"WDM" wrote in message k.net...
Missing Brake Parts on Cobra Trailer My brakes have not worked on my Cobra trailer since I purchased it. It is probably 10 years old. I finally pulled the drums off and found all the internal parts missing. I assume that a previous owner went joy riding with the brake lever on. The brakes were probably burned up and then removed. I have no brake parts and corroded drums. I am looking for recommendations. Do I purchase parts and new drums or consider hanging a new axle with brakes under the trailer. Does anyone in the US still make axles with mechanical brakes? Should I convert the whole thing (axle and tongue) to hydraulic? Anyone every tackled this successfully? Thanks ** remove 55 to respond to email address directly ** Well, you could write to Spindelberger and give details of your trailer and they would probably be able to supply you with new wheel brake parts. On my Cobra trailer Spindelberger used Al-Ko (Kober) running gear, so you might also buy the parts from an Al-Ko dealer. Rudy Allemann |
molding plexiglas websites? | [email protected] | Owning | 44 | February 17th 05 09:33 PM |
Cleveland Parking Brake Parts | Jeff | Home Built | 2 | October 11th 04 10:38 PM |
Building the Po' Boy Bending Brake | Veeduber | Home Built | 14 | March 1st 04 06:15 PM |
COBRA TALON, COBRA SPOT | Allen Thomson | Military Aviation | 0 | December 9th 03 06:44 PM |
Brake caliper flange | Stealth Pilot | Home Built | 5 | July 7th 03 04:19 PM |
