Roy Bourgeois wrote in message ...
Sounds like this 1-34 has had it's nose cone screws & junction bondoed = over. Find the screws under the bondo, remove the cone and access the = hook mechanism from the front. Roy Turns out the factory began putting access holes and plates in the floorboards after a certain serial number. This was an early ship and so it has to have the holes cut in the floor to get to the parts. The nose cone is not bondo'ed on, but you sure cannot get to the parts that way, or thru the cockpit. We have the factory drawings for the modification. So, problem solved. |
Tow Hook on Cessna 180 - Update | Stuart Grant | Soaring | 13 | April 10th 20 10:48 AM |
Cobra Trailer Axel Replacement | Carter | Soaring | 7 | July 7th 04 02:06 PM |
Cirrus SR22 Purchase advice needed. | Dennis | Owning | 170 | May 19th 04 04:44 PM |
Cirrus SR22 Purchase advice needed. | C J Campbell | Piloting | 122 | May 10th 04 11:30 PM |
Prop Cable - Replacement Needed | zatatime | Owning | 0 | May 7th 04 04:37 PM |
