![]() But, what I was getting around to saying is your comment - The average 45 degree bank thermalling turn takes about 13 - 14 seconds may be true for you, but not most pilots, based on my observations in sport and contest flying, where 22+ seconds is typical. Maybe you meant your average turn? Nope, I meant my standard thermalling turn in the Nimbus is 14 seconds, 45 degrees and 45 MPH. If the core is small, I'll tighten up to a 60 degree bank and 48mph. Ballast will, of course, bump those numbers up a little. Eric, I think your turns are way too shallow and fast to make use of the strong cores. Bill Daniels Eric &Bill If a stall speed of a glider is 36 kt at a wing loading of 6 lb/sq/ft in a 45 deg. it will be about 44 kt and at a 60 deg bank it will 50kt. With a loading of 9lb/sq/ft the stall speed will be 44kt at a 45 deg bank it will be 53kt and at a 60 deg bank it will be 61 kt. I do not know what your respective wing loading are but both of you could be right. It is more beneficial to turn tighter with a lighter wing loading , then it is with a heavier wing loading. Regards Udo |
Udo Rumpf wrote:
Eric, I think your turns are way too shallow and fast to make use of the strong cores. Bill Daniels You might be right, but I'm not routinely outclimbed by other pilots wherever I fly, even by US World team members, so experience suggests I'm not too far off the mark. I do try tighter banking occasionally, and sometimes it helps, but it usually not, so the 40 degree bank is what I normally end up using. Perhaps you are circling more tightly than needed, your thermals are much smaller than the ones I encounter, or as Udo suggests, it's the wing loading difference. Or all items... It would be interesting to look at the circling times of good contest pilots using contest flight files, or perhaps the OLC files. Circle time (our primary parameter in the discussion) and circle diameter can be obtained directly from the flight trace, the true airspeed can be determined by noting the highest and lowest ground speeds during the circle and taking the average. These can be plugged into Frank's web calculator to get the bank angle. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Eric Greenwell wrote:
Udo Rumpf wrote: Eric, I think your turns are way too shallow and fast to make use of the strong cores. Bill Daniels Ooops! The above was written by Bill, not Udo, as I accidentally replied to the wrong posting. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
OK, this is going to get good.
Eric thinks wide fast turns work best for him. I think 45 degree turns are best on average with steeper turns useful in small cores. If fly as slow as I can without risking a stall. Lets have a poll. Tell us how you thermal. Bill Daniels |
Bill,
I try to fly, if the conditions warrant it, a 45 deg. bank my wing loading is 8.3 lb/ft/sq at that bank my turn will be 22 seconds. My speed will be 52 kt. indicated. Udo PS. I will check some of my contest recordings to make sure my memory is still ok. Also I open up the turn when more lift is indicated and tighten when less lift. I use the Borgelt and I react to the trend, that is when the needle or sound just start coming out of the bottom or falling off. Works for me like a charm. Udo "Bill Daniels" wrote in message news:2bidd.499463$8_6.239366@attbi_s04... OK, this is going to get good. Eric thinks wide fast turns work best for him. I think 45 degree turns are best on average with steeper turns useful in small cores. If fly as slow as I can without risking a stall. Lets have a poll. Tell us how you thermal. Bill Daniels |
Bill,
a small correction, wing loading remains 8.3 lb/ft/sq, average time around the circle 25 second at 50 kt Ground speed. Bank of between 40 and 45 deg. I use the Instrument screws as reference. I have a number of recordings. If any body cares to look at them let me know and I will send an http. Udo Bill, I try to fly, if the conditions warrant it, a 45 deg. bank my wing loading is 8.3 lb/ft/sq at that bank my turn will be 22 seconds. My speed will be 52 kt. indicated. Udo PS. I will check some of my contest recordings to make sure my memory is still ok. Also I open up the turn when more lift is indicated and tighten when less lift. I use the Borgelt and I react to the trend, that is when the needle or sound just start coming out of the bottom or falling off. Works for me like a charm. Udo "Bill Daniels" wrote in message news:2bidd.499463$8_6.239366@attbi_s04... OK, this is going to get good. Eric thinks wide fast turns work best for him. I think 45 degree turns are best on average with steeper turns useful in small cores. If fly as slow as I can without risking a stall. Lets have a poll. Tell us how you thermal. Bill Daniels |
Bill Daniels wrote:
