The discussion of a) overly-long checklists that don't get used and,
on the other hand, b) the need for checklists reminds me of a discussion with a power instructor (instrument), who made a distinction I hadn't encountered before, but it made sense. He distinguished between a written procedure, a written checklist and an oral checklist. Here's the idea: Written procedu a written sequence of steps to take. Written checklist: a written list of things to check. Oral checklist: a memorized checklist. Should be very short, and memorable, used only for a few last-minute and "death/destruction" items. A written procedure may be quite long and can be detailed. It may contain some lower-importance items. It is used for setting up the aircraft and should be used when there is time for it. Sitting next in line for takeoff on the runway, barreling down final approach, or right after a rope break - not good times for a written procedure. A written checklist may also be quite long. Often it's the same as the procedure list, but it should contain only short reminders of only the important items: its purpose is to confirm that the aircraft is already properly set up. Written checklists should also be used when there is time for them. They provide a double-check; their disadvantage is that they rarely identify anything wrong, so human nature makes it easy to miss something. It's mostly for that reason that a checklist should be as short as possible and should stick to truly important items: no zipper-checks. In 2-pilot operations, the written procedure and checklist can be combined in a single document, but the functions are separated by the challenge-response between the two pilots. For single pilot operation, this instructor did NOT like the approach of read-it-do-it-confirm-it all in one pass. It's too easy to either skip a line, or skip an action (to avoid missing a line, pilots have a tendency to touch the control but keep their eyes on the list, so they don't actually confirm the step or even think about what they're doing). Hence his preference for separating the roles of the two pilots - read it (copilot role), do it (pilot role), check it (copilot role) - into entirely separate sequences. An oral checklist should be short and memorable. It should contain only last-minute items and the few items most likely to cause death and/or destruction. It can be used when the pilot is busy, because it's short and doesn't require reading. In fact, busy moments - when something may get overlooked - can be a good place to insert one! The takeoff and landing checklists are the best examples. I'm still working on how this translates for gliders. I think those long checklists ("zipper check / chewing gum quantity check / attach tow rope") are actually procedures: most pilots probably don't need to keep using the written version (how likely is it that you'll forget to attach the tow rope? - and if you do, what will happen?). Shorter checklists have their place - "task set up on the nav computer" - but probably should be done before you become #1 in line for takeoff. And oral checklists should be used right before takeoff ("brakes-trim-belts" or whatever) and landing (USTALL, or your own favorite) as a last-minute confirmation that nothing really stupid is going to cause something really bad. There's a somewhat separate question of what the right contents for the procedures and checklists should be! |
the procedures and checklists should be! With apologies to pilots whose memories never fail even under stress, I'm one of those guys who does use a very detailed written checklist. Chewing gum isn't on it but things like food, drinking water, reading glasses, and landout jacket are. But I don't wait until I'm #1 on the takeoff line to use it. One reason is that it's in sections. The first and longest section is the post-assembly checklist with all the stuff on the glider, arranged in the proper walkaround order. I can do that immediately after rigging. Then there's another list of all the stuff that should be in the cockpit--things that wouldn't kill me if I forgot but which might make life less comfortable. Then there are sections for task items (applies only to contests: task sheet, retrieve telephone #, etc.), on the grid (tail dolly, etc.), and pre-takeoff (I use the very old SSA A-B-C-C-C-D sequence that I committed to memory back in the mid 1960s). I've got a section for landing out: remove multi-probe, download trace to CF card, etc., since in the pre-cellular world I once got to a pay telephone without my wallet or the retrieve #. There's even a section for my crew to use for hooking up the trailer. I keep a copy in the cockpit at all times. If I do things out of sequence, I literally check off each item with a pencil. On a normal day at the gliderport, I just run my thumb down the list and make sure I'm not interrupted during one of the sections. OK, maybe this is overkill. But whether I'm crewless or accompanied by my wife and two 10-year-old daughters, it seems like I'm always rushed before takeoff. Having a written checklist not only guarantees I won't forget something but gives me peace of mind when I launch that I've done everything right and lets me focus on flying safely. And in the post-Clem Bowman/Genesis accident era, it gives my family the same peace of mind. I'll confess that in the past 40 years, I've taken off without my map (pre-GPS days), with my dive brakes open, without taping, and with a landing gear door hanging loose. And that doesn't count the time I was on the line ready to launch with the tail dolly still attached. It's fun to scoff about obsessive/compulsive types reaching for their checklist and pencil during a spin recovery. ![]() use my written checklist before every flight, as I noted in the safety talk I gave at this year's U.S. Standard Class Nationals. Chip Bearden |
Finbar wrote: The discussion of a) overly-long checklists that don't get used and, on the other hand, b) the need for checklists reminds me of a discussion with a power instructor (instrument), who made a distinction I hadn't encountered before, but it made sense. He distinguished between a written procedure, a written checklist and an oral checklist. Here's the idea: Written procedu a written sequence of steps to take. Written checklist: a written list of things to check. Oral checklist: a memorized checklist. Should be very short, and memorable, used only for a few last-minute and "death/destruction" items. A written procedure may be quite long and can be detailed. It may contain some lower-importance items. It is used for setting up the aircraft and should be used when there is time for it. Sitting next in line for takeoff on the runway, barreling down final approach, or right after a rope break - not good times for a written procedure. One other item. I've found that numbering the written checklist helps. Then, even solo, I read it aloud. I read "1", and aloud then I do "2". I've found that if I skip a step, my brain goes instantly "3 isn't after 1!" and I'm saved. Again, I also prioritize it. This makes for an awkward flow in some aircraft, but I can repeat items to get a good flow. Anyway, all good stuff... -- ------------+ Mark Boyd Avenal, California, USA |
SR22 Spin Recovery | gwengler | Piloting | 9 | September 24th 04 07:31 AM |
Spin Training | JJ Sinclair | Soaring | 6 | February 16th 04 04:49 PM |
Cessna 150 Price Outlook | Charles Talleyrand | Owning | 80 | October 16th 03 02:18 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
