Gerhard Wesp wrote:
nafod40 wrote: Interesting observation. Flying in ground effect places the center of pressure of the wing at about mid-chord, while out of ground effect the Are you sure? Note that a forward CG implies a pitch down moment which would have to be compensated by negative lift on the tail. Hence performance degradtation, contrary to what ground effect is supposed to create. That part would be minor, more than compensated for by decrease in induced drag and increase in lift. I'm still searching for a good explanation of ground effect :-) Here's a killer page describing the aerodynamics of it. Follwoing is a short excerpt from the page. http://www.se-technology.com/wig/htm...en=aero&code=0 Two phenomena are involved when a wing approaches the ground. Ground effect is one name for both effects which is sometimes confusing. The two phenomena are sometimes referred to as span dominated and chord dominated ground effect. The former results in a reduction of induced drag (D) and the latter in an increase of lift (L). The overall effect is an increase of the L/D ratio. This ratio is a measure for the efficiency of an aircraft which can be expressed as the amount of power (thrust) that is required to propell an aircraft of a certain weight. Since thrust is equal to drag and weight is equal to lift in stationary flight this efficiency can be expressed as the L/D ratio. As the L/D of a wing increases with decreasing ground clearance the craft becomes more efficient in ground effect. |
The Meredith Effect | Corky Scott | Home Built | 19 | September 4th 04 04:01 PM |
Toronto Area Glider Pilot Ground School Starts Thu. March 25, 2004 | Ulf | Soaring | 0 | March 3rd 04 05:02 PM |
Wing in Ground Effect? | BllFs6 | Home Built | 10 | December 18th 03 05:11 AM |
Why did Britain win the BoB? | Grantland | Military Aviation | 79 | October 15th 03 03:34 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
