necessary on the tail. This is the very reason pilots try to place the CG aft in competition gliders : so that the elevator doesn't have to produce quite so much DOWN force on the tail. The result is improved climb because of this. "Bert Willing" wrote in message ... Not quite correct. At high angles of attack, the elevator produces lift and at of angle of attack, it produces negative lift. The crossover (i.e. zero lift, minimum drag) is a design criterium and is usually placed at the max L/D angle of attack. But then, this will of course be influenced by a large variation of the CG. -- Bert Willing ASW20 "TW" "Gldcomp" a écrit dans le message de . com... Bert, It has little to do with airspeed. The position of the CG will determine the force on the elevator. "Bert Willing" wrote in message ... You're right - the elevator produces lift (same direction as the wings) at low speeds, not at high speeds. Got mixed up. -- Bert Willing ASW20 "TW" "Gldcomp" a écrit dans le message de om... "Bert Willing" wrote in message ... That doesn't make sense to me. At high speeds, the elevator produces lift so in case of structural failure, the bits would go upwards. -- Bert Willing ASW20 "TW" Bert, The elevator does produce lift, but in the opposite direction as the wings (most of the time anyway). |
On Wed, 16 Jun 2004 09:14:13 GMT, "Gldcomp"
wrote: Bert, I'm sorry, you are not correct or not expressing yourself correctly. I'm not expressing an oppinion here, I'm telling you how it is. Sorry to intrude, but Bert is correct. ![]() The induced drag of a low aspect-ratio horizontal stab is considerable, therefore the designer tries to minimize it at the speed of max L/D - since L/D is still the main number to characterize the performanc eof a glider, this is the number that needs to be maximized. The only case where induced drag is 0 is when the tail does not create any Cl at all. Situation at low speeds: Don't forget that the center of pressure (CP) moves forward with rising AoA, creating a nose-up momentum - and this needs to be encountered by the tail (wich is therefore creating lift at speeds below the speed of max. L/D). And vice versa. The more forward the CG position, however, the more DOWN force is necessary on the tail. This is the very reason pilots try to place the CG aft in competition gliders : so that the elevator doesn't have to produce quite so much DOWN force on the tail. The result is improved climb because of this. The aerodynamical benefit of an aft CG is the fact that the tail airfoil with upwards deflected elevator has got an extremely bad L/D due to its negative camber. Less upwards elevator deflection (due to aft CG) drastically improves the L/D of the tail. Bye Andreas |
![]() "Andreas Maurer" wrote in message ... On Wed, 16 Jun 2004 09:14:13 GMT, "Gldcomp" wrote: Sorry to intrude, but Bert is correct. ![]() The induced drag of a low aspect-ratio horizontal stab is considerable, therefore the designer tries to minimize it at the speed of max L/D - since L/D is still the main number to characterize the performanc eof a glider, this is the number that needs to be maximized. The only case where induced drag is 0 is when the tail does not create any Cl at all. Situation at low speeds: Don't forget that the center of pressure (CP) moves forward with rising AoA, creating a nose-up momentum - and this needs to be encountered by the tail (wich is therefore creating lift at speeds below the speed of max. L/D). And vice versa. Correction : The tail is generating LESS negative lift. The more forward the CG position, however, the more DOWN force is necessary on the tail. This is the very reason pilots try to place the CG aft in competition gliders : so that the elevator doesn't have to produce quite so much DOWN force on the tail. The result is improved climb because of this. The aerodynamical benefit of an aft CG is the fact that the tail airfoil with upwards deflected elevator has got an extremely bad L/D due to its negative camber. Less upwards elevator deflection (due to aft CG) drastically improves the L/D of the tail. Exactly. And this is because the tail generates less negative lift. |
As I said: get a textbook, and don't confuse powered aircraft with gliders.
