Aircraft certification questions.
Old November 16th 04, 11:16 PM
Blueskies
"Steve Foley" wrote in message
You don't have PMA.
I cannot buy a Gates belt and put it on my Piper, but I can but a belt from
Piper that they bought from Gates, and put it on my plane. Nobody could tell
the difference, because there is none. That doesn't make it legal.
Same holds true for the u-joint holding my yoke together. It's not legal to
put it in the plane unless Piper has blessed it first (with their invoice).
"psyshrike" wrote in message
om...
If a field mechanic and an FAA expert couldn't tell the difference
between engine A and engine B, is there any regulatory reason this
wouldn't work?
Anyone can reverse engineer the 'part' and apply for PMA for it. The feds will accept it if the process is good...
Old November 17th 04, 06:30 PM
psyshrike
"Blueskies" wrote in message . ..
You don't have PMA.
om...
wouldn't work?
Do you have an example?
I looked at Advisory circular 21-1B all the Qaulity control standards
appear to be handled through the Production Certificate (PC), which I
guess is what you file to get your Parts Manufacturing Authority
(PMA)? Apparently having a PC, does not directly require a Type
Certificate (TC). Presumably this is intended so that subcontractors
can be regulated. By the look of it you CAN manufacture parts with the
FAA's blessing without a TC.
Refering up-thread to Steves comment, I can understand the engine belt
issue if the OEM for the belt doesn't directly have a PC. In effect
Pipers PC would have to include Quality Control (QC) for the part. But
I can't emagine that the TC dictating that you can only buy part X
from vendor Y. It is more like Vendor Y must comply with FAA safety
standards (have a PC) in order to sell direct. Which is probably not
cost effective for them to do since they probably make nonaviation
parts on the same assembly line.
I am guessing Type Certificates were originally supposed to dictate an
engineering and testing standard required prior to selling the part.
But it eventually evolved so that the PC and flight testing standards
make up the the technical portion, while the TC itself just ends up
being a revision log. O-360-A1A, O-360-A1B etc. Is this fairly
accurate?
It sounds like the catch-22 is this:
Manufacturer: "Here is the engine made in full accordance with my PC,
it has been run up and tested I would like my Airworthyness Tag"
FAA: "What TC number?",
Manufacturer: "Number Contintal O-235 1234",
FAA: "Thats not your TC",
Manufacturer: "Damn your quick",
FAA: "You have to have your own TC, because you have impirically test
for safety",
Manufacturer: "It has already been tested by Contintal Engine Company.
It tested safe. There 5000 in the fleet, and I'd be happy to refer you
to all the happy pilots who've logged a trillion hours on this
engine",
FAA: "Well thats how we do things"
Manufacturer: "No it's not, the regs say that I am free to manufacture
a part for aviation provided that that I have a PC."
FAA: "It's not the same engine"
Manufacturer: "Prove it"
FAA: "We don't have to, we're the FAA"
Manufacturer: "Oh yes you do, and this small army of blood thirsty
lawyers standing behind me says so",
FAA: "But you didn't design it, and go through years of testing so we
could bust your chops and pontificate our naval"
Manufacturer: "You catch on quick"
FAA: "Well you still have to have a TC, so here are the forms, let us
when we can schedule a time to come over and bust you balls."
Manufacturer: (pulls out the same form, already filled out with
references to the the original OEM TC) "No need, here you go, and
heres my Production Certificate as well".
FAA: "This simply won't do."
Manufacturer: "Why not"
FAA: "Well you see, you have to go through the 'process'".
Manufacturer: "Show me that in the regs"
I guess my questions boils down to: Is there any part of the TC that
stipulates that the sale of a part is dependent on the permission of
the TC holder? Does the issuance of an Airworthyness tag require
permission from the TC holder?
-Thanks
-Matt
Old November 17th 04, 07:03 PM
Rich S.
om...
BLAM !!!
FAA: "This simply won't . . .
THUD !!!
Old November 17th 04, 11:08 PM
Blueskies
"psyshrike" wrote in message om...
anip
snip
-Thanks
-Matt
Try he
http://www.wencor.com/products/pmas.html
http://www.ainonline.com/issues/07_0...mapartp94.html
You, as a PMA 'Knock off' house, need to show how you reverse engineered the product. I think that many get the reverse
engineering process blessed through the FAA, and then they run the process on a number of similar parts. The OEM (TC
folks) do not like the PMA houses because they depend on the aftermarket business to keep things going. Even the OEM
folks, when they sell 'spares', have to show that they hold PMA authority for the part when they sell it...
