Is it Possible to Self launch (no wingman) with CG hook??
Old November 6th 04, 07:31 PM
Shawn
Jack wrote:
Shawn wrote:
Prevailing wind will plaster the box against the airport fence, to be
recycled after the flight.
The next 1-26 to land will take care of the saw horse.
Be careful what you say about the 1-26: your Mosquito could catch a Virus.
Jack
Catch one? I could mop the floor with one, once the engine is off.
http://www.pipistrel.si/virus.htm
Actually, I only picked on the 1-26 because its wing is so close to the
ground.
Shawn
Old November 6th 04, 08:21 PM
Janusz Kesik
Uzytkownik "Shawn" napisal w wiadomosci
ground.
Well, by the way of this thread, I have took a look at few websites
regarding ultralights. Look what a nice plane I have found, it tows gliders
too (the 550 Trener model)...
http://www.3xtrim.pl/
Regards,
Janusz Kesik
Poland
See Wroclaw (Breslau) in photography,
The XIX Century, the Festung Breslau, and photos taken today.
http://www.wroclaw.dolny.slask.pl
Old November 7th 04, 12:22 AM
Gary Kemp
"Bill Daniels" wrote in message news:sbPid.368503$D%.307763@attbi_s51...
A CG hook is a disadvantage only if you never plan to winch launch.
I was shown at rig made with PVC plumbing pipe for just such a situation.
it worked like a saw horse with a carpeted top and could be broken down for
storage in the glider trailer. Starting with the wings close to level is a
big help.
I don't think I would try a CG hook, wing-on-the-ground start with my Nimbus
Bill Daniels
Have done it in my Nimbus 3 and many times in my Pegasus, both CG hooks.
Old November 8th 04, 12:14 AM
John Cochrane
I've used the "stick" method several times on retrieves -- find two
sticks, put them under the wings to hold them level. It works best
with 10 mph or so headwind. If you can talk the tow pilot into running
up for 30 sec or so so you get some prop blast before you start and
less prop blast halfway through the roll that helps too.
One thing nobody has mentioned is that a good tailwheel is much more
important to the success of this sort of thing than nose vs. cg hook.
Gliders with a skid are much more vulnerable to groundloops, and
gliders with cg hooks plus skid are really bad. Keep the tailwheel
planted on the ground with full back stick until you're really sure
which way the glider is going. If you have an old glued-on skid, spend
the $100 to get a tailwheel instead.
John Cochrane (BB)
(Jerz Rossignol) wrote in message om...
Hi Guys,
I'm curious if any of you guys have ever tried to self launch with no
wing man on a cg hook only glider. I have skids on my wingtips as
well. Would you put the wing that's on the ground further forward at
start? What's the technique!!
I think this is why having a cg hook is a disadvantage.
Regards,
Jerz
Old November 8th 04, 12:30 AM
Mark Newton
"tango4" wrote:
Aerotow no problem. Don't try it with a winch though!
Why not? Winch is easier than aerotow: The rapid acceleration
means you have instant roll-axis control.
(done it several times, easy as pie)
- mark
Old November 8th 04, 01:24 AM
Bill Daniels
"Mark Newton" wrote in message
- mark
Instant roll control and no prop wash to deal with.
There was a 'lone ranger' who built a remote controlled winch 20 or 30 years
ago. He could launch himself with no help at all. I'd like to know more
about that winch.
Bill Daniels
  #28
Old November 8th 04, 02:03 AM
goneill
You need to be "very very" quick on release if the down wing
does not move forward with the winch launch as the upper wing
starts flying and lifts up and can throw the glider/you into an
end over end cartwheel, fatalities have happened with that scenario.
The winch rapid acceleration is a two edged sword ,as long as
you get the wings both moving forward its easier than a aerotow
wingdown takeoff.
gary
- mark
  #29
Old November 8th 04, 10:01 AM
CV
Actually, the prop wash will help, by providing some airflow
over the wings and control surfaces, giving you a certain
degree of control, even before the speed builds up.
CV
  #30
Old November 8th 04, 04:24 PM
F.L. Whiteley
"CV" wrote in message
CV
Actually, I'd contend this causes most wing drops since it's usually not
evenly distributed over both wings.
spaceship one Pianome Home Built 169 June 30th 04 05:47 AM
Vandenberg Launch, April 17 Piloting 5 April 9th 04 02:21 AM
Ground launch and the incremental vanishing of soaring Mark James Boyd Soaring 24 March 8th 04 10:50 PM
Pegasus/TRACE Launch Photos Posted Brian Webb Military Aviation 0 February 21st 04 03:50 PM
Friendly fire pilot may testify against wingman Otis Willie Military Aviation 0 October 11th 03 09:32 PM
