In article , Todd Pattist
writes I've also had some pilots tell me they were trained years ago to use a standard compass That is, an old fashioned one with pendulous suspension of the magnet assembly. This type of compass has acceleration errors on east and west and turning errors on north and south. What may be an "error" in terms of registering an accurate instantaneous heading, might be turned to advantage in a case of total failure of gyro instruments. With great caution, of course, and IMHO not the best answer, see below. , head south It is true that a pendulous compass has turning errors on South, and could be used a sort of turn indicator on that heading. and steer with rudders. No! A good way to get disorientated, IMHO. What is wrong with turning in the normal way, application of (in this case) small amounts of bank where necessary. Fly gently, don't get used to coarse use of unnecessary control inputs. Particularly boots of rudder un-coordinated with aileron, unless you wish to spin or do aerobatics, of course!. However, to stay alive in instrument flying, particularly in turbulence, there is no substitute for proper aircraft-designed gyro instruments. I taught and examined on what we used to call "limited panel" for many years, AND IT WORKS, with a bit of practice. That is, instrument flight using a good old Sperry turn gyro presented through a needle display ("needle, ball, airspeed ... needle, ball, airspeed"). Turn gyros take little power and normally run on DC, so are well suited to glider use. People say that instrument flight using only a turn needle is difficult, But at least it is designed for the job, unlike pendulous compasses, GPS presentations etc. And what is difficult is limited-panel accurate pattern turns, approaches etc., with an examiner breathing down your neck! Merely keeping the wings about level so as not to enter a spiral dive, is not difficult. On a safe heading, of course, that is away from known high ground. Try it in a two-seater with a safety pilot, but make sure that you are really "under the hood" and are not peeping out to see the horizon, otherwise you are not really getting proper training that might get you out of trouble later. The dear old Link Trainer was pretty good for this training also, but there aren't many about now except in museums! Of course even better if your glider has a gyro-driven Artificial Horizon as well as that rate-gyro. Makes instrument flight for those not in practice, including me nowadays, reasonably straightforward. -- Ian Strachan Lasham Gliding Centre, UK |
Ian Strachan wrote: Merely keeping the wings about level so as not to enter a spiral dive, is not difficult. On a safe heading, of course, that is away from known high ground. Try it in a two-seater with a safety pilot, but make sure that you are really "under the hood" and are not peeping out to see the horizon, otherwise you are not really getting proper training that might get you out of trouble later. It's amazing how hard it is to get *true* no-visual-reference conditions in IMC. I've done some flying with a commercial pilot friend doing night freight runs in small turboprops. Even in the clouds in the middle of nowhere in NZ you can almost always see some speck of light out of the corner of your eye, whether a farmhouse or a star, and that gives you roll information even when you're not looking at the AH. You don't realize how much this helps until the first time there really *is* nothing out there. -- Bruce | 41.1670S | \ spoken | -+- Hoult | 174.8263E | /\ here. | ----------O---------- |
In article , Bruce
Hoult writes It's amazing how hard it is to get *true* no-visual-reference conditions in IMC. I've done some flying with a commercial pilot friend doing night freight runs in small turboprops. Even in the clouds in the middle of nowhere in NZ you can almost always see some speck of light out of the corner of your eye, whether a farmhouse or a star, and that gives you roll information even when you're not looking at the AH. You don't realize how much this helps until the first time there really *is* nothing out there. A reference if you are rolling but for a controlled descent you do not want to be rolling. More important, what about horizon reference? I have often seen "false horizons" in cloud layers and at night. They can be very disorientating. For instance, I got severe "leans" once when coming off a tanker at night when the lit tanker was in a turn. And several times when between slanting cloud layers. Not a glider case, of course, but "beware the false horizon" and "believe the turn needle" would appear to be good guidance! Incidentally the title of this thread uses the word "benign". An accelerating spiral in a slick glider can be anything but benign. It is not difficult, I imagine, to literally pull the wings off in an attempt to recover. The rule on "limited panel" unusual attitude recoveries was "don't pull until you have the turn needle within about Rate 1 of the centre of the instrument. -- Ian Strachan Bentworth Hall West Tel: +44 1420 564 195 Bentworth, Alton Fax: +44 1420 563 140 Hampshire GU34 5LA, ENGLAND |
Bruce Hoult wrote:
