IFR in motorglider?
Old July 5th 04, 10:06 PM
Mark James Boyd
In the USA:
(e) Instrument rating. No person may act as pilot in command of a civil aircraft under IFR or in weather conditions less than the minimums prescribed for VFR flight unless that person holds:
(3) For a glider, a pilot certificate with a glider category rating and an airplane instrument rating; or
Furthermo
(c) Medical certificate. (1) Except as provided for in paragraph (c)(2) of this section, a person may not act as pilot in command or in any other capacity as a required pilot flight crewmember of an aircraft, under a certificate issued to that person under this part, unless that person has a current and appropriate medical certificate that has been issued under part 67 of this chapter, or other documentation acceptable to the Administrator, which is in that person's physical possession or readily accessible in the aircraft.
(2) A person is not required to meet the requirements of paragraph (c)(1) of this section if that person --
(iii) Is holding a pilot certificate or a flight instructor certificate with a glider category rating, and is piloting or providing training in a glider, as appropriate;
It seems the answer from these two sections is
yes, as far as they go. Others have pointed out
that IFR currency and equipment requirements go beyond this.
As far as this goes, I'd guess strongly that an IPC to
get current is a good way to go. Sure one could get current
in a two seater with foggles and a safety pilot, or
maybe fly 3 hours of glider actual IFR solo every 6 months,
but in the US I'd guess the IPC would often be simpler and more
effective at meeting the reg's intention.
As far as equipment goes, there are a lot of misconceptions about
what is "required." Back during the ATC controller
strike (remember Reagan?) nobody used a transponder for anything,
just time slots and phone calls. Even in modern times
in A,B,C,D,E airspace, I personally have flown no-transponder
both VFR and IFR, with a waiver one hour before hand.
And in "G" airspace, there is no radio requirement
for IFR even, as far as I've ever seen. In
area with no altimeter setting information (the
mountains in Reno, California, for example, right Al?
the G airspace can go quite high.
I've also gotten a "cube" of area and altitude to fool around in the
clouds, in airplanes, before. Always out of the way
of other IFR traffic, and coordinated ahead of the flight,
and done to practice 180 turns from clouds in actual IFR with
students. No danger either, since the
clouds were only 2000-6000, and out away from
airways and approaches. ATC didn't care as long as there was no
possibility of traffic conflict, and we uttered those
magic words "we will maintain our own terrain
separation."
And as far as AI and DG, etc. go, my FAA examiner pointed out
that the instruments are for powered aircraft.
The POH is the limiting document for gliders
for flight instruments required for IFR as far as
I can tell (except that durned DME way up there in the FLs).
I must say, however, I've done the "needle, ball, and
airspeed" in gliders and planes in actual and
simulated, and it's some sketchy s**t if you
don't have recent practice.
But all of this is armchair wisdom (?) from me.
Carl Herold could write a book on this. We've
seen this subject enough on RAS maybe we oughta
all call him and ask him if he'd write something
up for Soaring mag... Horse's mouth is best, dontcha know...
Bob Greenblatt wrote:
On 6/29/04 2:37 PM, in article
, "cp"
Question:
Can I, a commercial & instrument rated power and glider pilot legally
fly IFR in a motorglider (which is IFR certified) if I do not have a
current medical?
Thanks!
Chuck
Good one! I would guess that the answer is yes provided the glider is
current re VOR, transponder and altimeter checks, and you have met the
instrument experience and competency requirements of 61.57.
Bob
CFI, CFII, CFIG
Bob
bobgreenblattATmsnDOTcom --fix this before responding
Mark Boyd
Avenal, California, USA
Old July 6th 04, 12:33 AM
ADP
Interesting.
14 CFR 61-3(e) takes care of the pilot but the original question pertained
to motor gliders.
AC 21 17-2(a) states:
h. Section 91.205 of the FAR. Powered gliders are considered to be powered
aircraft for the
purpose of complying with § 91.205.
91.205, of course, specifies the requirements for flying IFR.
