5000 meter height gain
Old August 28th 04, 03:31 PM
chris
Denis wrote in message ...
Gary Boggs wrote:
And about the M&H system, I use the cannula but you have to be very careful
that you don't take any breaths through you mouth. I've heard of some guys
holding a mouthful of water to make sure they don't.
This is not allowed above 0°C level (water could freeze)
If the water in your mouth freezes you have worse problems than
hypoxia!
If your body temperature drops to freezing level, hypothermia will
have long since killed you.
If you do this at least try to freeze yourself in a stable best L/D
glide into the wind so you can glide into the hereafter a real long
ways, at least you will not have to worry about a PIO.
chris
Deck height Sean Trost Home Built 5 July 16th 04 03:46 AM
Is there support for a official 20 meter two seater FAI class? Ruud Soaring 1 June 7th 04 07:31 PM
Radio Shack SWR meter Paul Lee Home Built 6 June 2nd 04 04:42 AM
Kestral 1000 Wind Speed Meter NEW IN BOX Cecil E. Chapman Products 0 November 7th 03 06:56 PM
Best Software and Hardware for Turn Area Task? Snead1 Soaring 29 August 13th 03 04:12 PM
