Hi,
Several years ago a used a double pole-double throw switch to select between my GPS-NAV and Garmin 90 for input to my L-NAV. That way I gained access to the large Jepessen database when I was a long way from home. It worked great. However, the downside to using a switch is that RS-232 data lines are noisy and it would be difficult to shield the switch well (putting foil around it wont help). It may cause radio interference. Therefore, I don't really recommend it. Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com "tango4" wrote in message ... I do the same with my twin colibris. Just switch the tx and RX lines. No Problem Ian "Todd Pattist" wrote in message ... A friend has two Volksloggers, primary and secondary. The primary feeds data to his SN-10. The primary failed last weekend and he wants a way to switch the secondary to the SN-10 while in flight if it happens again. I suggested a simple double pole double throw switch to switch the TXD and RXD lines from the SN-10 between the primary and secondary VL's. Has anyone done this? Any problems? Thanks. Todd Pattist - "WH" Ventus C (Remove DONTSPAMME from address to email reply.) |
FS 2004 with multiple monitors - how to save settings? | Horst Walter | Simulators | 5 | December 8th 04 01:29 PM |
Airmen at Osan switching from M16A2 to lighter M4 carbine, By Franklin Fisher, Stars and Stripes | Otis Willie | Military Aviation | 0 | April 29th 04 04:07 AM |
Switching to ground.... | David Rind | Piloting | 85 | April 16th 04 06:53 PM |
Where is approach good about multiple approaches and clearances in the air? | Andrew Gideon | Instrument Flight Rules | 29 | February 14th 04 02:51 AM |
FS 2002 Multiple Monitors | Hugh Roberton | Simulators | 1 | September 22nd 03 01:49 PM |