A distinction must be made between flying IFR and flying in clouds.
While I doubt any motor glider can meet the requirements for flying IFR (and
no unpowered glider can), flying in clouds in uncontrolled airspace seems to
be a simple matter of having an instrument rating and having no day VFR
restrictions in your glider handbook or operating restrictions.
In uncontrolled airspace, you can do just about anything you want, if
properly certificated. The problem is finding uncontrolled airspace.
Allan
"Mark James Boyd" wrote in message
news:40e9c2ea$1@darkstar...
In the USA:
.......Snip.....
Old July 6th 04, 01:58 AM
Mark James Boyd
ADP wrote:
Interesting.
Goodness no. I believe unpowered gliders can and have
flown in controlled airspace, and under IFR, and quite recently and
legally in the USA. There was a recent high-altitude downwind dash
in wave over the Sierras by a savy, experienced ATP that did just
this, IIRC. Somebody who doesn't have to rush home
for dinner like I must can perhaps chime in here...
Goodness, yes. Carl Herold by secondhand info seems
to have 300 hrs + glider IMC this way. But again, I may
be deifying him rather than stating fact...best to
get his input directly I suspect...
Although a bit rare, none of this seems outside of the
realm of legality. Certainly very risky if one
chooses needle, ball, airspeed alone without
much recent experience this way, but
not illegal with certain caveats.
Personally I'd SURE want an AI too...
Mark Boyd
Old July 7th 04, 06:55 AM
ADP
Why must it be an unequivocal no?
Please site your sources.
Allan
"Tom Seim" wrote in message
om...
(Mark James Boyd) wrote in message
news:40e9f92c$1@darkstar...
ADP wrote:
I will remind you that the original post was whether it was legal to
fly said glider WITHOUT A CURRENT MEDICAL! The answer to this question
must be an unequivocal NO!
Tom
Old July 7th 04, 02:34 PM
Tom Seim
"ADP" wrote in message ...
61.23
Old July 7th 04, 05:20 PM
ADP
Where in 61.23? In fact, it says precisely the opposite.
om...
61.23
Old July 8th 04, 11:41 PM
Mark James Boyd
Aggghhh. This one comes down again to if one
thinks a motorglider is a powered aircraft.
This subject is too fuzzy for me to agree or
disagree. I'd tell you that
a) I have a medical so I don't personally care so much
b) if I didn't have a medical I might interpret
the rule to mean I can't fly in clouds with the engine on,
(but I can fly in them with it removed or stowed)
which is silly.
c) if I had a medical revoked or failed, I'd
likely not be safe to fly anything at all...
So really I guess the pilot wants to know if
he can fly a motorglider in the clouds with the motor
running with an expired medical but no
known adverse medical problems.
That's a good question for the FSDO. I dunno what they'd
say. Somebody ref'd an AC on this but the early posts in this
thread are no longer accessible. Ooops, I shoulda saved the
AC ref...
Mark Boyd
Old July 8th 04, 11:54 PM
ADP
aircraft for the purpose of complying with § 91.205.
Allan
news:40edcd7c$1@darkstar...
AC ref...
Mark Boyd
Old July 13th 04, 07:04 AM
Mark James Boyd
http://www.airweb.faa.gov/Regulatory...e_Library%5Crg
AdvisoryCircular.nsf/0/EAE91A15C5E11823862569B600563FBF?OpenDocument
You gotta paste together the link, sorry ;(
Allan
AC ref...
Mark Boyd
Mark Boyd
Motorglider and Towered Airport Steve B Soaring 23 January 13th 04 06:06 PM
Flying a motorglider without the engine? Eric Greenwell Soaring 1 September 23rd 03 05:38 AM
Latest Pipistrel Motorglider Newsletter Uploaded Michael Coates Home Built 1 September 16th 03 06:04 PM
MONI motorglider / sportplane for sale Bill Berle Soaring 7 August 2nd 03 12:05 AM
Wanted to buy - motorglider Catherine Conway Soaring 1 July 22nd 03 09:47 AM