It's amazing how hard it is to get *true* no-visual-reference conditions in IMC. I've done some flying with a commercial pilot friend doing night freight runs in small turboprops. Even in the clouds in the middle of nowhere in NZ you can almost always see some speck of light out of the corner of your eye, whether a farmhouse or a star, and that gives you roll information even when you're not looking at the AH. You don't realize how much this helps until the first time there really *is* nothing out there. There have been an amazing number of Navy pilots that have flown into the water as they mistaked boat lights for either stars or an aircraft they were joining on. I know, not pertinent to gliders, but the optical illusions of sort of IMC/VMC can be intense and almost more disorienting. |
nafod40 wrote:
There have been an amazing number of Navy pilots that have flown into the water as they mistaked boat lights for either stars or an aircraft There are libraries full of books about wrong visual clues: Houses on a hill taken for stars, a street taken for a shore line, wrong perspectives, wrong distances, wrong altitude, etc. etc. etc. I'm always amazed that there would still be pilots who believe they are smarter than those who contributed to this knowledge with their blood. If in IMC or at night, believe your instruments and nothing else. If your aircraft (glider) is not adequately equipped, avoid clouds. This can be done! There is no such thing as "trapped" by a layer if you act as you should. If you feel like cloud flying, equip your glider accordingly and learn how to use the gauges. Stefan |
I could never get my ASW-20B to do a benign spiral. I tried many times
over a period of sixteen years and 2000 hours with flaps, spoilers, gear, trim and CG in various positions. My technique was to set up the configuration, then upset the attitude a bit the way rotor cloud turbulence would, and then hands and feet off. It always would begin with small "zoomies" which got bigger and bigger until I was forced to take control to save my life. My '20 was also the only glider (or throttled back power plane) that I ever flew which was uncontrollable with the stick against the aft stop. With every type but the '20 I could very slowly ease the stick aft until it hit the stop and then control it indefinitely with coarse use of aileron and rudder as it waffled downwards. Not the '20. Very quickly it would tell me that I better push forward or it was going to self destruct. The exception was in a very steep bank, 50 or 60 degrees, doing 10 second circles and pulling about 2 g's. I loved my '20 - a wonderful airplane. There must be other types out there with the same characteristics but I never came across one. This winter while I'm floating around the skies in Florida I'll try out my '27 and see what it does. Walter |
Walter Weir wrote:
My '20 was also the only glider (or throttled back power plane) that I ever flew which was uncontrollable with the stick against the aft stop. With every type but the '20 I could very slowly ease the stick aft until it hit the stop and then control it indefinitely with coarse use of aileron and rudder as it waffled downwards. I would think "coarse use" of the ailerons would be exactly the wrong thing to do with the stick full aft. Rudder is often the best, and sometimes the only, way to do high AOA maneuvering in fixed-wing types I have flown. In what types have you found coarse use of aileron to be of benefit at high AOA? Jack |
![]() I too learned to fly clouds, in the UK on Turn and Ball; those old gliders did at least have speed limiting dve brakes which I never had to use. When I graduated to the Oly with a German WWII artificail horizon cloud flying was the proverbial piece of cake. When my AH failed (low battery) about 12000 ft in Yugo '72, I was glad that I had those hours Of time using T and B. I was told that a skilled pilot with a Bohli freely gimballed compass could adequately cloud fly and Bohlis were banned from World comps. I did prove to my limited satisfaction that with great care and circumspection one could maintain a controlled trun using the COOK vertcal bearing compass but I do not think I would try it now. In closing, always have a backup, if you go IFR; the offical report of a sad accident to a single engine transatlantic delivery happened on final IFR approach to Reyavik , when the pilot reported AH failure! (no T and B) That is pegging your life to one unkown instrument. Don't do it. John Firth Old, no longer bold pilot. Ian Strachan ) writes: In article , Todd Pattist writes I've also had some pilots tell me they were trained years ago to use a standard compass That is, an old fashioned one with pendulous suspension of the magnet assembly. This type of compass has acceleration errors on east and west and turning errors on north and south. What may be an "error" in terms of registering an accurate instantaneous heading, might be turned to advantage in a case of total failure of gyro instruments. With great caution, of course, and IMHO not the best answer, see below. , head south It is true that a pendulous compass has turning errors on South, and