Circling for rodents?
Old July 7th 04, 03:44 AM
Bill Daniels
It's pretty well established that soaring birds have extremely good
eyesight. I think they just see the ground moving away when they are
climbing. Thermals also have a lot of stuff in them like insects and seeds.
The birds are probably able to see these rising at a considerable distance
There's a lot of visual cues while thermalling. If you are trying to thermal
near a mountain peak it's easy to see the glider rise at the onset of lift.
The varios will signal lift two or three seconds later.
BTW, that story about the USA hang glider team chasing buzzards and landing
next to a dead cow is really funny.
Bill Daniels
"Derrick Steed" wrote in message
It's a well known fact that birds bones are very light and filled with
holes, just like we have sinuses in our head bones. I've pondered how
birds
might sense rate of climb many times and I now hold the view that they
sense
it via the cavities in their bones - this would provide them with a very
sensitive variometer, the capacity being automatically incorporated so to
speak.
I'm also convinced that birds soar for pleasure as well as because they
might have to (e.g. Pelicans soar when they are migrating and follow
similar
climb/glide patterns to us).
I once observed a seagull from the restaurant at the top of the OMPI
building in Geneva - a seagull was already soaring near the ITU building
when suddenly another shot past the window in a fast glide headed straight
for a point below the other seagull, when it got there it pulled up into
climb underneath the other gull turning in the same direction. Obviously
his/her CSI (Chief Seagull Instructor) had made the point about proper
thermal entry.
Rgds,
Derrick Steed
Does anyone have an idea of how the birds know where to thermal? Do
they have a vario? Where is it? Where is its capacity?
Assuming they breath while thermalling, then I doubt they use their
lungs as capacity... or maybe they stop and sense the air coming out
their noses.
Just wondering...
Uri 4XGJC
(Andy Durbin) wrote
in
message
news:...
"Bill Daniels" wrote in message news:...
Most hawks circling low are looking for rodents, not lift.
Bill Daniels
But many times I have shared thermals with Hawks at high altitude.
How did they get there if not by working thermals at low altitude? I
have never been in a thermal with a Red Tailed Hawk that didn't seem
to be trying to optimize climb rate. Turkey Vultures are a different
story. They seem to be happy with any sloppy thermal technique as
long as they maintain altitude.
Andy
Old July 7th 04, 05:49 PM
CV
climbing.
Good eyesight is one thing, precision at judging distance another,
the latter basically dependent on how far apart your eyes are.
No way can they judge their climb rate based on seeing the ground
moving away.
That could be, and other visual cues as well.
CV
Old July 7th 04, 06:16 PM
Bill Daniels
C'mon, now. Binocular depth perception ends for humans at about 20 feet and
is only really useful up to arms length, yet we can still judge distance
well. Since the bird is moving, they can use dynamic field depth perception
that has nothing to do with interocular distance.
Close one eye and move your head back and forth or up and down. You will
see what I mean. Birds and other small animals are observed to move their
heads constantly to better judge distances.
Ever ride one of those glass elevators (lifts) on the outside of a tall
building? Did you notice how powerful the impression of climbing is?
I still claim that they can see themselves rise away from the ground.
Excellent vision and the experience to use it to the fullest is the likely
explanation. It's the simplest explanation and requires no internal vario.
Bill Daniels
"CV" wrote in message
news
climbing.
moving away.
distance
CV
Old July 9th 04, 06:42 PM
Robert Ehrlich
I can't believe that, except for very low heights. The elevator experience
you mention mention is for such heights, or at least when something (the
building itself) is very near.
The best processing system (e.g. the bird's brain) cannot infer anything
from missing or non significative input. In the case of climbing, the only
information on which you say they rely is the change in the apparent size
of ground features. I didn't do the computation, but I bet that the change
during one full turn is below the optical resolution of a bird's eye. In
this domain, we are better equiped than they are, our eyes are larger.
Nevertheless we can't decide if a glider or a bird is climbing when watching
them from below just by watching the change of their size during a short
time, except when they are very low. However I agree that after watching
a bird for a long time, as it changed from a beautiful thing with discernable
separate feathers at the tips to a vanishing little point in the sky, I can
say that it was climbing.
Old July 10th 04, 05:45 PM
Mike Lindsay
In article , Robert Ehrlich
On the other hand, do you think you'd be able to spot a mouse from
3000ft? No problem for some birds of prey.
Mike Lindsay
Old July 11th 04, 01:50 AM
Bill Daniels
experience
only
change
You don't look down to see height changes, you look out at an angle. You're
not looking for changes in the size of objects, you look for changes in
angles. It's just like we judge height on final approach to landing. I can
judge the strength of thermals visually up to 1000 meters or so and I bet
the birds can do a lot better.
Bill Daniels
Old July 12th 04, 07:34 PM
Robert Ehrlich
Bill Daniels
Well, the changes in (apparent) size of objets is nothing else than a change
in an angle. I agree that looking for such an angle just below the glider is
not what will maximize the change for a given height change. If your method
is by watching the change in the angle of the directions of some fixed ground
feature and the horizon, it can easily be shown that the maximum rate of change
is obtained by looking at some feature at 45 degrees below the horizon. In this
case, the change rate, in radians per climbing meter, is 1/(2*height), at 1000
meters the rate of change is of 1.7 minute per meter, in order to see a 1
degree change when climbing at 2 m/s, you have to wait 35 seconds.
Difficult but workable. I should try it in my next flight, although I think I
will not be able to perceive changes below 10 degrees, when looking at 45 degrees.
Looking toward a more horizontal direction should provide better senitivity, as
the fixed feature and the horizon are together in the visual field, but the
rate of change of the angle is much lower. When looking in the same direction
as on final approach, i.e. the direction of the 1/10 slope, the rate of change
is 1/(10*height) radians per climbing meter, 5 times lower than at 45 degrees,
you have to wait nearly 3 minutes climbing at 2 m/s to see a 1 degree change
at 1000 m.
Changes in Instrument Proficiency Check Requirements Richard Kaplan Instrument Flight Rules 71 June 10th 04 08:02 PM
Kerry begins circling the drain: Tarver Engineering Military Aviation 0 February 12th 04 06:04 PM
What determines LNAV "circling mode"? Jack Soaring 11 November 20th 03 05:15 AM
Circling To Land On NDB-B and NDB-C S. Ramirez Instrument Flight Rules 7 July 13th 03 03:46 PM
