Hi guys,
Thank you so much for your insights and advise. There is a local pilot that has an LS4, a little bit of crazing of the fiberglass. He hasn't flown in about 10 years. I am also looking at a brand new 15 meter SZD51-1 Junior. I know they are not quite in the same class but I am a little nervous about the high performance of the LS4. I plan to spend the next two weeks in a Lark to transition to a glass ship(remember I don't have my licence yet but am very keen and careful). My approaches are good and PDM has been refined over the last 15 year. I do not want to get discouraged by a ship over my level of ability. I still plan to spend lots of time dual to refine my skills. Any advise is greatly appreciated. Jeff |
Jeff Runciman wrote:
Hi guys, Thank you so much for your insights and advise. There is a local pilot that has an LS4, a little bit of crazing of the fiberglass. Don't worry about performance. Last week I flown a Discus2 and I have to tell that I can't imagine better glider for beginners. I think it will be difficult to sell you junior and you could outgrow in a year so go for the ls4 if you can afford it. Regards, /Janos |
![]() "Janos Bauer" wrote in message ... Jeff Runciman wrote: Hi guys, Thank you so much for your insights and advise. There is a local pilot that has an LS4, a little bit of crazing of the fiberglass. Don't worry about performance. Last week I flown a Discus2 and I have to tell that I can't imagine better glider for beginners. I think it will be difficult to sell you junior and you could outgrow in a year so go for the ls4 if you can afford it. Regards, /Janos There seems to be a steady stream of clubs and others looking for Juniors in the US. There are eight on the registry and no one wants to sell. One owner told me he'd had a call each month this year when I called a few months ago. Due to the Euro/Dollar rate, they are a little bit expensive for new production w/trailer as there are other suitable options available on the used market. Frank |
Jeff Runciman wrote in message ...
Hi guys, Thank you so much for your insights and advise. There is a local pilot that has an LS4, a little bit of crazing of the fiberglass. He hasn't flown in about 10 years. I am also looking at a brand new 15 meter SZD51-1 Junior. I know they are not quite in the same class but I am a little nervous about the high performance of the LS4.... Once again, "high performance" does not equate to "hard to fly" in a sailplane. Characteristics that make a glider "hard to fly" are poor roll rate, small spoilers, inadequate rudder, touchy spin characteristics or tip stalling tendencies, poor cockpit layout, unharmonized controls, poor aileron control on takeoff, etc. This can come with good glide angle or bad glide angle. More glide angle by itself does not make a sailplane harder to fly - it only makes it more fun! The LS4 is a very good easy to fly glider -- only the LS8, Discus2, ASW28 are better in that class, and they also perform better. The LS4 is a lot easier to fly than older generation gliders with worse performance. John Cochrane (BB) |
Janos Bauer wrote:
Jeff Runciman wrote: Hi guys, Thank you so much for your insights and advise. There is a local pilot that has an LS4, a little bit of crazing of the fiberglass. Don't worry about performance. Last week I flown a Discus2 and I have to tell that I can't imagine better glider for beginners. I think it will be difficult to sell you junior and you could outgrow in a year so go for the ls4 if you can afford it. And Jeff, keep in mind some of the performance is just from the retract wheel. Really I wouldn't buy into a fixed gear glider unless it was a Sparrowhawk. In the end, if the retract idea is scary, just leave the gear down! Tie-wrap it that way if you like! Believe me, you'll outgrow fixed gear quickly... -- ------------+ Mark J. Boyd |
Mark James Boyd wrote:
And Jeff, keep in mind some of the performance is just from the retract wheel. Really I wouldn't buy into a fixed gear glider unless it was a Sparrowhawk. In the end, if the retract idea is scary, just leave the gear down! Tie-wrap it that way if you like! Believe me, you'll outgrow fixed gear quickly... THis might not be obvious, but a glider designed with fixed gear doesn't suffer the same performance penalty a retractable gear glider does when the gear is down. THe typical fixed gear does not extend as far from the fuselage as on a retractable gear glider, and it is faired in properly, so the drag is negligible at thermalling and moderate speeds and small at higher speeds. Because a nonretracting gear is typically on lower performance gliders, I think people come to believe it is a big performance liability. These gliders would still be lower performance with the gear tucked away. For example, note the small handicap difference between these two Russias (US handicap): AviaStroitel Russia AC-4A 1.193 (fixed gear) AviaStroitel Russia AC-4C 1.185 (retract gear) Or the SAME handicap for the two versions of the