could be used a sort of turn indicator on that heading. and steer with rudders. No! A good way to get disorientated, IMHO. What is wrong with turning in the normal way, application of (in this case) small amounts of bank where necessary. Fly gently, don't get used to coarse use of unnecessary control inputs. Particularly boots of rudder un-coordinated with aileron, unless you wish to spin or do aerobatics, of course!. However, to stay alive in instrument flying, particularly in turbulence, there is no substitute for proper aircraft-designed gyro instruments. I taught and examined on what we used to call "limited panel" for many years, AND IT WORKS, with a bit of practice. That is, instrument flight using a good old Sperry turn gyro presented through a needle display ("needle, ball, airspeed ... needle, ball, airspeed"). Turn gyros take little power and normally run on DC, so are well suited to glider use. People say that instrument flight using only a turn needle is difficult, But at least it is designed for the job, unlike pendulous compasses, GPS presentations etc. And what is difficult is limited-panel accurate pattern turns, approaches etc., with an examiner breathing down your neck! Merely keeping the wings about level so as not to enter a spiral dive, is not difficult. On a safe heading, of course, that is away from known high ground. Try it in a two-seater with a safety pilot, but make sure that you are really "under the hood" and are not peeping out to see the horizon, otherwise you are not really getting proper training that might get you out of trouble later. The dear old Link Trainer was pretty good for this training also, but there aren't many about now except in museums! Of course even better if your glider has a gyro-driven Artificial Horizon as well as that rate-gyro. Makes instrument flight for those not in practice, including me nowadays, reasonably straightforward. -- Ian Strachan Lasham Gliding Centre, UK |
I think part of the problem is the normal pilot response to a worsening
situation: equipment and experience play a huge part. If people are 'caught' above cloud with no blind flying instruments, there is a definite tendency to go into 'panic mode' and take the first available (unlikely to be the best) option and immediately try to spin/dive through the cloud layer. Much in the same way that stressed pilots in the mountains airbrake down (and crash) into tiny bits of green. If you know where you are (most gliders have GPS) and are not actually IN cloud then you have time to work out what you are going to do. (Although maybe some thought should have been given to this earlier?) Sometimes just waiting will improve the situation. Or you might have to fly somewhere else where you can let down clear of cloud. The world of wave/IMC glider flying is far removed from that of normal thermal soaring. Under the clouds, if the sun goes in, the lift stops and you land. Over them, it just carries on. When you are wave flying a sailplane on a cloudy day, especially at altitude, you are operating in conditions where most other aircraft are pressurised, turbine powered, de-iced and contain a full suite of navigation and autoflight equipment. When I go wave flying with others, I am always surprised by the seeming lack of PREPARATION or THOUGHT about what might happen. I suppose I have rescued too many people/gliders from the sides of mountains or edges of lakes. Wave flying above 8/8 gives me a real 'heightened sense of awareness', i.e. I'm scared. Doesn't stop me enjoying it immensely, though. ![]() A lack of any coherent contingency plans feauture strongly in incidents/accidents. What will I do if the wave gap closes? My oxygen gets low/fails? Controls start freezing up? Airbrakes won't open? etc. Where are my nearest suitable landing places? How will I get to them? How can I fly a non-precision approach in a glider in a strong wind, using GPS? The answers to most of these questions can be worked out on the ground, at your leisure. To those of you who regularly fly above cloud with no instruments: Good Luck! (You'll need it.) I don't understand why in some countries most gliders have no IF instruments in their panels at all. I know that sailplanes are not allowed to fly in IMC in some states but I'm sure there aren't laws preventing the FITTING and even non-IMC USE of blind flying kit? After all, you don't take off with the INTENTION of using your parachute but it might come in handy at some point... You can pick up a perfectly serviceable T&S/ball combo for $100-200. In fact I've just seen one on Ebay for $9 with 3 days to run. This could be the cheapest instrument in your glider and one day the most vital. |
Minden Waypoints | Carl Buehler | Soaring | 2 | August 14th 04 06:22 PM |
8th Anniversary : Kiwi Aircraft Images Update | Phillip Treweek | Military Aviation | 0 | August 13th 04 01:45 AM |
Minden In Two Weeks | ADP | Soaring | 3 | August 10th 04 01:51 AM |
Anyone know how to update an old Loran database? | Tom Jackson | Owning | 12 | December 5th 03 06:03 PM |
Anyone know how to update an old Loran database? | Tom Jackson | Piloting | 6 | December 3rd 03 02:15 AM |
