In article , Andy
Durbin writes I had a problem downloading a log from my 302 last Sunday (June 13). Several attempts to download with utility 3UT15255 gave a transfer or communication error (don't remember which). Still didn't work after reset the PDA and power cycing the 302. A free download utility is available on the IGC GNSS web site, as it is for all types of IGC-approved GPS recorders. The program file for downloading IGC files from the Cambridge 302 is DATACAM2.exe (DATA-CAM.exe is for the legacy models 10, 20 and 25).. Try www.fai.org/gliding/software/gps/pc/cam.zip DATACAM2 works OK with my syndicate's 302 using a laptop and a RS232 9-pin connector which we have available in the glider as well as the plug to the palmtop. We have fixed a permanent RS232 cable to the back of the 302 to avoid the need to get at the back of the panel-mounted 302 unit each time that we download. We can therefore either download via the RS232 connector, or into the palmtop. Both systems work but personally I normally use an old laptop and the IGC-standard RS232 download connector. -- Ian Strachan Lasham Gliding Centre, UK |
Looking for JPI's older software to download engine monitor data to a PC | Peter R. | Piloting | 11 | February 14th 05 08:58 PM |
Anyone has the EDM700 data download software? | Jay Honeck | General Aviation | 4 | September 26th 04 06:54 PM |
Download | Thijs Wolters | Simulators | 26 | June 24th 04 03:36 PM |
FS2004 Pauses When Real World Weather Won't Download | Andrew Watson | Simulators | 1 | September 8th 03 09:08 AM |
Download GPS Track from Bendix/King handheld | Andreas Medlhammer | General Aviation | 0 | August 11th 03 02:50 PM |
