Kirk Stant wrote:
(Mark James Boyd) wrote in message news:412b9c97 Think about it for a minute. If you're going 50 knots in one direction, and then one-half second later the nose of the glider is 180 degrees pointed the other way, does this mean you are doing 50 knots in the other direction? That's some G's, and I don't feel them in a spin. And what do you mean by doing "a complete 180 during the spin ...and is now to some degree flying backwards." That isn't a spin, it's a frisbee! As far as G's, if you enter a spin at low speed (not accelerated), you can't pull any G's - as the plane unloads and goes down there is actually a decrease in G's! Some aircraft have a very nose low spin (Blanik), others have a much flatter spin (Katana). The Katana, which spins very flat on the horizon, is going North at 30 knots. I stall it and spin. Over the course of a second, the nose is now pointed South. Is the Katana moving South with an airspeed of 30 knots? No, it is not. This is part of the reason why, during the first turn or two, the pitch oscillates more violently than in a fully developed spin. Because of momentum, the airspeed from front to back of the wings is less during the South pointed nose part of the spin than during the entry of North. And yes, this is a frisbee. At least for the first 180 anyway... This is why aircraft oscillate pitch up and down for a few turns before stabilizing in a spin. For the first few turns, the aircraft momentum is still slogging through the air. I don't have a spin text handy, but I would think the oscillation is more due to angular momentum and changing AOA as the glider rotates around it's pitch and roll axes than from "flying backwards". Yes, and part of this changing AOA is due to momentum in the Northerly direction. Even with an aft CG, any glider is fully controllable up to the spin - it's recovering that would be interesting. True, true. The more aft the CG, the more controllability. It's pretty hard to get the CG that far aft (it can be done, especially if you are light, but any sort of preflight should find it) Ms. Campbell is the Hawaii state altitude record holder. She worked at Dillingham as a CFI. She told me during a ground session she was in an uncontrolled spin for more than 5,000 feet at one point, with a passenger, before recovering. She said after landing, she weighed the glider and the CG was well aft of what was on the 10+ year old "official" form. And her new calculated CG for that flight was well aft of limits. In my experience, the older the calculation, the further back the actual CG is from it. Dirt and crap on the long lever arm of the tail do a lot more than crap in the short nose. and if discovered the plane is still fully controllable - unlike a too far forward CG that can lead to a heavy landing. Just my opinion, but I bet there have been very few spin accidents caused by aft CGs (CG out of the aft limit, not just at the aft limit). Except for that 1 in 10 case, I'd guess aft CG is just a contributing factor, not a cause. But I'd like to see data. When I hear of a winch launch by an experienced pilot during the first flight of the season, ending in a fatality, I have to wonder if he took something out of the nose, or put something in the tail, and so his stick pressure feel and initial trim setting were off... Of the stall spin fatalities on record, I'd bet most, if not all, had CG further back than the 60-70% forward that Eric described... Sounds like trying to turn via ground references down low - a big no-no This is required to fly a rectangular pattern with wind correction, and still part of the PTS... and probably the real reason for low altitude "stall-spin" accidents. Clearly true. If one weren't trying to land on a particular bit of ground, and the world was just one big flat runway, I'm certain landing accidents would be more rare. The classic spin entry from a shallow bank is uninteresting. I won't be jamming in the rudder for a skid at some obviously low speed close to the ground. I think the focus on the classic case is niave and dangerous. Yes, it's easy to teach and demonstrate, but it ignores too much. The more complex, less discussed spin entry is the one in the accident reports: tight pattern, higher speed, steep bank, lots of inside rudder, pilot focussed on keeping the yaw string straight, quite a bit of opposite aileron in the steep bank, in vertigo, pulling stick back to tighten up the turn, and then wham! I'll look back through the accident reports, but the ones I recall, and the B-52 and the DG spin I saw on video, involved stabilized, 30-45 deg bank turns before each of the spins. In each, it looked like the craft was overbanking, and the pilot put in more opposite aileron and more elevator and WHAM! Instant spin... Again, you are describing a pilot who has no clue how to fly his glider. Hard to quiz them, the dead are VERY quiet... A stabilized steep turn doesn't call for a lot of inside rudder. Many of the 10 reports seem to indicate the spirals/spins happened during the roll, not the turn. High roll rates require a lot of rudder (and then rudder release), used quite precisely. And I am a bit confused by your reference to vertigo - again, this is avoidable (don't stare at the ground, no rapid head movements, etc) and should be taught. I commonly induce vertigo in students to demonstrate unusual attitude recovery. Although easiest to induce by rapid head movements, I can also induce it with nothing more than a rapid, perfectly coordinated roll into a steep bank, and then a rapid coordinated roll to level flight. I've done this with pilots from 10-30,000 hours. In all of them, if I cover all the instruments on a nice dark night with foggles on, they get vertigo. Not staring at the ground and avoiding rapid head movements is a start, but is an incomplete solution...rapid roll rates and dramatic G changes are another factor. When I fly gliders, I have to remind myself to fly at least a 1/4 mile out pattern. I normally fly a power plane (day VFR only) with a 5:1 glide ratio, and a tight pattern, with steeper banks and faster roll rates at higher airspeed. I don't do this when in a glider approaching an unmarked landout field with mountains and no horizon around. If a pilot continually gets vertigo in steep turns (and I have some really good friends who do, unfortunately) they need to seriously consider the ramifications of it and fly accordingly! I see we are agreeing again ![]() -- ------------+ Mark Boyd Avenal, California, USA |
