Jeff Runciman wrote:
Thank you again for your advise. Any more thoughts on the LS4? Any concerns with the age? What should I pay for one? And are there any flying groups for the LS4? Thank you again and I hope I can contribute to the group as I go along. It's good to see that we managed to convince you ![]() Waiting for your igc files on OLC! /Janos |
Thank you again for your advise. Any more thoughts on the LS4? Any concerns with the age? The LS 4 is one of the most docile gliders I've ever flown. In some European clubs it's even used as first solo training glider! The age is no factor, the shape it's in is. Later LS4s have authomatic hook ups, early ones don't, this should be reflected in the price. The LS 4 has two negative points: One is the bad surface quality. Depending on the use, they need a refinish rather soon. (In a club environment after 15 years or so.) So take a careful look. The second is the wheel brake. The wheel brake is a joke. This can be a problem if you have to outland in a short field. Stefan |
The wheel brake in my LS4 was also ineffective at first. Turns out all
I needed to do was a minor adjustment, and then you could put the glider on it's nose. Secondly, there is also the possibility of having the brakes modified (I believe by a motorcycle shop in California) that will make the drum brakes very effective. The LS4 was my first glider and a great one too. I couldn't have asked for better handling and docile stall characteristics. It's strong as hell, and the manually connected ailerons and spoilers were a snap. In fact it was easier and faster to assemble my LS4 than my second glider which was a Ventus that had automatic control hookups. You can't go wrong with a well cared for LS4. Stefan wrote in message ... Jeff Runciman wrote: Thank you again for your advise. Any more thoughts on the LS4? Any concerns with the age? The LS 4 is one of the most docile gliders I've ever flown. In some European clubs it's even used as first solo training glider! The age is no factor, the shape it's in is. Later LS4s have authomatic hook ups, early ones don't, this should be reflected in the price. The LS 4 has two negative points: One is the bad surface quality. Depending on the use, they need a refinish rather soon. (In a club environment after 15 years or so.) So take a careful look. The second is the wheel brake. The wheel brake is a joke. This can be a problem if you have to outland in a short field. Stefan |
I've been flying an LS-4 for the past two years. Everything said about
it in this forum is true -- it's a great first glider, responsive, forgiving, with excellent thermalling and Xcountry qualities. There's also a very good owners forum on Yahoo with lots of people offering helpful advice: http://sports.groups.yahoo.com/group/LS-gliders/ Negative points: Surface: Mine has some gelcoat degrading near the wing roots but I very much doubt if it affects performance much at all. I briefly considered refinishing (expensive) but then decided to live with it. Wheel brake: Admittedly not great, but there are ways to deal with it. Search for the brake discussion in the Yahoo forum. Tail wheel: A much more annoying problem in my estimation. In American versions of the LS-4, a wheel the size of an in-line skate wheel is mounted on a rubberized skid. DON'T ATTEMPT TO PUSH THE GLIDER BACKWARD WITHOUT THE TAIL DOLLY. The skate wheel will swivvel sideways causing all kinds of problems, the most serious of which is that the glider may run off the runway on tow unless the tail wheel is lined up carefully. I finally replaced the skate wheel with a decent sized tail wheel, and all the problems disappeared. Main wheel gas strut: When the gear is extended, it's locked in place by a gas strut. These struts weaken after a few years of use and must be replaced. Otherwise the gear may collapse on landing or (as mine did) on takeoff. By all means make this your first maintenance check if you buy an LS-4. The replacement strut is not particularly expensive, and it's a hellofalot cheaper than a belly job. Again, check the Yahoo forum for advice. Please don't be put off by these negative points. Every glider has its defects, but the LS-4 is a glider to love. |
I'm still building my experience before buying a first glider, and from
reading RAS over the past year or so, I've also concluded that an LS4 would be a great choice. Is there a newer model plane that people adore as much as an LS4 for its good balance of performance and behaviour? Thanks. Waduino. --- "Jeff Runciman" wrote in message ... Thank you again for your advise. Any more thoughts on the LS4? Any concerns with the age? What should I pay for one? And are there any flying groups for the LS4? Thank you again and I hope I can contribute to the group as I go along. Jeff |
Waduino wrote:
I'm still building my experience before buying a first glider, and from reading RAS over the past year or so, I've also concluded that an LS4 would be a great choice. Is there a newer model plane that people adore as much as an LS4 for its good balance of performance and behaviour? Thanks. Waduino. Discus2! /Janos |
![]() "Waduino" wrote in message ... I'm still building my experience before buying a first glider, and from reading RAS over the past year or so, I've also concluded that an LS4 would be a great choice. Is there a newer model plane that people adore as much as an LS4 for its good balance of performance and behaviour? Thanks. Waduino. Yes!.....HpH Glasflugel 304C! newer...(new) nicer quality, better performance, all automatic control hook-ups, better brakes, hinged panel, nicer cockpit, and even nicer handling, etc etc etc tim |
Waduino wrote:
Is there a newer model plane that people adore as much as an LS4 for its good balance of performance and behaviour? LS 8 |
Well if you are looking for an easy flying glider...you
can't go too far wrong with a Discus, it doesn't get the same rave reviews of handling like the LS4, but is still one of the nicest gliders I've ever flown and it is slightly newer without getting into the realm of Discus 2's, ASW28's and other really expensive modern German glass. Barn door airbrakes make field landings easy, decent enough wheelbrake, launches easy, docile stall, goes like the clappers and is forgiving of most indescretions in thermalling. At 13:06 10 September 2004, Waduino wrote: I'm still building my experience before buying a first glider, and from reading RAS over the past year or so, I've also concluded that an LS4 would be a great choice. Is there a newer model plane that people adore as much as an LS4 for its good balance of performance and behaviour? Thanks. Waduino. --- 'Jeff Runciman' wrote in message ... Thank you again for your advise. Any more thoughts on the LS4? Any concerns with the age? What should I pay for one? And are there any flying groups for the LS4? Thank you again and I hope I can contribute to the group as I go along. Jeff |
can't go too far wrong with a Discus, I couldnt agree more. We are using it as the first retractable club glider. We keep them in the trailer rather than the hanger as they are so quick and simple to rig. Typically we can rig all three using just the three pilots in 15 minutes. I think the wings are lighter than the LS4 as they have carbon spars. You can even buy them new still according to Schliechers web site |
Sport Pilot - School Won't Offer | Gary G | Piloting | 38 | February 16th 05 10:41 AM |
Bad publicity | David Starer | Soaring | 18 | March 8th 04 03:57 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
I wish I'd never got into this... | Kevin Neave | Soaring | 32 | September 19th 03 12:18 PM |
Restricting Glider Ops at Public Arpt. | rjciii | Soaring | 36 | August 25th 03 04:50 PM |
