flatlets
Old October 27th 04, 04:53 PM
CV
Default flatlets
Another aerodynamic bone to toss around and chew on:
Instead of carefully crafted, expensive winglets, wouldn't
straightforward flat end plates serve nearly as well in
reducing wingtip vortices and improve performance.
Have they ever been tried, and with what results ?
CV
Old October 27th 04, 05:18 PM
Bill Daniels
"CV" wrote in message
CV
Wing end plates were a big fad in the early 1950's. It was found that the
same or better improvement could be obtained by simply adding the same area
to the wingtip as additional wingspan.
Messing with wingtips has a long and somewhat eccentric history. They have
been bent up and down, swept forward and back, made wider and narrower,
sliced off at an angle or square, slots added and removed. Until Whitcomb
developed winglets, everything else people tried had a huge drag penalty.
Airflow around the wingtip is complicated. You really have to understand it
to extract any gain.
Winglets produce a real gain especially if the glider must remain within a
span-limited competition class. They have the advantage of increasing the
lift inboard of the winglet without increasing the bending force on the wing
as much as additional span would. They also convert some of the energy in
the wingtip vortex into thrust which is seen as a general drag reduction in
the wingtip area. Think of the winglet as a sailboat sail that catches some
of the inward flow on the upper surface and converts it into thrust.
Bill Daniels
Old October 27th 04, 05:46 PM
Here is an article about the successful addition of wing tip stall fences:
http://www.soaridaho.com/Schreder/HP...ng_Fences.html
CV
Old October 27th 04, 05:47 PM
Bob Kuykendall
Earlier, Cv wrote:
...Instead of carefully crafted, expensive
winglets, wouldn't straightforward flat end
plates serve nearly as well in reducing
results ?
Dick Schreder tried some fairly simple endplate type
winglets on the HP-18. They didn't work very well.
Winglets must be carefully designed and executed, otherwise
they are more likely to reduce performance than improve
it. The flows in the tip vortex call for carefully
optimized planform and twist distribution.
Based on the winglet design that Steve Smith did for
my HP-24 wing, I think that it is generally possible
to develop winglets that are fairly simple in geometry
and construction, and that are not very expensive in
terms of materials. However, they would still have
to be carefully made, and that's usually where the
money goes.
Thanks, and best regards to all
Bob K.
http://www.hpaircraft.com/hp-24
Old October 28th 04, 01:29 AM
Bob Salvo
Has anyone tried this? http://www.minix.fr/
Bob Salvo
"Bill Daniels" wrote in message
news:zTPfd.321990$3l3.156113@attbi_s03...
CV
area
have
it
wing
in
some
Bill Daniels
Old October 28th 04, 01:57 AM
Bill Daniels
Like I said, wingtips are a magnet for eccentric aerodynamics (and
aerodynamisysts).
One I particularly liked was a ram air turbine that popped out of the
wingtip when needed. It spun like a pinwheel in the tip vortex. The
inventor claimed it generated electricity from energy that would have been
wasted.
At about the same time as the red smoke photo shown on the minix site was
taken, I was working on a similar project to get some good air velocity
measurements in a wingtip vortex. Our idea was to fly an airplane through a
cloud of small helium balloons and track their 3D motion with an array of
35mm film cameras known as cine-theodolites.
As expected, the balloons became entrained within the vortex flow. What we
didn't expect was that the balloons spiraled inward to the vortex center in
a plane at right angles to the vortex axis. (The lighter than air balloons
were moving up the air density gradient.) When they reached the vortex
core, they raced away after the airplane in two parallel streams. The
balloons were moving at more than half the speed of the airplane. It was
fascinating to watch and we got some good data.
Bill Daniels
"Bob Salvo" wrote in message
news
Bob Salvo
CV
area
have
Whitcomb
penalty.
understand
it
a
wing
in
in
some
Bill Daniels
Old October 28th 04, 04:18 AM
Stewart Kissel
I have seen a couple of versions of those things kicking
around the web...if us colonials can get over the 'freedom
fries' syndrome and overcome the lack of sexiness with
them...they apparently will do the same thing as winglets.
Bob Salvo
'Bill Daniels' wrote in message
'CV' wrote in message
on:
wouldn't
in
CV
adding the same
area
history. They
have
wider and narrower,
have to understand
it
of increasing the
wing
in
sail that catches
some
it into thrust.
Bill Daniels
Old October 28th 04, 12:38 PM
CV
Yes, all I can see is the following text:
Cet espace de 20mo a été acheté sur ovh.com
Ce fichier s'appelle index.html
CV
Old November 10th 04, 05:16 PM
Robert Ehrlich
I don't think so. On the web site they are shown applied only
on airplanes with low aspect ratio, where anything would anyway
provide a higher improvement than on a high aspect ratio
wing as on a glider. And glider have to otimize both climb and
cruise. The minix doesn't seem to be well suited to the wide
range of angles of attack implied by this. An improvement for
climb, where induced drag is the most important, will probably
payed by an increased drag in cruise. And I am not biased by
the 'freedom fries' syndrome!
