Derek Piggott has written as follows:
"I think lots of people still think that pro-spin controls means having a lot of rudder or aileron on and don't realise that the important thing is the stick position. If the stick is well back, spinable machines spin: without the stick being back they don't spin. "I don't need to tell you that many other gliders will spin a turn or two if the stick is kept back on the stop, the c.g. is well aft and a wing drops, even if the aileron and rudder are still central." Even if the pilot coordinates perfectly, and string and ball remain exactly central, a gust or turbulence may cause enough asymmetry to start a wing drop. Gustiness, gradient, shear and turbulence are particularly likely close to the ground. W.J. (Bill) Dean (U.K.). Remove "ic" to reply. "Chris OCallaghan" wrote in message om... snip BTW, as I noted in another thread, spins are not caused by lack of airspeed, but uncoordinated use of the controls -- at least in modern sailplanes. Two things must happen to enter a spin: 1) you must stall, and 2) you must fail to apply sufficient rudder during your attempt to pick up the low wing with aileron. That is, the sailplane is designed with enough rudder to stop autorotation, even with full deflection of the aileron throughout the stall break. snip |
Bill,
Can't say I agree, but at least from my point of view, you are erring on the side of safety. Here is a simple argument that I have backed up with experiment in many types of gliders. An aircraft that is capable of spinning during a stall while aileron and rudder are held neutral (and within published cg limits) is inherently unsafe. This means that such a glider flown into a strong, turbulent wind gradient 50 feet above the ground is likely to autorotate. Since recovery from an insipient spin requires much more altitude than a straight ahead stall, there is a very good chance that such a glider would see very few flights before being retired. I have proven to myself many times that stalling a glider without abusing the controls results not in a spin but a spiral dive. While we can all point to experiences of having a wing drop and losing control in a stall, I doubt very seriously that any of us were holding coordinated controls throughout the stall break. It takes a very determined effort not to move the stick throughout the stall and self-recovery. Here's another argument. The vertical stabilizer provides a great deal of yaw stability, even at very low speeds. To start autorotation, you need a source of drag at the tip greater than the normal differential to be expected resulting from span effect in a turn. That we don't kill ourselves everytime the glider approaches stall is testament to the stability provided by the tail. That we occasionally do screw gliders into the ground makes me think that the cause lies more in the way we are applying the controls under stress than any inherent tendency of the glider snap into a spin at the least external provocation. Yes, outside factors can influence how the glider flies, but I think they do more damage by causing pilots to react in unacceptable ways. Go back and read through my reports on control use during stall in my Ventus. What it drives home in my mind is that spins are the result of control abuse. You're right, don't stall land you won't spin. But it's just as right to say that a stall needn't develop into a spin so long as the controls are not abused. |
That's nonsense. Spin/autrotation is all about one wing (partially) stalled,
and the other not. It's not about drag. -- Bert Willing ASW20 "TW" "Chris OCallaghan" a écrit dans le message de m... Here's another argument. The vertical stabilizer provides a great deal of yaw stability, even at very low speeds. To start autorotation, you need a source of drag at the tip greater than the normal differential to be expected resulting from span effect in a turn. That we don't |
Uh, Bert, what happens when a wing stalls? Lift decreases... drag
increases. Something needs to start the spin. Could that be... a force? I suppose we could call it something other than drag. Gremlins maybe? Let's see, perhaps I can offer another explanation. Non-symmetrical, differential lift across the wingspan produces roll. Non-symmetrical, differential drag along the wingspan produces yaw (adverse yaw when actuating the ailerons, for example). The vertical stablizer and rudder are there to provide stability and yaw authority to counteract the aileron drag effect (as well as the destabilizing effect of the fuselage forward of the cg). If the stall (or partial stall) produced no drag, the glider would simply roll. There would be no yawing motion. And thus, no spin! (But lots of rolling.) Here's another way to think about it... if you had an infinitely large vertical stabilizer (that is, infinite directional stability), would it be possible to spin? Since the infinitely large tail would produce an infinitely large counterforce to any adverse yaw, then a spin is not possible. What's the practical substitute for an infinitely (or very) large vertical stabilizer? A moveable rudder. It's all about the flippers, man. And from a practical standpoint, spins are all about the drag. And even though a partially stalled wing will display adverse yaw with neutral control surfaces, so long as you don't move the flippers, the vertical stabilizer will keep you from spinning. As noted before, I prove this to myself with every modern model of glider I fly. But if you move those flippers in an uncoordinated fashion, baby, all bets are off! Piggott: "Drag from the badly stalled, falling wing, pulls the glider down into a steep spiral and the autorotation is speeded up." There's a graceful way out of your dilemma... we could discuss the torques brought into play by the rolling motion of a partially stalled wing. That will introduce a rotation about the yaw axis (the aerodynamicist's definition of autorotation), but you'll need to prove to me that it alone is sufficient to overpower the vertical stabilizer, even at very low airspeeds and relatively high rates of roll. Since the vast majority of modern aircraft need an additional yawing moment to enter a spin (pro rudder, counter aileron), it's going to be a tough sell. But I'd be interested to see you work through the problem. Maybe we'll both learn something new. "Bert Willing" wrote in message ... That's nonsense. Spin/autrotation is all about one wing (partially) stalled, and the other not. It's not about drag. -- Bert Willing ASW20 "TW" "Chris OCallaghan" a écrit dans le message de m... Here's another argument. The vertical stabilizer provides a great deal of yaw stability, even at very low speeds. To start autorotation, you need a source of drag at the tip greater than the normal differential to be expected resulting from span effect in a turn. That we don't |
BTW,
I thought I'd add that "autorotation" is why highly controllable, low stability aircraft can be spun with ailerons held into the direction of spin. If you can roll fast enough with stick well back, the resulting torque about the yaw access is sufficient to overpower a too small vertical stabilizer (in designs where stability is sacrificed for greater controlability). But this does not describe a modern, certified glider. And, after all, we're looking for practical knowledge we can take into the air. But I remain interested in whether you can demonstrate that rolling torque alone will make the glider spin. If it can't, then we can focus on other sources of adverse yaw that contribute to the autorotation. If it can, then we'd all best be looking for a new, safer passtime, like freeclimbing solo. But hey! I'm making your argument for you. Bert, this could really be fun. Fire away, please! |
SR22 Spin Recovery | gwengler | Piloting | 9 | September 24th 04 07:31 AM |
Spin Training | JJ Sinclair | Soaring | 6 | February 16th 04 04:49 PM |
Cessna 150 Price Outlook | Charles Talleyrand | Owning | 80 | October 16th 03 02:18 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
