#51
Jack wrote in message
They unflex because the load is removed. In order to stall they would have to unflex faster than the load is removed. If the pilot is pushing, the stall speed can go _way_ down. It's when he starts to load the wings again that his technique, or failure to track his loss of airspeed in the pull/push, can bring about the stall. Jack Isn't it also true that lift will be reduced if a highly flexed wing increases its angle attack beyond the critical angle of attack. If the wing is producing less lift it cannot maintain the flex that existed before the critical angle of attack was exceeded. As the wing unflexes the tip angle of attack increases. Which of those assumptions is invalid? Andy |
#52
Chris OCallaghan wrote:
.... When thermalling, use flap position 4, or drill a hole between positions 3 and 4 if you want less drag. Thank you, Chris. My 20B had a 3.5 hole drilled when we bought it but I had no advice on its purpose or use. I was puzzled when I couldn't relate the Flight Manual descriptions to what my glider had. Eventually I worked it out. I would be interested in any advice anyone can give on the use of 3.5. I tend to use it for nearly all thermalling and only use 4 for landing. Am I right? Is a 3.5 hole common? Did Schleicher's get it wrong? GC |
#53
On Sat, 17 Jul 2004 00:36:28 +1000, Graeme Cant
wrote: Thank you, Chris. My 20B had a 3.5 hole drilled when we bought it but I had no advice on its purpose or use. I was puzzled when I couldn't relate the Flight Manual descriptions to what my glider had. Eventually I worked it out. I would be interested in any advice anyone can give on the use of 3.5. I tend to use it for nearly all thermalling and only use 4 for landing. Am I right? Is a 3.5 hole common? Did Schleicher's get it wrong? It depends what you use 4 for: For thermalling at normal bank angles (20-30 degrees) 3 is the better setting (the 20 converst excessive speed into height a lot better in 3 than in 4), but very tight turns combined with high wing loading (or forward CG) need 4. Many 20 owners drilled the 3.5 hole, but I have to admit that I tested this setting and I never felt 3.5 to be an advantage over 3 (I hold the flap handle at 3.5 before I decided not to drill a hole there). At 3 the nose is significantly higher than in 3.5, but I think the 20's airfoil loves high AoA's. If the AoA of the 20 is too low (in other words: Flap setting too positive for current airspeed/g-load combination), the drag rise is drastic - very easy to feel the deceleration. One more thing why I love the 20: The flap handle tells you which position it wants to be in - it moves itself into the optimum position (if you help it overcome the friction with your hand). Bye Andreas |
#54
#55
Andy Durbin wrote:
Jack wrote in message They unflex because the load is removed. Isn't it also true that lift will be reduced if a highly flexed wing increases its angle attack beyond the critical angle of attack. If the wing is producing less lift it cannot maintain the flex that existed before the critical angle of attack was exceeded. As the wing unflexes the tip angle of attack increases. I see nothing in your comments which is invalid. If the wing unflexes due to stall and resultant loss of lift, the further increase in the angle of attack during the unflex may be of little consequence. -- Jack |
#56
Andreas Maurer wrote: But if the tip is already stalled it doesn't matter a lot if it has exceeded its maximum AoA by 2 degrees or 6 - the resulting stall is the same. No it's not. There isn't a "maximum angle of attack". There is only an "angle of attack for maximum lift". As you approach that angle of attack the rate of lift increase gets smaller and smaller, then you get the same amount of lift at slightly increasing angles of attack, and then with still more angle of attack you get less lift. The more you take the angle of attack past the point of maximum lift the less lift you get. So, yes, it does matter whether you are 2 degrees or 6 degrees past the angle of attack for maximum lift. -- Bruce |
#57
On Fri, 16 Jul 2004 09:22:52 +0200, "Bert Willing"
wrote: Stalling of a wing is connected to AoA in the first place, nothing else. I must respectfully disagree - the load being carried by the wing is at least as important as the AoA. -- martin@ : Martin Gregorie gregorie : Harlow, UK demon : co : Zappa fan & glider pilot uk : |
#58
Martin Gregorie wrote: On Fri, 16 Jul 2004 09:22:52 +0200, "Bert Willing" wrote: Stalling of a wing is connected to AoA in the first place, nothing else. I must respectfully disagree - the load being carried by the wing is at least as important as the AoA. I'm afraid that turns out not to be the case. Stalling depends on the AoA, and only the AoA (Reynolds number effects aside). The amount of lift generated depends only on the AoA and the airspeed. The amount of lift necessary to support the aircraft against an acceleration of 1 gravity depends on the load being carried. For each load there is a minimum airspeed below which the amount of lift necessary to support that load against gravity can not be generated. But if you don't insist on trying to support the load against gravity (that is, trying to increase the AoA until sufficient lift is generated, thus stalling the wing) then you can be in perfect control and not stalled at as low an airspeed as you like. Which brings us back to: stalling of a wing is connected to the AoA, nothing else. -- Bruce |
#59
Bruce Hoult wrote:
In article , Martin Gregorie wrote: ...the load being carried by the wing is at least as important as the AoA. [snippage] ...if you don't insist on trying to support the load...then you can be in perfect control and not stalled at as low an airspeed as you like. Bruce, it would appear that you and Martin are in agreement. Jack |
#60
Jack wrote:
Bruce Hoult wrote: In article , Martin Gregorie wrote: ...the load being carried by the wing is at least as important as the AoA. [snippage] ...if you don't insist on trying to support the load...then you can be in perfect control and not stalled at as low an airspeed as you like. Bruce, it would appear that you and Martin are in agreement. Appearances can be deceiving... If you look at the Coefficient of lift diagrams for airfoils, you see that it is dependent only on AOA, not load. In other words, a wing will stall at the same AOA at .5 G, 1 G, 2 G, etc. I think this is what Bruce is saying. Martin is wrong to say the load is as important as AOA, and that is why some ras posters think we should have AOA indicators in our gliders. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Spin Training | JJ Sinclair | Soaring | 6 | February 16th 04 04:49 PM |
spin characteristics of new racers | Andy Durbin | Soaring | 14 | January 31st 04 06:05 AM |
Cessna 150 Price Outlook | Charles Talleyrand | Owning | 80 | October 16th 03 02:18 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
