The Mosquito (glider) has an unusual arrangement, not flaperons, but quite
related. The ailerons and flaps move together when commanded by one lever. That's quite common on 15meter ships. The ailerons move independently of the flaps for aileron control. When you pull a different lever, for airbrake, the flaps deflect downward and a spoiler comes up (the spoiler is hinged at it's trailing edge and actually pushes the flap down) but the ailerons do not move. Then you can move the ailerons up and down in unison with the lever that I first mentioned while at the same time can be moved like normal ailerons. The ailerons have differential as well, more up than down. It is quite a system. The drag range is very large. The stall speed is hardly changed at all between flaps up and down. Typically I will takeoff with the flaps and ailerons full up. It makes a distinct difference in roll authority. After landing the first order of business is to get the ailerons up for this better aileron authority. By modulating the flaps/speed brake you can control your landing roll considerably (on hard surface). I must note - just because the stall speed doesn't change much with speed brakes it doesn't mean that the lift isn't changed much. The way we do stalls is not measuring your descent rate, it is measuring the speed at which you lose the ability to control the aircraft. Nils Rostedt wrote in message ... "Lou Parker" wrote in message . com... I just don't get it. Can anyone successfully explain how flaperons work? Are they better or worse than seperate flaps? What are the pro's and con's? It seems to me if one fails you have no recovery. Lou I'll try ;-) Flaperons are control surfaces that look like full span ailerons. They work both as ailerons (i.e. move in opposite directions when the stick is moved) and as flaps (i.e. move in the same direction when the flap handle is moved). There is a mechanical "mixer" device connected to the stick and flap handle that transmits the movement to the control surfaces so that they move as described above. The advantage, in theory, is that you can have effective, full span ailerons at the same time with effective full span flaps that can bring the stall speed down. To get the same effect with conventional control surfaces, the flaps need to be of more exotic design such as the split or Fowler type flaps. The main disadvantage is that when the flaps are in use you get an increased adverse yaw moment, which may make steering more difficult during approach. Also, as the flap deflection angle is limited compared to conventional flaps, the drag increase (speedbrake effect) is smaller. This means the airplane floats longer in ground effect on landing, making short field landings more difficult. A pilot friend had a Rans S-10 Sakota with flaperons. He told me he rarely used the flap function, preferring to sideslip on approach. The French DynAero MCR-01 high performance plane (Ban-Bi in the US) was originally designed (in the microlight/UL version) with double slotted flaperons to comply with the stall speed requirement of 35 knots (65 km/h) even with a very small wing area. After a few years, they were able to tweak the wing design to fulfil the stall speed requirement also with a conventional arrangement with ailerons and double slotted flaps, and this is the current configuration. A number of airplanes (gliders in particular) have ailerons which are connected with the flaps and move with them. In these planes, the main idea is to be able to reduce drag with negative deflection of the ailerons together with the flaps. But I'd hesitate to call them flaperons in this case, where the wing also has separate flaps. Please correct me if I got something wrong, my practical exeprience of flaperons is limited to radio controlled model airplanes ;-) // N |
