Eric Greenwell wrote in message ...
And if you don't like what you are getting into, how do you avoid if you are low and tight? Even a high, large pattern will eventually have you as close to the "what you are getting into", but in the mean time, you have a lot more time to look things over and change your mind. I don't think I like the idea of a fast landout, either. Eric, what I want is to have the best look at the potential landout field before actually landing on it. That means picking the field early, looking at it carefully while making a last attempt to climb out (if possible, then setting up a pattern close enough to be able to see terrain details and pick the exact point to touch down at. That usually means being downwind at about 500' or so, and that means being pretty close in. By fast, I mean about 60 to 70 knots (depending on wind, etc) in my LS6 dry. That is plenty enough for aggresive turning if necessary to adjust my pattern, and to float over a last minute fence, but slow enough that with full divebrakes I can quickly slow down on short final for a low energy tail first landing. And I practice this often at my home field, using different runways when possible to get used to different patterns. And it has worked on my actual landouts, when necessary (obviously not a good idea when landing at a big controlled field - that requires a totally different pattern technique!). I shudder when I watch 2-33s flying wide bomber patterns, downwind at 1000', and flying long finals. It may be FAA approved textbook, but I think it is bad technique. I like the BGA's idea of the angled base leg, which approaches my preferred military-style one turn to final pattern. Hope this clarifies things a bit. Kirk |
Kirk Stant wrote:
I like the BGA's idea of the angled base leg, which approaches my preferred military-style one turn to final pattern. Yep, I think this is a better pattern too. I wonder where the rectangle came from in the USA? -- ------------+ Mark Boyd Avenal, California, USA |
SR22 Spin Recovery | gwengler | Piloting | 9 | September 24th 04 07:31 AM |
Spin Training | JJ Sinclair | Soaring | 6 | February 16th 04 04:49 PM |
Cessna 150 Price Outlook | Charles Talleyrand | Owning | 80 | October 16th 03 02:18 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
