Kitplanes December
Old November 15th 04, 04:18 PM
Jim Weir
Fifteen years ago they had an avionics writer that didn't know which end of the
soldering iron got hot. I bitched EVERY MONTH to the editor with factual
information as to what was correct and what was wrong. He finally got so tired
of my bitching that he offered me the chance to do it better.
So far, every month for fifteen years I've been doing it better. Why not get on
the editor's case and show where the errors are. Don't be MEAN about it, but be
persistent. We don't get paid a hell of a lot, but it buys a case of iced
orangeade from time to time.
Something about lighting a candle instead of cursing the darkness...
(Lou Parker)
Every month there is an apology for something wrong
-only because a subscriber has to point it out. Maybe it's time they
-knew the truth. They need help at the information business.
- Lou
http://www.rst-engr.com
Old November 15th 04, 10:50 PM
TaxSrv
know which end of the soldering iron got hot.
A classic was in Custom Planes, whose avionics writer had nothing in
his bio I found elsewhere to suggest he should be. He was explaining,
in an article entitled "Understanding Parallel Feeds," series verses
parallel wiring in a airplane, for practical reasons hard to fathom
once you thought you understood the title. He described an example of
a builder wiring two 14V radios in series in a plane with a 14V system
(who would?), but his reasons this wouldn't work -- he said both
displays would be dim -- missed the problem of the physical
installation resulting in a common ground. One will work just fine,
the other won't at all.
In another article, he explained Watt's Law to say that if your
battery voltage were to drop to 11 volts, your circuit breakers can
pop, because when voltage goes down, current must go up. So use
bigger breakers. And you'll like his explanation of how all avionics
work, I guess Circuit Design 101:
"Every piece of avionics in your plane contains thousands of [series]
circuits. They're used to modify voltages or signals between
stages...they allow your avionics to use them to drive...even moving
map displays."
Fred F.
Old November 15th 04, 10:58 PM
Morgans
map displays."
Fred F.
You sure that was not Jim W's work? I could have sworn that was the
explanation I heard him give, one time. VBG (ducking and running)
Actually, Jim is so far above my head, I seldom understand all of what he
writes. Even I can see the BS meter pegging, on that previous one.
Jim in NC
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.794 / Virus Database: 538 - Release Date: 11/10/2004
Old November 16th 04, 03:08 PM
Drew Dalgleish
On Mon, 15 Nov 2004 17:50:02 -0500, "TaxSrv"
map displays."
Fred F.
I stopped reading custom planes after I bought the issue with the
bearhawk on the cover and found out it was written by budd davisson
the owner of the quick build company. I don't really expect unbiased
reviews from any mag but that was way over the top.
Old November 17th 04, 03:02 AM
Del Rawlins
On Tue, 16 Nov 2004 15:08:56 GMT, (Drew
As long as the magazine made it clear that the writer wasn't an
unbiased source, and it sounds like they did (I don't generally read
CP so I don't know), I don't see a problem from an ethical standpoint.
I do think that a review by somebody else would have been of more use
to their readers.
In all fairness to Budd, he was singing the praises of the Bearhawk
long before he became involved financially with it. The situation is
not unlike that of the guy who liked the electric razor so much that
he bought the company. Also, on the email list he has been extremely
generous of his time in answering questions from plans builders who
haven't bought a thing from him as well as the kit builders.
Del Rawlins--
Unofficial Bearhawk FAQ website:
http://www.rawlinsbrothers.org/bhfaq/
Remove _kills_spammers_ to reply
Old November 17th 04, 07:13 PM
Drew Dalgleish
On Wed, 17 Nov 2004 03:02:23 GMT,
to their readers.
Del Rawlins--
I should have been clearer. I don't have anything against Budd he's a
good writer. I subscribe to the bearhawk list and am impressed with
his candor and willingness to help builders. I don't know if any other
kit manufacturers make themselves so available.
My beef is with CP they didn't make any disclaimer that I can recall.
The bearhawk was their cover story and I bought the mag for that one
story. It wasn't until I started reading it and saw the article that I
found out Budd was the author.
unfair cartoon in October 2004 issue of KITPLANES Bob Kaplow Home Built 31 August 29th 04 02:00 PM
Kitplanes August Issue Badwater Bill Home Built 28 July 6th 04 08:26 PM
Kitplanes Columns Jim Weir Home Built 30 April 14th 04 08:23 PM
KitPlanes - Home Page by Ron Wanttaja RobertR237 Home Built 40 August 12th 03 10:17 PM
Jim Weir's CO Detector in Kitplanes June edition. Michael Home Built 0 July 29th 03 01:32 PM