Phoebus: Bolkow Phoebus A, B 1.025 (A is fixed; B is retract) What the retractable gear can give a designer is flexibility in other aspects. The glider can sit higher off the ground for better wing and fuselage clearance in a off-airport landing, and more "crush space" is available for absorbing very heavy landing loads. Of course, the designer might choose a gear high enough that wing tip stalling on the ground roll is a problem, or not use the crush space effectively (cheaper). You will definitely pay more for the retractable gear because they are more costly to design and build, and some of us will pay more for fixing the glider when they forget to lower the gear or it makes it's own decision about retracting! -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
I've flown both. The LS-4s I have flown are easier and more pleasant to
fly than the Junior I flew. I'll risk saying that the LS-4 is so easy to fly that it is almost boring. Very stable in all 3 axes. Darn near flies coordinated on it's own and requires very little input in thermals. The one Junior that I have flown is a fine ship except for a sticky rudder. My first glider was a 301 Libelle (my second glider was a 301 Libelle as well). On releasing from tow, I remember thinking "What have I gotten myself into". Every club should have an LS-4! Best tool ever for recruiting and member retention. In article , Jeff Runciman wrote: Hi guys, Thank you so much for your insights and advise. There is a local pilot that has an LS4, a little bit of crazing of the fiberglass. He hasn't flown in about 10 years. I am also looking at a brand new 15 meter SZD51-1 Junior. -- Take out the airplane for reply |
Eric Greenwell wrote:
Mark James Boyd wrote: And Jeff, keep in mind some of the performance is just from the retract wheel. Really I wouldn't buy into a fixed gear glider unless it was a Sparrowhawk. In the end, if the retract idea is scary, just leave the gear down! Tie-wrap it that way if you like! Believe me, you'll outgrow fixed gear quickly... THis might not be obvious, but a glider designed with fixed gear doesn't suffer the same performance penalty a retractable gear glider does when the gear is down. THe typical fixed gear does not extend as far from the fuselage as on a retractable gear glider, and it is faired in properly, so the drag is negligible at thermalling and moderate speeds and small at higher speeds. This is all quite true. A Russia with gear down will fly worse than a fixed gear Russia (at the same weight). I was really just making the point that if retract gear familiarity is the issue, it's certainly possible to fly for a while and get familiar with other aspects of the glider before mucking with learning the retract gear procedures... Because a nonretracting gear is typically on lower performance gliders, I think people come to believe it is a big performance liability. These gliders would still be lower performance with the gear tucked away. For example, note the small handicap difference between these two Russias (US handicap): AviaStroitel Russia AC-4A 1.193 (fixed gear) AviaStroitel Russia AC-4C 1.185 (retract gear) I disagree completely. Sure, the handicap difference looks small. This is bunk. There is a big difference in performance between these two gliders in even moderate (4 knot) conditions. And in wave or strong ridge lift? The polar at 80 knots is about 15% better for the retract. I'd be willing to bet that two evenly ranked pilots, one in each, would prove that the AC-4c is better. Swap them out every other day, and you'd see the AC-4c win a competition. I think the AC-4c is mishandicapped. It won Sport class at Avenal this year, and Chad Moore took third in a 2000 competition despite missing a day! You can make up for not having flaps to some degree by using ballast, but a big draggy tire (or TWO!) has no fix except gettin' it out of the wind...again, the Sparrowhawk may be an exception because adding the mechanism and space for retract might involve other needed changes that subsequently reduce performance... -- ------------+ Mark J. Boyd |
Wallace Berry wrote:
I've flown both. The LS-4s I have flown are easier and more pleasant to fly than the Junior I flew. I'll risk saying that the LS-4 is so easy to fly that it is almost boring. Very stable in all 3 axes. Darn near flies coordinated on it's own and requires very little input in thermals. The one Junior that I have flown is a fine ship except for a sticky rudder. As an aside, the PW-5 is a bit under-ruddered. Not much roll rate flipping into a thermal. -- ------------+ Mark J. Boyd |
Sport Pilot - School Won't Offer | Gary G | Piloting | 38 | February 16th 05 10:41 AM |
Bad publicity | David Starer | Soaring | 18 | March 8th 04 03:57 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
Restricting Glider Ops at Public Arpt. | rjciii | Soaring | 36 | August 25th 03 04:50 PM |
Announce/USA: FAA Glider Flying Handbook / Bob Wander | SoarBooks | Soaring | 0 | August 11th 03 03:55 PM |