-- Bert Willing ASW20 "TW" "Gldcomp" a écrit dans le message de m... "Andreas Maurer" wrote in message ... On Wed, 16 Jun 2004 09:14:13 GMT, "Gldcomp" wrote: Sorry to intrude, but Bert is correct. ![]() The induced drag of a low aspect-ratio horizontal stab is considerable, therefore the designer tries to minimize it at the speed of max L/D - since L/D is still the main number to characterize the performanc eof a glider, this is the number that needs to be maximized. The only case where induced drag is 0 is when the tail does not create any Cl at all. Situation at low speeds: Don't forget that the center of pressure (CP) moves forward with rising AoA, creating a nose-up momentum - and this needs to be encountered by the tail (wich is therefore creating lift at speeds below the speed of max. L/D). And vice versa. Correction : The tail is generating LESS negative lift. The more forward the CG position, however, the more DOWN force is necessary on the tail. This is the very reason pilots try to place the CG aft in competition gliders : so that the elevator doesn't have to produce quite so much DOWN force on the tail. The result is improved climb because of this. The aerodynamical benefit of an aft CG is the fact that the tail airfoil with upwards deflected elevator has got an extremely bad L/D due to its negative camber. Less upwards elevator deflection (due to aft CG) drastically improves the L/D of the tail. Exactly. And this is because the tail generates less negative lift. |
On Thu, 17 Jun 2004 05:12:08 GMT, "Gldcomp"
wrote: Situation at low speeds: Don't forget that the center of pressure (CP) moves forward with rising AoA, creating a nose-up momentum - and this needs to be encountered by the tail (wich is therefore creating lift at speeds below the speed of max. L/D). And vice versa. Correction : The tail is generating LESS negative lift. Nope. ![]() As Bert has been pointing out repeatedly - for a typical powered plane setup this might be correct, but not for a glider. BTW: The tail of a powered plane is also designed not to deliver any lift at the typical cruise condition of this plane (speed, wing loading, CG, density altitude). Just take a look at the AoA of the tail: AoA_tail = (AoA_wing) - (longitudinal dihedral) with longitudinal dihedral typically being 1.5 degrees. Grab one of the available airfoil simulators (e.g. http://www.mh-aerotools.de/airfoils/javafoil.htm), use a symmetrical tail airfoil with a, say, 5 degrees upwards elevator deflection, and simulate it at a typical AoA of about 5 degrees (simulating a wing AoA of 6.5 degrees for a typical thermalling situation). Voila - you'll see that that the lift vector of the tail points in the same direction as the wing's one, despite the upwards-deflected elevator. Bye Andreas |
Had a look at Amazon: The Fundamentals of Sailplane Design, Fred Thomas &
Judah Milgram -- Bert Willing ASW20 "TW" "Gldcomp" a écrit dans le message de . com... Bert, I'm sorry, you are not correct or not expressing yourself correctly. I'm not expressing an oppinion here, I'm telling you how it is. The CG is by design located ahead of the Neutral Point of the glider (otherwise the glider would be uncontrollable), so, it has the overall tendency to push the nose of the glider down, since the Neutral Point is the place where all the Lift is acting. To counteract this force, the tail planes are always pushing the tail DOWN, thus keeping the forces balanced. We vary the amount of down force produced by the tail planes by moving the elevator with the stick. When we move the CG aft, we bring it closer to the Neutral Point, which reduced the required down force produced by the elevator. In extremeley aft CG situations, the tailplanes MAY IN FACT produce an overall UP force on the tail, but this is the exception, rather than the rule. The more forward the CG position, however, the more DOWN force is necessary on the tail. This is the very reason pilots try to place the CG aft in competition gliders : so that the elevator doesn't have to produce quite so much DOWN force on the tail. The result is improved climb because of this. "Bert Willing" wrote in message ... Not quite correct. At high angles of attack, the elevator produces lift and at of angle of attack, it produces negative lift. The crossover (i.e. zero lift, minimum drag) is a design criterium and is usually placed at the max L/D angle of attack. But then, this will of course be influenced by a large variation of the CG. -- Bert Willing ASW20 "TW" "Gldcomp" a écrit dans le message de . com... Bert, It has little to do with airspeed. The position of the CG will determine the force on the elevator. "Bert Willing" wrote in message ... You're right - the elevator produces lift (same direction as the wings) at low speeds, not at high speeds. Got mixed up. -- Bert Willing ASW20 "TW" "Gldcomp" a écrit dans le message de om... "Bert Willing" wrote in message ... That doesn't make sense to me. At high speeds, the elevator produces lift so in case of structural failure, the bits would go upwards. -- Bert Willing ASW20 "TW" Bert, The elevator does produce lift, but in the opposite direction as the wings (most of the time anyway). |
Seeking advice on pilot training approach... | Rob | General Aviation | 8 | December 15th 04 12:58 AM |
Midland: Seeking Advice | [email protected] | Piloting | 8 | September 29th 04 01:44 PM |
Seeking Route Advice - OH -> SD -> MT -> BC | Darrell Clay | Piloting | 0 | January 28th 04 01:20 AM |
Newbie seeking glider purchase advice | Ted Wagner | Soaring | 19 | January 2nd 04 07:00 PM |
Newbie seeking glider purchase advice -- II | Ted Wagner | Soaring | 11 | December 26th 03 05:04 PM |