Old November 18th 04, 09:49 AM
smjmitchell
There are a number of ways to get a PMA - don't be any means think that this
is a straight forward process. The first method is to prove to the FAA that
the part is identical to the original. The second is to provide engineering
data to prove that the part meets the applicable design standards from the
FAR that would apply to the design of that part. For something like an
engine part it will be very difficult to show that your part is identical to
the original without access to the OEM's data simply because you can never
be sure what material, processes, tolerances etc the OEM has used. Without
this sort of insight it can be very difficult to prove that your part is a
proper substitute for the original. If you produce OEM data to prove the
identical nature then the regulations (21.303) more of less imply that you
would then need to produce evidence of a licencing agreement for the use of
that data. There is no point in explaining this process further here. There
is volumes of data on the FAA web site that explain the process.
You do not need a PC to make parts under PMA (see 21.303 (h)). The PMA
application includes all the requirements for configuration and quality
control of the manufacturing process. The PMA is in effect a licence to
produce parts. Unlike a TC it is both a design and manufacturing approval.
Subcontractors do not hold separate PC's .... it is up to the PC holder to
document the process for the control of subcontractors in the PC process
control documents and manuals.
The reason you cannot buy a Gates belt from gates and use that is that it is
in effect a commercial part. Piper has probably developed a specification
for the part against which the part is conformed on delivery to Piper to
turn it into an airplane part. Same part yes but Piper has applied
additional QA oversight to ensure that it is fit for the purpose that they
intended. This may take the form of additional inspections or testing.
But
See previous explanation.
accurate?
No not exactly. The TC is simple a design approval. The holder of a TC does
not really have any right to build the airplane. They simply have a design
approved by the FAA as meeting FAR 23/25/27/29/35 depending on the product
type.
There are two ways in which the holder of a TC can then produce airplanes to
that approved design.
Ref FAR 21 Subpart G - One is via a PC which basically establishes FAA
approved processes for the control of the manufacturing activities including
all testing of the product before delivery. Depending on the maturity of a
companies PC the company will be delegated certain levels of responsibility
by the FAA from very little right through to the authority to conduct final
inspections, approve flight test reports, issue CofA's etc (i.e. complete
control of the process). FAR 21.133 is quite clear - you must hold a TC or
an STC or evidence that you have the rights to manufacture a products to a
third parties TC or STC to be elligible for the issue of a PC. PMA holders
and subcontractors are NOT eligible for the issue of a PC.
Ref FAR 21 Subpart F - The other method of producing an airplane for which
you hold a TC is "production under a Type Certificate Only". Generally this
applies to companies who have recently gained a TC and who want to start
manufacturing the airplane but who have not yet got a PC. When airplanes are
made in the way the FAA is heavilly involved in the process. It does not
means that the company does not need production control processes, they do,
but these may not be sufficiently mature for the issue of a PC and
consequently the FAA is not yet in a position to delegate the company
authorities to conduct certain tasks on their behalf.
Old November 18th 04, 09:58 PM
psyshrike
"smjmitchell" wrote in message . au...
Outstanding information thanks! I read 21.303, and by the look of it
there are a few things that still would probably end up being
contested IMHO. Not anything insurmountable though.
For example f(4):
That the fabrication processes, construction, and assembly conform to
those specified in the design.
I am guessing this means that the TC can include manufacturing
techniques, and that your supposed to be in compliance with those
techniques. Obviously that's not possible without the OEM data. I
can't emagine contesting this would be difficult provided you could
demonstrate equivilant or superior quality control.
As far as the sub-parts on design and material specification, that
would all be dependent on the competency of the persons doing your
reverse engineering. If the FAA dinged you on it, you would just go
back to the crated OEM engines in the lab and confirm or deny the
FAA's position. Then you just have to fix it and demonstrate
conclusively that there was no difference.
I expect you'd probably still end up in court, but only once or twice.
Still cheaper that designing and flight testing a whole new engine.
Much obliged.
BTW, are you with the FAA?
-Thanks
-Matt
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 40 October 3rd 08 03:13 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 1st 04 02:31 PM
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 September 2nd 04 05:15 AM
