Aerotow with Diesel engine?
Old October 30th 04, 07:38 PM
Bob Salvo
Why not two winches; one to launch with and the other to retrieve the cable?
I think I remember this being done years ago. If the drag chute is big
enough, the retrieve winch should be able to return the entire cable. I
wonder how fast two setups (4 winches) could launch a fleet?
"F.L. Whiteley" wrote in message
"Kirk Stant" wrote in message
om...
(Mark James Boyd) wrote in message
news:41818652$1@darkstar...
Steve Hill wrote:
I'd really like to see what the actual costs are for a club to
purchase
a
good winch.
The "street" has spoken. There are NO winches in California.
And the ones I researched that were closest were in Arizona or
Washington, and aren't getting anywhere even remotely close to
50 launches a day.
I haven't been to Washington yet, but I have talked to the club there
and they were closed for a good part of last winter (0 launches).
Would a winch in CA do well? I dunno. At Avenal, there are
days when it would be fine, but then again there are
a lot of days or times of the day when a higher tow or further
away is better. And of course I've had 4 aero-retrieves.
Try that with a winch
The Prescott (AZ) Soaring Club does well with their winch, apparently.
Down here where I usually fly at Turf (just west of Phoenix), we
rarely aerotow higher than 1500', I think my usual release altitude is
about 1200' just off the end of the runway into the house thermal -
ideal for a winch! Of course, this makes for a pretty quick cycle
time with a couple of Pawnees, and we would really need a double or
triple drum setup to get a race grid off rapidly, but it sure would be
fun to watch!
Kirk
66
A single drum winch is the poorest of compromises in effeciency with only
cost being the overriding factor. There is simply no reason to drag one
rope at a time and doing so can make the entire process more tedious and
dampen enthusiasm. Only one thing matters to private owners on the
ground,
and that's launch rate. For wide adoption, a two drum winch works well.
For a large operation, two two-drum winches provide high availability and
redundancy, portability is off-site operations are anticipated.
Frank
Old October 30th 04, 08:08 PM
F.L. Whiteley
It's doable and is done at the Long Mynd, Midland GC,
http://www.longmynd.com/ along with bungee launching.
Spectra's 'float' might make work pretty well on a long run.
Frank Whiteley
"Bob Salvo" wrote in message
cable?
om...
purchase
a
good winch.
50 launches a day.
there
fun to watch!
Kirk
66
only
ground,
and
Frank
Old November 1st 04, 05:18 PM
Mike Lindsay
In article , Bob Salvo
writes
This is the set up the Midland Gliding Club has used for at least 30
years, the two cables join in a device that used to be an iron triangle,
but the present gizmo is a lot lighter.
It gives a very good launch rate with an experienced driver on each
winch.
But its not universally suitable...
Mike Lindsay.
Smart CDI diesel engine Hans Zwakenberg Home Built 14 January 9th 05 12:32 PM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 06:42 PM
Diesel engine Bryan Home Built 41 May 1st 04 07:23 PM
Emergency Procedures RD Piloting 13 April 11th 04 08:25 PM
Autorotation ? R22 for the Experts Eric D Rotorcraft 22 March 5th 04 06:11 AM
