Pardon this input from an uninformed intruder to this subject, but why
couldn't birds simply sense how strong the lift is by the amount of stress it puts on their "airframe". When I pump iron, I'm all too aware of the amount of effort required. Surely birds can do the same. Ted Frost Soaring Society of Boulder The stress would only change when acceleration was present (as in entering a thermal, we use our bums for for that - transitting from an area of intense sink to and area of lesser sink: e.g. no thermal). In a steady climb the stress wouldn't change and would be the same as in normal turning flight. I suspect that Martin's observation about the birds choosing a more extreme dihedral has more to do with lack of effort than sensing the lift intensity - a high dihedral result and a high value of lateral stability, but poor efficiency of the wing. Rgds, Derrick Steed |
Can birds sense pressure changes? Maybe they have bio-varios.
I've noticed they seem to chirp, even on gloomy mornings, when I have noticed pressure rising on the altimeter or baro. It wouldn't surprise me if this was true, but I haven't heard of any studies... So I'm guessing maybe they know they are climbing from vario alone... In article , Derrick Steed wrote: Pardon this input from an uninformed intruder to this subject, but why couldn't birds simply sense how strong the lift is by the amount of stress it puts on their "airframe". When I pump iron, I'm all too aware of the amount of effort required. Surely birds can do the same. Ted Frost Soaring Society of Boulder The stress would only change when acceleration was present (as in entering a thermal, we use our bums for for that - transitting from an area of intense sink to and area of lesser sink: e.g. no thermal). In a steady climb the stress wouldn't change and would be the same as in normal turning flight. I suspect that Martin's observation about the birds choosing a more extreme dihedral has more to do with lack of effort than sensing the lift intensity - a high dihedral result and a high value of lateral stability, but poor efficiency of the wing. Rgds, Derrick Steed -- ------------+ Mark Boyd Avenal, California, USA |
Changes in Instrument Proficiency Check Requirements | Richard Kaplan | Instrument Flight Rules | 71 | June 10th 04 08:02 PM |
Kerry begins circling the drain: | Tarver Engineering | Military Aviation | 0 | February 12th 04 06:04 PM |
What determines LNAV "circling mode"? | Jack | Soaring | 11 | November 20th 03 05:15 AM |
Circling To Land On NDB-B and NDB-C | S. Ramirez | Instrument Flight Rules | 7 | July 13th 03 03:46 PM |
