Hotellier connections
Old September 23rd 04, 06:34 PM
John Sinclair
Good post Stew, indeed winter is not too far away.
Automatic control hook-up's is the final answer, but
we still have a bunch of sailplanes out there without
the final solution. I have twice failed to hook up
the outboard flap connections on our ASH-25 (now sold).
Both times I was talking to someone and reverted to
my Nimbus 3, habit patern where there is only 2 connections
to be made, both after the wing is completely in place.
The ASH-25 requires the flap connection to be made
while the wing is about 2 inches from mating and then
2 more connections after sliding the wing all the way
into the inboard sections. In both cases, I found my
mistake in the PCC.
If I may start the winter season with a political remark,
How about adjoining jail cells for Martha Stewart ans
Dan Rather?
At 16:42 23 September 2004, Stewart Kissel wrote:
Ahhh, that fall season is upon us...as hours in the
air decrease, the semi-annual return of the PCC, PW5
and 2-33 threads reappear Other groups have guns,
religion and politics as their old standbys.
Although some might see Mark's post as a troll attempt...I
think he makes some interesting points. IIRC on the
HP site, an analysis was done that 1 in 1,000 hottelier
connections are done incorrectly...not sure how that
data was collected. Attitudes on PCC's seem to be
1.) I have done it safely for years, others should
be able too.
2.) I used to think (1.) until almost killed by disconnect.
3.) It's a crappy design and I ain't going near it.
I am a #3 guy myself.
At 02:42 23 September 2004, Mark James Boyd wrote:
I think the best way to do this isn't mirrors or safety
pins
or PCCs or bits of string or feel or training or flashlights....
I prefer a big ass port (or two) that lets you look
directly at
the entire connection from all sides.
If the designer made an ity-bity port, and you have
to rely
on a PCC because you can't see the dang connection
close up,
then that's just a crappy design. If the fuse is really
so flimsy the port has to be 5 inches wide instead
of 8 or 9 inches,
and it can't be right near the connection, then the
designer needs
to go to the drawing board.
The Pegasus elevator connection is out in the breeze,
and real easy to
visually inspect. If anyone ever failed a PCC of that
elevator
connection, I'd have to recommend they do the connection
inspection
next time with eyes open, perhaps with their bifocals
on, during
daylight hours.
I think the (over)emphasis on a PCC is bunk. The connection
inspection is the key. If I'm ever in a situation
where a PCC discovers something, I'll either not fly
that glider
again (the design doesn't allow good enough direct
connection
inspections) or I'll not fly ANY gliders (since I'm
too stupid
or too hurried to look right at a connection and determine
if it's
connected).
The exception to this is something like the bellcrank
failure that
happened last year to a dive brake during a PCC. No
connection
inspection is going to find that. But one wonders
if the
tens of thousands of PCCs CAUSED the failure itself,
by wearing
out the bellcrank faster...
Mark J. Boyd
Old September 23rd 04, 06:47 PM
Eric Greenwell
Dan Rather?
If we are going to jail people for using poorly authenticated
information, we could start at the top of the food chain, couldn't we?
Eric Greenwell
Washington State
USA
Old September 23rd 04, 07:07 PM
Mark James Boyd
Dan Rather?
Ohmigod...I saw "The Daily Show" with John Stewart on Comedy Central
yesterday. I had tears it was so funny.
I dunno if we could get him to do a show on Hotelliers, unless
their the Hilton sisters...
Mark J. Boyd
Dittel FSG40S wiring connections Anthony Manwaring Soaring 3 June 23rd 14 05:42 PM
Narco Com IIA Wiring connections? Rod Home Built 4 October 12th 11 07:08 AM
NEW - Exposing more on the Felony Fraud SwiftLiars Organized Crime connections Psalm 110 Military Aviation 0 August 21st 04 09:40 PM
NEW - Exposing more on the Felony Fraud SwiftLiars Organized Crime connections Psalm 110 Military Aviation 0 August 21st 04 09:39 PM
Denso alternator connections Paul Lee Home Built 2 July 6th 04 09:22 PM
