In article 5bs1d.43915$D%.38664@attbi_s51, Paul Remde
writes Hi, If the file is indicated as not secure when downloading with the PC utility the 302 is most likely not sealed. The status of the seal is displayed on one of the 302 LCD screens. I suggest you check that. If it is not sealed you will need to send it back to Cambridge to be re-sealed. Certain Cambridge agents can also carry out the re-sealing. These are not the normal sales agents, but those specially authorised by Cambridge to carry out modifications and other internal work on their recorders. Work that does not need to open up the sealed box, such as pressure altitude calibrations, is different and is carried out by any calibration organisation that is approved by the gliding NAC (SSA for USA, BGA for the UK). In general, the servicing agent authorised to work "inside" will check that nothing has been altered inside the box, run a check on the recorder unit, check internal connections etc for integrity, upgrade any firmware (if the customer wants this, always a good thing to do) and then the box is ready to re-seal. The agent contacts Cambridge and gets a special re-sealing code that will only work with that particular recorder. This is so that the code cannot be used again for a whole series of recorders. Other manufacturers have similar arrangements for secure re-sealing. I do not know what the situation is in North America, any work inside the sealed box (including re-sealing) may all have to be done at Cambridge itself at Horn Lake, MI. However, in the UK, RD Aviation (Oxford) and also Bicester Aviation Services (Bicester) are allowed to carry out internal work on Cambridge recorders, to avoid transatlantic travel for the recorder box. Similar arrangements exist for some other countries. I hope that puts the situation on re-sealing and servicing in perspective. -- Ian Strachan Chairman IGC GFA Committee |
GWB has been a good Commander-in-Chief | Horvath | Military Aviation | 112 | August 25th 04 12:00 AM |
16 Aug 2004 - Today’s Military, Veteran, War and National Security News | Otis Willie | Military Aviation | 0 | August 17th 04 12:37 AM |
For Keith Willshaw... | robert arndt | Military Aviation | 253 | July 6th 04 05:18 AM |
Showstoppers (long, but interesting questions raised) | Anonymous Spamless | Military Aviation | 0 | April 21st 04 05:09 AM |
