Good point - here is a tad more detail.
Turn on the 302 and push the button to change the "screen" on the 302 display. 1 is mccready setting,etc. I think you need to go to screen 10, it's near the end. When you get to the right screen, twist the knob and along w/ showing you things like raw airspeed G sensor reading when you turn the knob far enough it will say either good or bad seal. You can get a "bad seal" if the case has been opened or perhaps if there is some internal electronic fault. Roy Bourgeois wrote: Joe: Go back to the 302 manual. It will explain that one of the screens is a security seal check. If you go to that screen and it indicates "Security Bad" the unit has to go back for a repair. Mine did it when new. Roy B. |
Mark Zivley wrote in message om...
Good point - here is a tad more detail. Turn on the 302 and push the button to change the "screen" on the 302 display. 1 is mccready setting,etc. I think you need to go to screen 10, it's near the end. When you get to the right screen, twist the knob and along w/ showing you things like raw airspeed G sensor reading when you turn the knob far enough it will say either good or bad seal. You can get a "bad seal" if the case has been opened or perhaps if there is some internal electronic fault. This isn't a valid check. The 302 screen may indicate "good seal" but the log security check can show fail. I had this problem with my 302. It requires the 302 to be returned for resealing. Note that this particlar problem causes log security fail for every download. If you are seeing a random security failure it could be a different problem. Andy |
GWB has been a good Commander-in-Chief | Horvath | Military Aviation | 112 | August 25th 04 12:00 AM |
16 Aug 2004 - Today’s Military, Veteran, War and National Security News | Otis Willie | Military Aviation | 0 | August 17th 04 12:37 AM |
For Keith Willshaw... | robert arndt | Military Aviation | 253 | July 6th 04 05:18 AM |
Showstoppers (long, but interesting questions raised) | Anonymous Spamless | Military Aviation | 0 | April 21st 04 05:09 AM |
