ILEC File Transfer with Pocket PC
Old September 27th 04, 08:32 PM
Kirk Stant
"Paul Remde" wrote in message news:YxL5d.117055$MQ5.57483@attbi_s52...
Hi Kirk,
We must be doing something differently because it didn't work well for you
and worked great for me. On Saturday I download a friends flight log from
his SN-10b using my iPAQ 3970 with PocketDOS and the HL utility from ILEC.
It worked perfectly. It downloaded the flight log in only about 1 to 2
minutes. However, the SN-10 then seemed to "think" for several minutes, but
eventually the SN-10 reported that the transfer was successful. My iPAQ
3970 is basically the same as the 3950 you are using.
Perhaps something was set differently in Pocket DOS? I tested PocketDOS
without buying a license initially but later bought a license. I think it
cost around $35. Without the license the software has some delays at
startup and other differences. Could that be the problem?
Paul Remde
Paul,
Not sure. I also bought the license, so it should be the same setup.
Like I said, I couldn't use the SD card, and that could be part of the
problem. I might play with it this winter some more.
Kirk
New File Library Email Service Tom Allensworth Simulators 2 July 19th 04 10:33 PM
WingX for the Pocket PC - Version 1.2 Hilton Software LLC Products 1 October 17th 03 01:38 PM
gpligc map file Mike Stramba Soaring 0 October 3rd 03 08:20 PM
Cross post - NASA/ARMY TRANSFER UNIQUE AIRCRAFT TO AIR AND SPACE MUSEUM Tim Luton Rotorcraft 0 September 11th 03 11:14 PM
WinPilot Now Supports Ipaqs with Pocket PC 2003 Ipaqs 2200, 5510, 5400, 5500 Series. rhpf Soaring 0 August 15th 03 01:21 AM
