FAI, soaring and Olympic Games
Old August 18th 04, 05:04 AM
Kevin
Most people think that all the Olympic sailing classes are one design,
which simply isnt true. The most competitive class, the Finn, is
similar to our 15m or Std class with designs within a rule.
Kevin Chrisnter 2c
Old August 18th 04, 01:11 PM
iPilot
Well. It's not true.
"RULES of the INTERNATIONAL FINN CLASS 2004 Edition" say following in Part B "RULES AND
INTERPRETATIONS FOR THE CONTROL OF THE INTERNATIONAL FINN CLASS BOATS"
"Purpose of the Measurement Rules
1.1.1The Finn is a One-Design Class.
1.1.2 (74-1.1) (OR-1) The object of these rules is to establish a class of boats which is one-design
in all matters which affect
basic speed. The rules shall be interpreted in this spirit."
One-Desgn Class!!! Not some loosely specified standard class.
Basically the rules in Finn class are so strict that to transfer those to gliders class you get the
planes which have:
Same lenght
Same width
Exactly the same aerodynamic exterior of the fuselage
Exactly the same profile and the layout of the wing and the control surface.
Mostly the same materials in use.
Once again from Finn rules:
"Defining the hull shape requires use of a measurement jig to check length distances of the hull.
The jig should be
used during measurements at major championships and preferred for the first measurement of a boat,
particularly at builder's premises."
In case of soaring it compares to measuring the fuselage or wing profile in . Have you heard about
that anywhere?
In most places the permitted materials are listed.
If you are familiar with our standard class rules, it's a completly different philosophy
alltogether.
"Kevin" wrote in message ...
Kevin Chrisnter 2c