Mark James Boyd wrote:
Some aircraft have a very nose low spin (Blanik), others have a much flatter spin (Katana). The Katana, which spins very flat on the horizon, is going North at 30 knots. I stall it and spin. Over the course of a second, the nose is now pointed South. Why do you think it takes only one second? Even a aerobatic glider can't reverse direction that quickly - that would be such a violent manuever. Think about it: a 60 knot change in one second takes over 3 gs, and a spin entry produces nothing like that. Try timing a spin entry sometime with stopwatch or a recorder on board. Is the Katana moving South with an airspeed of 30 knots? No, it is not. It's probably still got about 30 knots airspeed (do they really stall at such a low speed?), but because it is pointed down, the southerly component is less than 30 knots. snip Except for that 1 in 10 case, I'd guess aft CG is just a contributing factor, not a cause. But I'd like to see data. When I hear of a winch launch by an experienced pilot during the first flight of the season, ending in a fatality, I have to wonder if he took something out of the nose, or put something in the tail, and so his stick pressure feel and initial trim setting were off... Of the stall spin fatalities on record, I'd bet most, if not all, had CG further back than the 60-70% forward that Eric described... Just to be clear here, the convention is: 0% is at the front of the range; 100% is at the aft end of the range. It sounds like you have it backwards. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Eric Greenwell wrote:
Just to be clear here, the convention is: 0% is at the front of the range; 100% is at the aft end of the range. It sounds like you have it backwards. My mistake. I wasn't expecting you to have flown aircraft in such an aft CG range, and inverted it in my mind. Really. So the aircraft were in the aft 1/3 of the range? And still wouldn't stall at 45 deg bank? Interesting... I believe you, I'd just like to see this myself as well. As far as stalls in a steep bank, without uncoordinated inputs, I've noticed many aircraft roll wings level, just like the GFH and AFH (and Marc, it seems) say... One thing I haven't tried that I recall is banking into a turn and then just failing to take rudder out while rolling level at a high rate (all while at low airspeed). This should get a nice spin entry too... Maybe there are spin fatalities in this category too...steep bank close to the ground, more elevator to tighten the turn to final, then an attempt at a quick roll to level wings... -- ------------+ Mark Boyd Avenal, California, USA |
Eric Greenwell wrote: Just to be clear here, the convention is: 0% is at the front of the range; 100% is at the aft end of the range. It sounds like you have it backwards. My mistake. I wasn't expecting you to have flown aircraft in such an aft CG range, and inverted it in my mind. Really. So the aircraft were in the aft 1/3 of the range? And still wouldn't stall at 45 deg bank? Interesting... 70% is a common CG location, because (for many/most gliders, especially the newer they are) the glider handles pleasantly, recovers easily from spins, and is close to the optimum CG for cross-country performance. I believe you, I'd just like to see this myself as well. The limit on elevator "authority" isn't so much the force it can generate (except at the most forward positions) but more the angle of attack reduction on the elevator that occurs in steep turns. I'm sure the bank angle you can stall at is higher with a more aft CG, but in the commonly used 60-80% range, you do run out of elevator in the steeper turns. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Kirk Stant wrote:
I fly my pattern based on where I want to touch down, and adjust the pattern accoding to my altitude and the wind. I prefer low, tight, fast patterns, so I can see what I'm getting into during a landout! And if you don't like what you are getting into, how do you avoid if you are low and tight? Even a high, large pattern will eventually have you as close to the "what you are getting into", but in the mean time, you have a lot more time to look things over and change your mind. I don't think I like the idea of a fast landout, either. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
![]() Slightly off topic but the following is pretty good reading, IMHO. pdf: http://home.comcast.net/~verhulst/GB...erLandings.pdf If you prefer html: http://home.comcast.net/~verhulst/GB...r_landings.htm Tony V. -- Even popularity can be overdone. In Rome, along at first, you are full of regrets that Michelangelo died; but by and by you only regret that you didn't see him do it. Mark Twain |
Tony Verhulst wrote:
Slightly off topic but the following is pretty good reading, IMHO. http://home.comcast.net/~verhulst/GB...r_landings.htm It really points out one of the largest differences between power and glider flight: the increased need for no altimeter approaches. The Airplane Flying Handbook (AFH) suggests rectangular field engine failure landouts just for this reason (to eliminate the problem, just fly further on base). I must say, however, that I vaguely recall that other countries don't fly rectangles, but a V and then a 45 deg turn onto final. Is this true? It seems like a better way to avoid looking back over the shoulder for the touchdown spot... -- ------------+ Mark Boyd Avenal, California, USA |
fly rectangles, but a V and then a 45 deg turn onto final. Is this true? It seems like a better way to avoid looking back over the shoulder for the touchdown spot... -- ------------+ Mark Boyd Avenal, California, USA Not in this country (UK). But I was taught to do a 45 degree approach at Minden. -- Mike Lindsay |
SR22 Spin Recovery | gwengler | Piloting | 9 | September 24th 04 07:31 AM |
Spin Training | JJ Sinclair | Soaring | 6 | February 16th 04 04:49 PM |
Cessna 150 Price Outlook | Charles Talleyrand | Owning | 80 | October 16th 03 02:18 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