OK, this is going to get good. Eric thinks wide fast turns work best for him. "Fast" is relative: at 8.2 lb/sq ft, going a slower is counterproductive. I can slow down to 45 knots from the usual 50, but the glider isn't very steady, feels "draggy", and it doesn't climb any better, even in very smooth thermals (this measurement done when circling with other gliders). In anything but very smooth thermals, the 50-52 knots is needed to have decent control, anyway. I think 45 degree turns are best on average with steeper turns useful in small cores. If fly as slow as I can without risking a stall. This may be appropriate for the Nimbus 2, but not for the ASH 26, where the stall is noticeably lower than minimum sink. Waibel told me once that he considers this a safety feature. Lets have a poll. Tell us how you thermal. And what, and where. These are likely important reasons for your bank angle and speed preferences. Bill Daniels -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
![]() "Eric Greenwell" wrote in message ... Bill Daniels wrote: OK, this is going to get good. Eric thinks wide fast turns work best for him. "Fast" is relative: at 8.2 lb/sq ft, going a slower is counterproductive. I can slow down to 45 knots from the usual 50, but the glider isn't very steady, feels "draggy", and it doesn't climb any better, even in very smooth thermals (this measurement done when circling with other gliders). In anything but very smooth thermals, the 50-52 knots is needed to have decent control, anyway. I think 45 degree turns are best on average with steeper turns useful in small cores. If fly as slow as I can without risking a stall. This may be appropriate for the Nimbus 2, but not for the ASH 26, where the stall is noticeably lower than minimum sink. Waibel told me once that he considers this a safety feature. Lets have a poll. Tell us how you thermal. And what, and where. These are likely important reasons for your bank angle and speed preferences. I just examined some IGC traces of mine and, correcting for density altitude, the IAS was about 43 mph in what looks like a 40 - 45 degree bank. I'm still looking for a representative climb in a small, strong core but I think I should have one from Moriarty, NM. The Nimbus 2C ailerons become very ineffective at low IAS but it still responds nicely to rudder inputs. I use Dick Johnson's slipping turn so the ailerons stay neutral and I fly the bank with rudder. The big glider is very stable in slow turns. If there's a strong core, I'm not concerned with sink rate in slow, steep turns. The strength of thermal cores will easily offset that. Bill Daniels |
I don't believe in a shallow bank for 180 degrees. The trade off in efficiency is more than offset by getting out of the sink and into the lift quicker. Reichman's rules: Increase bank in sink, shallow bank as vario rises, increase bank in lift. My numbers say min sink is 44 ktws, 30 degree min sink is 49, 45 is 52, and 60 is 63 kts. If themals are tight and narly, then crank 45-60, decreasing with altitude as thermals generally widen. Like many here, the screws on the instruments are the 45 degree indicator (a golden nugget from a CSA instructor). I would rather increase my airspeed than shallow the bank since the increase in airspeed effectively increases the turn radius with minimal drag effects and low time lag. To me, crankin and bankin to get into the best lift is worth it...plus much more fun! Jim Vincent N483SZ illspam |
![]() "Bill Daniels" wrote in message news:2bidd.499463$8_6.239366@attbi_s04... Lets have a poll. Tell us how you thermal. Bill Daniels I do whatever it takes to make the averager number bigger! What that might be depends on whether I am at Truckee or Ely or Williams; whether the lift is turbulent or smooth, big or small core, alone or with other gliders, with or without water, bugs on the wings, etc. The correct bank angle and speed might change from one side of the circle to the other and is changing, experimenting, trying to iterate the best possible lift. When I see another glider climbing better in another part of the thermal, I just go there! It really matters that the climb rate is as high as possible in each climb taken. When I fly with others in our DuoDiscus I am amazed at how carefully many pilots follow the speed director (which is on a 30 second averager) in cruise, but climb sloppily and lazily, accepting whatever comes and not actively searching for the best thermals and using them to the max. Maximizing climb and avoiding sink are the best ways to cover miles (or km.). Interthermal glide speeds are relatively unimportant. Of course, most of this is just experience -- many hours of flying and thermalling -- and better learned in thermals than on Usenet... -Bob Korves 5H DuoDiscus 5K LAK-17a |
Themi thermal locator | John Jones | Soaring | 5 | April 30th 04 04:16 AM |
For Auction: Thermal Imaging Camera - One Day Left | sell2all | Rotorcraft | 0 | April 29th 04 08:29 PM |
For Auction: Thermal Imaging Camera - One Day Left | sell2all | Military Aviation | 0 | April 29th 04 06:45 PM |
Spin on thermal entry - how-to | Bill Daniels | Soaring | 0 | January 29th 04 05:43 PM |
Thermal to Wave contact! | C.Fleming | Soaring | 1 | January 21st 04 01:54 PM |
