H201 Libelle and wing dropping
Old October 25th 04, 09:50 PM
Bob Salvo
"Wallace Berry" wrote in message
One thing I forgot to
mention, my Libelle only has the CG hook, the nose hook having been
glassed over by a previous owner. Because of this, the tail on my 301
tends to stay down a bit longer than one being towed by the nose hook.
With a long rope, negative flap and the stick forward, I've done
unassisted takeoffs with no trouble. Haven't tried that with a strong
crosswind.
Using the nose hook will reduce the tendancy for wing drops.
Bob Salvo
Old October 25th 04, 10:53 PM
Bill Daniels
"Bob Salvo" wrote in message
Bob Salvo
Really? Why?
Bill Daniels
Old October 26th 04, 03:51 AM
Bob Salvo
Bill,
Not sure, but when I sealed over my nose hook on the H301 and used the CG
hook for aertow, I had more trouble keeping a wing from dropping. I think
when the CG hook is used and there is a wind gust from the side at the start
of launch, there is more tendancy for the tail to swing, which usually
produces some roll. Using the nose hook, which is well in front of the
wheel, reduces the tendancy for a swinging tail. Another interesting thing
I found about using the nose hook is that if the ship happens to vere
towards, say the left, and the left wing starts to drop, the pull force of
the tow rope will try to roll the ship, lifting the wing. I believe this is
because of the larger moment arm (height) between the nose hook and the
pavement. On the other hand, the CG hook is a very close to the pavement,
so there is very little moment force to assist in rolling the ship back to
level. Of course, this could be a disadvantage if the roll force caused by
the tow is holding the wing down. But there are some cases when a wing
drops that releasing is the best thing to do. BTW when using the CG hook
(when there is little rolling force from the tow), I have found that the use
of rudder to pick up a wing works very well if I rudder (turn) towards the
wing that drops. When the ship is forced to turn in the direction of the
dropping wing, the ship will roll to bring the wing back up. Its like
riding a bicycle: if you happen to start falling to the left, you should
steer to the left, otherwise you will fall over. I'm sure that there are a
lot of pilots out there that don't believe this, but that's OK; this method
works for me.
Bob Salvo
"Bill Daniels" wrote in message
news:MBefd.247116$wV.107530@attbi_s54...
Bob Salvo
Really? Why?
Bill Daniels
Old October 26th 04, 04:18 AM
Bill Daniels
I honestly can't tell any difference. I've made turning takeoffs so as to
be able to stage off the side of an active runway where the fuselage at the
start of the roll was 30 degrees to the runway centerline. My Nimbus 2C
with a CG hook just tracks where I want it to.
I have no interest in adding a nose hook. I don't think it's a big deal.
Like all tailwheel gliders I try to hold the tailwheel down hard until I get
some rudder control then I lift the tail and just steer it where I want to
go. I use the ailerons aggressively right from the start to hold the long
wings level.
The CG hook doesn't help, but it doesn't hurt either. There have been many
millions of winch launches with CG hooks with no systemic problem with wing
dropping.
Bill Daniels
Bill,
start
thing
is
by
use
a
method
works for me.
Bob Salvo
Bob Salvo
Really? Why?
Bill Daniels
Old October 26th 04, 06:37 AM
Eric Greenwell
wings level.
dropping.
There wouldn't be any with the nose hook, either, since most of the wing
dropping is due to towplane wake which isn't present with a winch, and a
smaller number due to slow acceleration (I'm guessing more winches
provide good acceleration than towplanes).
My experience, and that of many others, is gliders with long wings or
water ballast are less likely to drop a wing, simply because of inertia.
Nose hooks are a proven advantage over CG hooks for aerotow, but not
primarily for wing dropping reasons; of course, the size of the
advantage varies with the glider and the pilot.
Eric Greenwell
Washington State
USA
Elevator Turbulator tape question JJ Sinclair Soaring 39 October 17th 03 02:35 PM
