Advice needed- 1-34 tow hook replacement
Old July 13th 04, 11:47 PM
Kurt
Default Advice needed- 1-34 tow hook replacement
A friend of mine has a 1-34 and he needs to replace the tow hook and
release arm. Question is...how? The floor is riveted in place and
access is just about impossible. There is a very small access hole in
the floorboard, but all it lets you do is see the nut on the bolt.
HELP!
Thanks
Kurt
Old July 14th 04, 12:55 AM
BTIZ
have a competent mechanic drill out the rivets... carefully.. remove the
floor.. and then pop rivet it back on
other option.. call Schweizer for advice
BT
"Kurt" wrote in message
om...
HELP!
Thanks
Kurt
Old July 15th 04, 05:51 PM
Roy Bourgeois
Sounds like this 1-34 has had it's nose cone screws & junction bondoed =
over. Find the screws under the bondo, remove the cone and access the =
hook mechanism from the front.
Roy
Old July 16th 04, 03:23 AM
Kurt
Roy Bourgeois wrote in message ...
Roy
Turns out the factory began putting access holes and plates in the
floorboards after a certain serial number. This was an early ship and
so it has to have the holes cut in the floor to get to the parts. The
nose cone is not bondo'ed on, but you sure cannot get to the parts
that way, or thru the cockpit. We have the factory drawings for the
modification. So, problem solved.
Tow Hook on Cessna 180 - Update Stuart Grant Soaring 13 April 10th 20 10:48 AM
Cobra Trailer Axel Replacement Carter Soaring 7 July 7th 04 02:06 PM
Cirrus SR22 Purchase advice needed. Dennis Owning 170 May 19th 04 04:44 PM
Cirrus SR22 Purchase advice needed. C J Campbell Piloting 122 May 10th 04 11:30 PM
Prop Cable - Replacement Needed zatatime Owning 0 May 7th 04 04:37 PM
