Nimbus 21C instrument panel
Old October 11th 04, 06:16 PM
Bill Daniels
Default Nimbus 21C instrument panel
I'm planning the installation of a new Borgelt B50 to replace an old Pirol
vario. The Pirol used three 61mm holes so the 57mm B50 units won't fit nor
will the G meter I'd planned to add. Arghhhh!
So, new panel time. Anybody got a new or used panel laying around?
If not, my choices seem to be:
A. A new panel from Shempp-Hirth or
B. Have one custom made by an outfit like Panel Pilot or
C. Make one myself.
I've made several panels and they are a LOT of work with a risk that the
part will be ruined at the last moment by the slip of a drill point. (been
there - done that)
Bill Daniels
Old October 11th 04, 08:48 PM
Tim Mara
easiest and best material to use is plain Phenolic sheet material.machines
easily, can be cut with a bandsaw or even saber saw, drills easily, sands
easily and comes in a variety of colors and base materials.....
I've made dozens of instrument panels from this material and can knock out a
simple flat panel like the Nimbus types easily in an evening with a band saw
and drum sander.....a flat sheet large enough for a Nimbus panel should cost
no more than about $20.00!
see www.mcmaster.com
page 3341
tim
www.wingsandwheels.com
"Bill Daniels" wrote in message
news:eezad.347181$mD.247702@attbi_s02...
nor
C. Make one myself.
(been
there - done that)
Bill Daniels
Old October 11th 04, 09:14 PM
Bill Daniels
"Tim Mara" wrote in message
a
saw
cost
page 3341
tim
That's an interesting idea. However, looking at the original panel which is
heavy 3.5mm alloy, I suspect that it also serves as a stiffening bulkhead
for the cockpit area. I think I will stick with aluminum.
Bill Daniels
Old October 11th 04, 11:06 PM
Tony Verhulst
What's the failure mode of this material in a crash, for instance. I
recall long sharp pieces but could be wrong.
Tony V.
Old October 12th 04, 04:20 AM
Tim Mara
really depends on how large the panel is and how well it's supported, but
typically the 1/8" is plenty.......but use the fiberglass material, not the
canvas or cotton, it is stronger
tim
"Todd Pattist" wrote in message
page 3341
Tim,
What thicknesss do you use for a Phenolic sheet panel?
Todd Pattist - "WH" Ventus C
(Remove DONTSPAMME from address to email reply.)
Old October 12th 04, 04:25 AM
Tim Mara
is
I can't say for sure..but I honestly doubt this
I think aluminum will be more vicious in a crash........the fiberglass
phenolic sheet is very strong, but can break and would break at the thin
areas between the instrument holes in a violent crash.the metal probably
would not but could go through you instead.....for this reason I think
you'll find no more new gliders made with metal panels
tim
Bill Daniels
Old October 12th 04, 04:33 AM
Tim Mara
see my last post.......Phenolic sheet is essentially a fiberglass (could be
other base materials like cotton or canvas, paper ect) panel as used in most
if not all new gliders..you could use the canvas or cotton based phenolic
sheet as well....it is not as sturdy as the fibergass sheet but ceratinly,
if used in the right panel types would be strong enough (you'd want a bit
more "meat" between the instrument openings) and I have used this material
also for more basic panels like in vintage ships and this type phenolic does
break more cleanly....the material is quite inexpensive and you could try
some samples for yourself. Since many gliders are already experimental as
was the one I believe that started this thread, it could be used without
having to be a certified part.
tim
"Tony Verhulst" wrote in message
Tony V.
Old October 12th 04, 02:11 PM
John Sinclair
A trick I picked up on, a few years back was to take
the face from a junk instrument (57 & 80mm) and use
it as a template. I use them to mark the location of
all instruments and after cutting the holes with circular
saw in the drill press, I use my templates as a guide
when drilling the instrument mounting holes.
BTW, most instrument panels are quite weak without
the instruments, but regain their strength through
the installed instruments. In most crashes, the sides
of the cockpit bulge out, so consider the strength
the instrument panel will provide to resist this bulging
out movement.
JJ
Old October 12th 04, 02:51 PM
Tim Mara
I've used hole saws myself.these are hard to find in 57mm (2.25") and 80mm
(3.125") but again... www.mcmaster.com
had these and you won't find these sizes in the Home depot or other common
local stores....though these were expensive...
I use the hole saws then placed metal instrument hole reducers (I have
these) over the hoe and finished with drum sanders (you can buy these at
local stores) for final fitting.I also use a dremel type tool with small
sanding drums for the cutouts for altimeter adjusters etc..all these tools
work amazingly well in Phenolic sheets.I am sure good sharp router bits will
also work well though I haven't needed to sue these....having a good drill
press is necessary to use the hole saws though and a real aid with the drum
sanders as well..gives you a good excuse to own these tools )
tim
Thanks. When I've made panels, I've used a router and
template. I mark the center of the instrument holes I want.
Then I use an undersized hole saw to get close to the
instrument hole size needed, then clamp the template to the
sheet, drill the mount holes through the template mount
holes, then use the router to enlarge the undersize main
hole and get good clean edges and the final exact shape and
size instrument hole needed. Will a router give a good
clean edge on Phenolic sheet?
Old October 12th 04, 09:56 PM
Eric Greenwell
is
Typically, the new designs have panels that rise so it's easier to bail
out, so the panel doesn't contribute to strength in any way. They also
have markedly stronger edges along the canopy opening for crash
protection. An old design like Bill's might use the panel to prevent the
sidewalls from bending out in a crash. The designer or factory is most
likely to know this, and I'd suggest contacting them about the proper
material.
Eric Greenwell
Washington State
USA
Instrument Checkride passed (Long) Paul Folbrecht Instrument Flight Rules 10 February 11th 05 02:41 AM
Instrument panel labelling options John Galban Home Built 12 November 18th 04 10:42 PM
Logging approaches Ron Garrison Instrument Flight Rules 109 March 2nd 04 05:54 PM
PC flight simulators Bjørnar Bolsøy Military Aviation 178 December 14th 03 12:14 PM
CAD outline of Rans S6S instrument panel? Rob Turk Home Built 2 October 21st 03 09:27 PM
